tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Residential Mesh Network
Old 12-05-2017, 04:49 PM   #21
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,144
Re: Residential Mesh Network
Originally Posted by SectorSecurity View Post
Please everyone knows that when you don't know how to configure a firewall you simply turn it off and tell yourself you don't need it.
That's why they give you the option to turn it off isn't it?
Sent from my XP7700 using Tapatalk
In the case of the EdgeRouter they really don't have any by default.
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 12-13-2017, 06:13 PM   #22
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 338
So I had another client call me needing better Wi-Fi coverage. She had tried extenders and new Wi-Fi router and was done dealing with it. I knew how I could run a hardline to a pretty central location in her home. Ended up using a UAP-AC-Lite for her. Killed her Wi-Fi radios in her existing router and just used the UAP for now. If she still needs better, I told her we will go with a new router and 2nd UAP. Pretty painless setup so far.
Sent from my VS988 using Tapatalk
overanalyze is offline
Old 01-07-2018, 10:50 PM   #23
Always Learning
Rewards Points: 338
Went all in for my home. Have a USG, 8 port 60watt switch, cloud key, an in wall uap and a Uap ac lite coming for my house. My old Belkin has been on the fritz and I have a mix of stuff that just works ok. The other driving force is I am finally cutting the cable so I wanted a rock solid home network to stream. Pics of the new setup once it is up and running.
Old 01-08-2018, 08:22 AM   #24
Inner10's Avatar
The 2.4 Gig In-Wall? I Installed a couple dozen and their range is minuscule and performance is atrocious. I still have 6 or 7 in stock.
Old 01-09-2018, 07:42 PM   #25
Always Learning
Rewards Points: 338
New ones are 5 & 2.4 GHz. My bedroom has the worst signal on my current setup. Going to put the in-wall in there. AC-Lite in the living room.
Nerd p0rn...
Old 01-09-2018, 08:00 PM   #26
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 234
Would have been better off mounting a up ac to the wall in place of the in wall model.
Only time they are really useful is if you need the port.
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
Old 01-09-2018, 08:24 PM   #27
Always Learning
Rewards Points: 338
Crap...well hopefully it works ok for me.
Old 01-09-2018, 11:48 PM   #28
Always Learning
Rewards Points: 338
Up and running on 1 UAP. The setup took way longer than it should have due to newb error and a problem with my modem not giving access to the USG. Once that was fixed everything went great. I am so happy with the software and UI. Lots and lots of stats!
Old 01-09-2018, 11:54 PM   #29
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 230
You can always count on these guys to be a boner killer. Right after you got all excited too.
Thanks to advice from here we installed a few of the UAP's? a few years back for a client. They worked extremely well.
I'm too cheap to do them at my own house but once I build my next one, it's gonna have kick ass wi-fi coverage in the house, shop, yard, wherever...
Xtrememtnbiker is online now
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
overanalyze (01-10-2018)
Old 01-10-2018, 12:29 AM   #30
Inner10's Avatar
Didn't I warn you about that? If you are using a local controller on the same vlan they are a PITA to setup if you need anything but the default subnet...you basically have to use CLI or suffer a half hour of frustration.
Old 01-10-2018, 12:30 AM   #31
Inner10's Avatar
Meh, the AC inwall is decent...the 2.4 is murder.
Old 01-10-2018, 07:49 AM   #32
Always Learning
Rewards Points: 338
It was the modem. It wasn't giving the USG it's IP. Took a couple power cycles of the modem to finally get it to take. Again I think mostly rookie/inexperience mistakes. It's my modem. Didn't like the free crap the ISP provided. Bought it a year or so ago.
Initially very pleased. Speeds are more than they have ever been and exceed what I am supposed to get from my ISP.
Going to get the IW-AC fired up tonight and tidy things up.
Old 01-10-2018, 08:44 AM   #33
Inner10's Avatar
That's par for the course with any dhcp connection from an ISP, almost always needs a reboot. PPPoE however doesn't seem to be as picky.
Old 01-10-2018, 04:35 PM   #34
Stryker1-1's Avatar
Rewards Points: 234
Did you use the cloud key for the controller?
Old 01-10-2018, 07:32 PM   #35
Always Learning
Rewards Points: 338
I did. I wasn't going to at first but decided to add it at the last minute. I wanted to cut my teeth on the setup at home. Plus I liked the remote login out of the box. Man there are a ton of stats with the software! Very happy so far. I even successfully activated LAN 2 on the USG and configured it for Ooma VoIP.
Old 01-11-2018, 01:07 AM   #36
Always Learning
Rewards Points: 338
Decided to mount everything to the exterior of my network panel cover. A little pre-planning and I think it looks good. Cable management is behind the cover.
Sent from my SM-T310 using Tapatalk
Xtrememtnbiker (01-11-2018)
Old 01-11-2018, 05:55 AM   #37
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 7,304
I'm impressed.
Net Zero Energy Is Here Now
“The worst day working for yourself, is still better than the best day working for someone else!”
..Jim Rohn
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
overanalyze (01-11-2018)
Old 01-11-2018, 07:44 AM   #38
Inner10's Avatar
Nicely done!
Old 01-11-2018, 10:36 AM   #39
Always Learning
Rewards Points: 338
Now that you have seen the good...here is what it looked like before.
All of this is also to finally cut cable. Once that is complete and I finalize cleaning up the interior of the panel I will share that photo.
Old 01-11-2018, 07:57 PM   #40
Stryker1-1's Avatar
Rewards Points: 234
Don't worry I have seen worse by "professionals"
More RRP Enforcement FStephenMasek Lead RRP Discussion 2 12-09-2014 10:30 AM
Anyone use the Corrigo network rtztgue Business 3 02-03-2014 01:42 AM
Computer Restarts When Connected To Network? AlphaCablingTek Low Voltage 6 12-08-2012 02:30 AM
flashing detail on residential 6stringmason Masonry 27 11-16-2012 12:08 AM
