25 yrs pro
Trade: low voltage
NuTone Intercom
Ran into a service call and the homeowner wanted me to upgrade his Intercom. They had an old Nutone wood-grained AM-FM intercom with a cassette player in it.(YES, A CASSETTE PLAYER!) Anyway, the installed wiring for the intercom is old fashioned ribbon cable. My question is, can the ribbon cable be used in an upgraded NuTone or M&S intercom or do i just re-run all new cable to the stations? (not an easy task unless i cut drywall)
Think about what you are going to say, think about it again, think about it one more time...... then dont say anything!!! |
Re: NuTone Intercom
Is it shielded cable? How many conductors? Type of plug on the end?
Handle It!
Re: NuTone Intercom
Highly unlikely that you can use the existing. There may be an adapter available. If not, get out your soldering gun. Will not be so difficult!
25 yrs pro
Trade: low voltage
Re: NuTone Intercom
It is sheilded with 8 conductors(red stripe at one end) with a white, clear rectangle plug.
Low Voltage Contractor
Trade: C-7
Re: NuTone Intercom
This will all depend on the existing wiring layout(home-ran, looped, etc) and what kind of equip. you plan on using. I'm sure you can make it work without tearing up the walls. Nutone sells retrofit master stations that cater to most scenarios.
Cassette tape...they still have...Ever seen one with an 8-track? Chilla |
Re: NuTone Intercom
There are certain one's that can still be connected to the existing 3-wire (as you call it, 'ribbon cable') system. I did one not too many months ago, and it had a record player in it. How's that for old? I had to call NuTone tech support to get a (very short) list of what naster units can still use the existing call boxes and remote speakers.
#7 | |
Trade: C-7
Re: NuTone IntercomQuote:
#8 | |
Trade: Squirrel Handler
I just saw a 45 rpm record player in a '59 Chrysler the other day. .
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Re: NuTone Intercom
You betcha, it's still working. I piped the existing NuTone record player in through the "aux" input on the new master unit.
For those that need this old/vintage NuTone intercom stuff repaired, there's only one guy in the country I can recommend. He has a sea of NOS parts for them: Tape-Medic (now called Pro-Tech Electronics) 15686 Marsh Rd Waynesboro, PA 17268-9038 Phone: (717) 762-1809 |
Systems Integrator
Trade: AV System Integration, Low-Voltage Contractor
Re: NuTone Intercom
no offense but a couple replies steering you in the wrong direction. with the 8 conductor wire you can use almost any nutone intercom. some functions may or may not be available depending on the way you wire or the way the wire is ran. best choice is to re-wire where ever you can with cat+59+2 depending on what options the client is looking for.
some of the features that you may miss out on depending are doorbell chime AND intercom or doorcam/speaker, etc. good luck. repost with more details if you have more questions |
Re: NuTone Intercom |
Trade: Electrical
Re: NuTone Intercom
Another option to take a look at is M&S. I have seen some of their retro-fit stuff and it was decent.The room stations are quite a bit smaller than the old school 70's stuff and the make a white trim ring to cover the old larger hole so you dont need to patch & paint.
| House Intercom System | Jengle | Remodeling | 3 | 04-08-2008 06:34 PM |
| nutone? | ptnick | Low Voltage | 5 | 09-07-2007 04:42 PM |
| Basic Intercom for upcoming Remodel project | plazaman | Low Voltage | 3 | 08-27-2007 01:34 AM |
