Originally Posted by philcav7
$10K is probably out of the question. This is job consist of approx $160K of architectural work and A/V gear. Most of the money is going to a dedicated theater, the rest is going to to updating video displays in the home and the bar area.
The ultimate goal is to enable him to be in any room of the home(with a TV) and view his cameras and have manual control of which camera is to be displayed on the TV. A single video output will suffice, as I can run it to a video distribution block(they will all show the same signal.)
He wanted the flexiblity of wife watching the kids in one room and him viewing the front porch on another tv, but those situations would be limited and is really a secondary concern if the price is too high. His current setup has no remote operation and only offers scrolling images or he has to walk to the unit and manually switch the cameras via push button. The signal is currently being distributed over the cable tv wiring using RF modulator and putting the TV on channel 134. This doesn't offer the usability and looks terrible.
I thought about reaching out to my Crestron guy, but he has been out of the area. For now, I have speced C4 in the theater and bar area. I am trying to talk him into setting up the entire house with distributed audio and lighting control, be he expressed not interest....he's a movie guy, not an audio guy.
Thanks for the insight!
I have had projects like these before... and honestly, it was not a problem.
The simple way to do it is like so:
Connect cameras to a 12 port DVR (if he wants one), making sure the dvr has a IN and an OUT for each camera. Clover has some nice DVRs that can do this (however, expensive... this can be replaced with a cctv matrix switch, as long as it has a remote and both in and out ports). Plug cameras into this DVR (or matrix switch), then from the other line, use a matrix switch. From the dvr out line and matrix switch out line, take these lines and hook them up to a AV distribution block (Elan has a nice one). Plug in any additional things into the AV distribution block (make sure it's a COAX block, since you said you don't want to complicate yourself in running audio to the TV too, and i assume the coax is already ran to the TV). Then, connect all TVs to the block.
Ok, this should complete the wiring, now we need figure out a way to control all this.
This can easily be done with a Logitech Harmony remote. Put the extender by the devices. This extender comes by default with i believe 8 IR ports (the price of this remote is like $350 or so). You hook up the extender with the IR to the devices and program them. You can use additional remotes for the project (1 per TV), or you can use a couple and program them by room (to tell the AV dist block to switch the input for whatever room you are in).
Since we used a DVR and a matrix switch (or 2 matrix switches), we can now have the wife use one of them to watch the cameras, and the husband the other one. And since i asked for the ones that have a remote control, you can program the harmony to change channels for the cameras
Here is what you would need:
12 Cameras.
1 DVR.
1 MATRIX SWITCH.
(or 2 matrix switches).
1 AV Distribution Block (remote controllable, coax type).
X Harmony Remotes (your choice here).
Some coax wire and cat5 (to run cameras, connect components).
By the way, I am an authorised ELAN/DENON dealer, if you need anything.
I believe that's it. Good luck, and if you have any questions let me know.
