tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Modular Connectors (not Plugs) And Stranded Wire?
Old 11-03-2010, 01:18 PM   #1
ICC Marco's Avatar
Trade: Structured Cabling
Rewards Points: 25
Would like to get your comments and opinions on using stranded wire with modular connectors?
Currently, ICC modular connectors do not support the use of stranded wire only solid.
In these challenging economic times, it appears that more and more installers are using stranded wire even for their backbone voice wiring.
Thanks for your feedback!
-Marco
ICC Marco is offline
Old 11-03-2010, 01:44 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,054
Re: Modular Connectors (not Plugs) And Stranded Wire?
I only stock solid in bulk, solid for the backbone, stranded for patch cords....honestly I have never seen someone wire their backbone in stranded; stranded is hard to find locally.
Inner10 is online now
Old 11-03-2010, 06:59 PM   #3
ABLE1's Avatar
Rewards Points: 946
If the "INSTALLERS" are installing stranded cable for backbone then it should be up to them to do the final terminations and testing so that when it fails it will be their responsibility to do the job right. Maybe they will learn something.
Les
ABLE1
ABLE1 is offline
Old 11-04-2010, 04:00 AM   #4
Synacom
Synacom's Avatar
Trade: Information Transport Systems Installer
Rewards Points: 89
There are RJ45 (8P8C) connectors made for both solid and stranded wire although most people assume the connector is 'generic' and will work on either.
Synacom is offline
Old 11-13-2010, 11:32 PM   #5
hbiss's Avatar
Trade: Electrical
Rewards Points: 101
That's crap. If an "installer" is using stranded UTP cable it's because he doesn't know what he is doing. Period.
Stranded cable is for patch cords. You use solid conductor cable for premises wiring. Purchase from reputable suppliers and you won't even see stranded cable. Purchase cheap Chinese junk cable off the internet and Ebay and that's what you are going to get. It most likely doesn't meet CAT standards and isn't UL listed per the NEC. This is what you would be supporting.
Absolutely the LAST thing your company needs to do is support this practice. The rest of the industry only provides IDC terminations for solid conductors because that is the standard. The few times I have come across stranded CAT5 it was removed at the customer's expense.
I don't give a rat's patoot about tough economic times. Do it right or don't do it at all.
-Hal
hbiss is offline
Old 11-13-2010, 11:56 PM   #6
hbiss's Avatar
Trade: Electrical
Rewards Points: 101
Just to make what you said clearer- there are plugs for cable with solid conductors and plugs for cable with stranded conductors. Use a plug for solid wire in stranded (or vice versa) and it will fail. So you need to make sure the plugs you are using are correct for the wire type. The strain relief should also be of the correct type for the shape and diameter of the cable jacket. This goes for any plug- 8P8C or 6P, 2,4,6C telephone.
That said I have heard talk of so called "universal" plugs but I have never seen and used one to confirm that they exist or work.
-Hal
hbiss is offline
Old 12-02-2010, 09:00 PM   #7
MisterCMK's Avatar
Trade: Fire Alarms, CCTV, Card Access, etc
-Hal
This.
I don't understand how any economic condition would warrant using stranded cable over solid.
MisterCMK is offline
Old 12-02-2010, 10:05 PM   #8
Thom
thom's Avatar
Rewards Points: 4,748
I, like CMK, am wondering. I've never seen stranded cat 5, I didn't know it existed. For those of you who have seen it, is it really cheaper?
thom is offline
Old 12-06-2010, 08:20 AM   #9
Synacom
Synacom's Avatar
Rewards Points: 89
Stranded Cat5 cable is usually used for patch cables. The reason for stranded is because it can flex repeatedly without breaking. Stranded is more expensive because of the process that uses multiple smaller gauge wires and adds the twist operation. With patch cables being as cheap as they are, I don't know of anyone making them.
Synacom is offline
Old 12-06-2010, 03:39 PM   #10
Inner10's Avatar
Hal is right on the money as far as the economic hardship BS.
Hal, I've never seen an 8P8C universal male plug but we do have universal female recepticals.
No its a little more, but its hard to find in stock anywhere....the only time someone would use it is if they ordered it by accident and wanted to get rid of it. I only buy stranded in pre-terminated cables.
The one time I used a box of stranded was with the B&W Casa system...it specified STP Stranded Cat5...I still have boxes of that crap hanging around.
Old 04-20-2011, 05:32 PM   #11
gizmo21187's Avatar
Trade: LV
Rewards Points: 25
http://www.techtoolsupply.com/Produc...de=CR6SD%2D100
Sent from my M80 using a lighter.
gizmo21187 is offline
Old 06-20-2011, 11:23 PM   #12
bader's Avatar
Trade: Electrical - Data Network
I have to patch stranded wire Cat 5e cables into patch panels (bad past work ... ) . What's the simplest solution ? Does exist any stranded wire to solid adaptors ? Thanks for help.
bader is offline
