Running DATA Cable, New Construction
Old 02-26-2009, 10:47 AM   #1
spoolin's Avatar
Trade: Network Data Fiber
Our company has been getting into larger and larger cabling jobs and i needed some tips for us to continue.
When running a cable for new construction office area, what can and can't you attach your cables to while running them down halls and across the rooms in the ceiling. Is it ok to affix to all thread rods for sprinklers? Is it better to use your own bendable wire to support the cable?
Also, if you are running cable in a new plenum installation with double drop ceiling, what could you attach to to suspend the cable through the ceiling given there is no drop ceiling suspension installed for the lower tile grid yet.
spoolin is offline
Old 02-26-2009, 08:10 PM   #2
GregS's Avatar
Trade: Low Voltage
Re: Running DATA Cable, New Construction
Familiarize yourself with Ericos line of hanger products. You'll find something to fit just about every situation.
And avoid touching sprinklers.. You don't want to become the excuse for any possible failure.
GregS is offline
Old 03-01-2009, 03:17 PM   #3
Electronics Expert
wireaudio's Avatar
Trade: My Trade: Too many to list here :)
I'd have to agree. Avoid sprinklers as much as possible.
As to the doible drop ceiling, i have never worked with that.
If drop ceiling can support it, i usually run it right above it with no supports, if its 1-2 cables. For more cables, i use some sort of hooks wherever i can, or a wiring basket.
Good luck.
wireaudio is offline
Old 04-13-2009, 06:16 AM   #4
Automate Anything
HomeMedia Pros's Avatar
Trade: Electrical, Home Automation, Home Theaters
Some day NEC should include Low Voltage wiring. If you are doing anything short of cable trays you are cheating your customer. Remember cable tray should always be 2 feet away from power lines and always cross them at 90 degrees. Last thing you want is some network geek sniffing out latency due to a run next to balast. You would have to rerun all of the wire and then some. Going from office to office and vacuming behind... Use the tray be a pro.
There are no stupid questions, but there are a lot of inquisitive idiots...
we like them all at www.homemediapros.com
HomeMedia Pros is offline
Old 04-13-2009, 05:45 PM   #5
ctiautomation's Avatar
Trade: Damien
I'd also recommend avoiding sprinklers. They can be a pain.
ctiautomation is offline
Old 04-16-2009, 08:18 AM   #6
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
Um, I'm not sure what you are refering to, because the National Electric Code certainly does include "low voltage"
Articles:
411
640
720
725
760
800
810
820
830
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
The Following User Says Thank You to JohnJ0906 For This Useful Post:
Celtic (08-14-2009)
Old 04-22-2009, 07:17 PM   #7
tjrmmm's Avatar
Trade: communications
hello you can use D rings .used to support cables caddy has j hook you can use or bridal rings and you can use caddy clips that attach to pencil rod
tjrmmm is offline
Old 04-22-2009, 11:34 PM   #8
Inner10's Avatar
Trade: Control Systems
Hilti has a pretty slick plastic cable clip that comes pre-loaded with nails, for runs in drop ceilings on concrete they are pretty slick. If its exposed or really long install a cable tray.
Inner10 is offline
Old 07-21-2009, 06:42 PM   #9
DiscountLowVoltage.com
msalinas's Avatar
Trade: low voltage wiring
I would get involved with ericos line of J hooks and bridal rings. They make so many different parts I'm sure they'll have something for you.
msalinas is offline
Old 08-14-2009, 05:27 PM   #10
CCW's Avatar
Trade: Low Voltage
Never go near sprinklers. Never tie-wrap to threaded rod. Never just lay the cables on the ceiling tiles, 1 or 100. Use clips, j-hooks, or other devices listed above from Caddy etc. Remember the cable / wire you install is part of the signature of your work.
CCW is offline
The Following 2 Users Say Thank You to CCW For This Useful Post:
bwalley (08-15-2009), HanerEnterprise (08-15-2009)
Old 08-14-2009, 10:02 PM   #11
slowforthecones's Avatar
Trade: scab
sounds like the kid needs to get schooled on "installation"
slowforthecones is offline
Old 08-15-2009, 09:15 AM   #12
CCW's Avatar
Trade: Low Voltage
It sounds like you're right, but it looks like this site is the place to learn. I'm glad I found this site - lots of good info.
CCW is offline
Old 08-15-2009, 09:15 AM   #13
Where's my coffee?
HanerEnterprise's Avatar
Trade: General Contracting - A/V Integration
Don't forget that other little chore - fireproofing. I never do anything without foaming, caulking, or grommeting. Don't make a mess... keep it fairly neat.
I went to a jobsite and the installer did everything wrong! Went thru steel studs without protection, hammered through firewalls, didn't secure anything, and even draped the lines over drop-in lights. The inspector not only flagged it, he thru him off the job. Cool.
Also, make sure you have plenum rated wire when you go through those plenums.
I never give up!
HanerEnterprise is offline
Old 08-15-2009, 09:28 AM   #14
Pompass Ass
bwalley's Avatar
You can't just run low voltage wires through a firewall and use fire caulk, it needs to be run through steel sleeve and then fire caulked.
bwalley is offline
Old 08-15-2009, 10:25 AM   #15
Where's my coffee?
Exactly. Sorry about omitting that part.
I never give up!
Old 08-16-2009, 06:27 PM   #16
Trade: scab
there's a company called "servicewarehouse" they've got everything you possible need for the daily newbie installer.....all install "aides" aka time savers, wire holders, markers, probes, fish tapes, benders..... price is not bad though but I've gotten some things cheaper elsewhere.
Old 08-16-2009, 06:30 PM   #17
Trade: scab
Just ask..more than happy to tell you the stuff..been doing this for almost 11+ years fire alarms, fire sprinklers, plumbing.
Old 08-17-2009, 07:14 AM   #18
Synacom
Synacom's Avatar
Trade: Information Transport Systems Installer
EIA/TIA 569A or 569B would be a good resource for you to have available. There are a number of considerations from both safety and performance considerations. Usually the threaded rods are a safe bet if you stay far enough away from what they are carrying (sprinkler, conduit, etc.) and make sure your cable cannot come loose to interfere with something below it.
Synacom is offline
Old 08-17-2009, 07:40 AM   #19
CCW's Avatar
Trade: Low Voltage
Thanks!
I've been in the buiness 25+ years, but always leanin' something new!
CCW is offline
Old 08-17-2009, 07:44 AM   #20
CCW's Avatar
Trade: Low Voltage
The problem with threadedrods is that most of the time cable is just tied to the rod, and that causes chaffing on cable. The rod can be used to support cables, but protection (hanging devices) must be used to keep the cable off the rod.
CCW is offline
Reed Construction Data? KevinA Online Leads Services 6 02-07-2012 11:41 AM
Edwards Construction DLE Introductions 5 01-05-2009 01:35 AM
Need an advice on the construction queries of my builder! Danielrow Commercial Construction 7 12-17-2008 03:46 PM
Geothermal to heat house under construction? GregWCIL HVAC 9 11-26-2008 01:30 AM
condenser fan not running BigoWhiteboy HVAC 10 11-19-2008 08:28 PM
