Semi-Pro
Trade: Low-Voltage Wiring
New To CCTV - Where To Start?
I've got a guy that wants a CCTV system for his business. I've never really gotten into it, but I can get the equipment and I'm pretty sure the installation isn't that complicated for a LV contractor. I've already found out there's a bunch of red tape to do security systems, so is CCTV just as complicated? Plus, there are so many options for the cameras... I don't know where to start.
Assuming i can legally do this, he's wanting six cameras, 4 indoor and 2 outdoor, and a DVR with a monitor. What kind of equipment should I be looking for? I hate to call my distributor and have them put together a package without doing some research and getting a better idea of what I need first.
ProWire Home Services, LLC - Kingsport, TN Audio, Video, & Communication Wiring | Home Theater Design & Installation | Home Automation | Professional Electronics | DirecTV Sales & Service Call: 877.433.WIRE | Click: www.GoProWire.com |
Trade: Low Voltage
Re: New To CCTV - Where To Start?
So do you want to practice on him?
DVRs will come with either 4, 8, and 16 inputs and variants beyond that. There are a thousand companies that 'make' DVRs when in reality they are all just rebranding the same crappy Chinese reference design. If you are looking for something with some sort of quality and ease of use, investigate DigiMerge and Capture. Not the cheapest, but also not the most expensive. ADI carries them. There are many many things to consider when it comes to cameras. Number one is: Cheap cameras will produce cheap results. You need to know what you need to cover per camera and then apply the appropriate focal length to fit it all in, or get another camera. You need to understand the differences between IR mechanical/electronic cut filters, day/night cameras, and more. You need to understand electrical requirements vs run lengths, local power vs centralized power. If local power in a commercial setting you may need to worry about cameras on different phases which introduces rolling bars.. Buy something that your supplier recommends. Play with it and get comfortable with it to gain some experience. |
Trade: scab
www.cctvforum.com has wonderful advice. I am a member there also. Pelco, Bosch and GE have great products with great support. It's a quality product with a quality warranty. GE DVRs are cheaper and less features than the Pelco and Bosch's but I use GE for 8 camera installs. I use Bosch and Pelco for larger setups.
send me a pm or ask questions on the forum for advice...goodluck. |
Trade: scab
ADI (owned by honeywell), always bargain with these motherf---. They charge outrageous prices and not always have what you need instock. They're like holedepot except they supply fire alarms, burg alarms, low volt stuff.
You'll need some tools, some you probably have. look at this thread I commented on for more info on tools needed..I'm sure you have the skills needed to install. Some things you learn as you go? http://www.cctvforum.com/about15462.html |
Trade: Low voltage (Long island NY)
At work we use speco cameras and also gvi cameras which are made by samsung. In my opinion speco cameras are the best. Speco just came out with cameras that all u need to do after installing them is just set your zoom and they auto focus. also speco has really nive dvrs.
Semi-Pro
I got a quote on a six camera system from ADI. My rep put together a pretty good package, and even threw in the cable, BNC crimpers, and door decals. I was pretty impressed. The problem is MY cost on materials is about 200 bucks more than what other companies are charging for the same type of system INSTALLED. hmmmmm....
and btw, it looks like CCTV is included under "alarm systems contractors" for the state classification which means I can't even do this unless I hire someone with 5 years experience to be a qualifying agent, and become a certified alarm systems contractor. too much red tape.
Also you may want to run simese rg59 and 2 wire for power. It's a lot easier to run one wie instead of two. Also i do not recomend using crimp on bnc. I would use compression bnc. My preference for bnc is the new cable pro bnc double bubble ends. Adi stocks the stripper, crimper and ends. We hav e not had one bad cable pro end yet.
#8 | |
Trade: scab
Re: New To CCTV - Where To Start?Quote:
Trade: scab
Care to share your quote here..maybe i can offer some feedback on no b.s. pricing for the hardawre/supplies atleast california pricing rates go.
#10 | |
Trade: scab
Semi-Pro
Yeah, I should probably PM it to ya.
Trade: scab
send it right on over.
| Kitchen - use 20A GFCI at start w/ 15A outlets??? | tmdelisle | Electrical | 25 | 07-28-2009 01:38 AM |
| Start the new year with a bang | all vinyl | Construction | 1 | 01-01-2009 04:11 PM |
| How do you start over? | Mike(VA) | General Discussion | 11 | 12-29-2008 02:58 PM |
| start up for business? | roscoe8423 | Business | 13 | 12-29-2008 12:49 PM |
| Helping A Good Buddy Start A New Biz??? | MILSAPS118 | Business | 21 | 09-23-2007 04:43 PM |
