Trade: H.v.a.c.
Venting A Communications Closet
The homeowner complained about the heat in his closet that holds what appears to be household communications (TV, Sound, and Maybe something to do with computers) The plan was to install a vent fan above. On second thought, I remember hearing you guys mention interference with high voltage and communications wiring.
One can install a remote fan, but it is more money. If necessary, fine. But, it's not the first choice. Remote fan? or bath fan? |
And I do electrical, too!
Re: Venting A Communications Closet
Only if they're in close proximity with each other. And by close, I don't mean in the same room. I mean in the same hole drilled through a stud or joist.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
slave driver
Is the homeowner receptive to changing out the closet door to one that has louvers?
Trade: H.v.a.c.
Re: Venting A Communications Closet |
Trade: H.v.a.c.
Depending on the specific layout or location it would be best to install a return duct in the ceiling and direct to the HVAC trunk line.
Then cut about 2" off the bottom of the door. Install a in line fan to keep a positive air flow. Or Vice Versa A louvered door may increase the sound (if any) to the living space. High temps will kill electronics. Good Luck, Les
ABLE1 |
Master Electrician
Trade: Electrical
You look like one of my relatives able. I'm not for sure cause I drink heavily at the family functions to avoid the empty conversations
#8 | |
Trade: H.v.a.c.
Re: Venting A Communications ClosetQuote:
Installing the cut out and making in another return run is a clever idea, but, would it suck out all the heat? Seeing the fan only energizes upon a call for heat/cool. I was thinking to take that heat, and dump it in the garage. |
#9 | |
Think about it. First heat rises. So in a small closet the hottest spot is at the top. That is where you put the grill with a duct to the HVAC trunk. The 2" at the bottom is to give an equal amount of cool air coming in to the space. If it is presently 1/2 to 1" the calculate the square inches of the area. If you are in the HVAC business you should know how many sq in or sq ft you will need in a opening for a given duct that will move X amount of cfm. The 2" gap is not set in stone just my best guess to make sure you are not sucking the door shut. Depending upon the amount of air flow this may not be a big issue. The main point is that even if you are going to vent to the garage where is that air coming from???? The conditioned space?? Again Good Luck, Les
ABLE1 |
#10 | |
Bubbles, If you have relatives that look my avatar I have a boat load of sympathy for you. ![]() Then again if you are 3 sheets to the wind then maybe they look pretty good under normal conditions. ![]() The truth is that the avatar is a picture of me in disguise when I went to my cousins wedding last year. The only one at the wedding that knew me was my cousin out of about 80 family members of her soon to be husband. I was asked to leave a number of times, thinking I was a wedding party crasher until I produced my invitation. Took a little over 1/2 hour for my cousin to finally realize that of all the nuts in our family tree I would have been the only one crazy enough to travel 600 miles, and show up at a family reunion/wedding party with 80 Cajuns. At one point I thought I might be fed to the closest alligator. All had a good time. Lots of fun. Just received the invite to this years bash for both my wife and I. Haven't made plans as yet. Any chance you were in South Carolina last October, 2008???? If you were it might explain your remembrance. ![]() BTW the avatar/picture make me look much much better. ![]() ![]() Have a good weekend. Les
ABLE1 |
Trade: Control Systems
I use these alot and they rock.
http://www.middleatlantic.com/rackac...ol.htm#clscool Scrool down to the Closet Cool. Throw some stain on the oak vent and it looks sexy! I've even put the closet cooler on cabnits. |
#12 | |
Well leave it up to a Canadian to come up with a super link. Thanks!!! BTW they have a very nice calculator. http://repnet.middleatlantic.com/COM...lc/TMCalc3.asp Have a good rest of the weekend. Les
ABLE1 |
#13 | |
Trade: H.v.a.c.
As for tying the heated air into the return line. It's a simple effective idea, and honestly, that is the way I would recommend for the $$. However, the homeowner wants a fan with a t-stat(we will see when he compares prices). Tap into the homes hvac system or into the garage, it's 6 to a half dozen. It likely won't help that much in heating the home nor the garage. My thinking is that by adding heat to the garage, it will more effectively lower the heat load on the house. Perhaps the engineers can more accurately answer that, but the original question was in regards to high voltage clearance from all the spaghetti. Once again, thanks for the input. I didn't consider tapping into the return, and I didn't even think about the math in determining the correct spacing. |
#14 | |
The Security Guy...
Trade: "Alarm Company" CCTV PERS GPS 24Hr LV AV
Jim |
#15 | |
You are welcome. Always trying to help a fellow CT guy. BTW isn't it a ratio of about 4 times the duct size for a grill opening to not restrict the air flow?? Concerning the separation from the spaghetti, the general rule is 1 foot. However give it as much as you can and if they have to cross always do it at 90 degrees. Have a good week. Les
ABLE1 Last edited by ABLE1; 09-13-2009 at 07:18 PM. |
#16 | |
ABLE1 |
The Security Guy...
#18 |
Re: Venting A Communications ClosetCarlos Santana??? Thanks and I am honored. However I can't carry a tune in a tin bucket. Funny!!! LOL Les
ABLE1 |
| Does roof venting really prolong shingle life? | willworkforbeer | Roofing | 32 | 06-24-2009 05:23 PM |
| Closet door idea | jcalvin | Windows, Siding and Doors | 3 | 03-27-2009 11:32 PM |
| Venting! + Need advice from other GC's | D.A.S.Anthony | Business | 29 | 01-29-2009 09:03 AM |
| Need Help w/ a Bathroom, closet, and laundry layout in addition | TurnkeyConst | Remodeling | 8 | 12-16-2008 12:50 AM |
| roof venting repair | Home Serve | Roofing | 0 | 09-08-2008 09:44 PM |
