Trade: Residential & Commercial Remodeling / Roofing
Resi-Gard / Smurf Tubes And EMI
Does anyone happen to know if Resi-Gard (sometimes called Orange Smurf tubing) protects structured wiring from high-volt EMI?
My customer is very concerned about interference, especially on the speaker wire. To accommodate, we are trying to keep at least 18" clear of all high volt, but it is not possible everywhere and Resi-Gard from Carlon seems a possible solution. Any advice is appreciated. |
Re: Resi-Gard / Smurf Tubes And EMI
Hi,
The "resi-gard" as you call it is just corrugated plastic tubing that is orange. Any EMI will never see it therefore will travel straight through it. ![]() EMT or metal spiral SealTight on the other hand will give some deflection quality to your attempt to stop the EMI from penetrating the wire in-cased there in. ![]() Hope that helps. Have a good rest of the week. Les
ABLE1 |
#3 | |
Trade: Control Systems
Smurf does very little for EMI protection, what is the application anyway? Sometime people get their knicker's in a twist over non-issues. There is probably an easyer way to get around it, such as crossing the high-voltage at 90 degrees and keeping parallel runs as short as possible. Conduiting only parts of a run is a bad bad idea (noting wrong its just a time-wasting PITA).
Electronics Expert
Trade: My Trade: Too many to list here :)
Pssst... if run the speaker wire and speakers have the "buzzing" sound in them due to interference... research this thing we call "ground loop isolator". $20 at any audio store. You can have the audio cable ran in circles around the electrical wire, put GLI and u'r golden :P.
A good read is here: http://www.epanorama.net/documents/groundloop/ |
If he's an enthusiast won't these solve his interference problem?
