Low Voltage Tech Tools
Old 08-30-2008, 02:34 AM   #1
slowforthecones's Avatar
Trade: scab
I'm trying to put together a low voltage tool box for two new trainees starting in a week. Any suggestions or thoughts on what should be included for low volt.
slowforthecones is offline
Old 08-30-2008, 10:44 AM   #2
GregS's Avatar
Trade: Low Voltage
Re: Low Voltage Tech Tools
What aspects do you cover?
TV, telephone, networking, alarm, automation, audio, video?
New construction rough-in? Retrofits? Service work?
I do all of the above and have a big list of tools that I could provide, but it may not be what you are looking for if your guys aren't going to be doing it all.
GregS is offline
Old 08-30-2008, 11:15 AM   #3
mickeyco's Avatar
Trade: Squirrel Handler
A Leatherman, some HoHo's, a big grab bag of Doritos, a 20 oz. Dr Pepper and a rebar bender.
Do a search, there was a really comprehensive thread about this for electricians a while back, take a look and remove what you don't need and add what might be missing.
mickeyco is offline
Old 08-30-2008, 11:16 AM   #4
mickeyco's Avatar
Yeah, there are a lot of specialized tools for the different categories. Probably a small fortune in all the different crimpers alone.
mickeyco is offline
Old 08-30-2008, 12:14 PM   #5
GregS's Avatar
Trade: Low Voltage
Get with the times dude! It's all compression tools now!
GregS is offline
Old 08-30-2008, 02:54 PM   #6
mdshunk's Avatar
A pair of pump pliers and a utility knife.
mdshunk is offline
Old 08-30-2008, 08:21 PM   #7
Trade: scab
It would be low voltage (alarms, cctv, intercoms, access control)
Old 08-30-2008, 08:43 PM   #8
GregS's Avatar
Trade: Low Voltage
If they are trainees, who is training them? If it's you, you should know what they need right?
Many of us can provide lists, but it may not be what you need..
For example, this is what is in my toolbelt:
1 Craftsman #2 Phllips
1 Craftsman 1/4" Flathead
1 Craftsman #2 Robertson
1 Craftsman #1 Robertson
1 Craftsman #1 Philips
1 Craftsman 3/8" Flathead
1 Telescopic Magnet
1 Yellow Wire Strippers
1 Red Wire Stripper/Crimper
1 CTC Side Cutters 6"
1 CTC Linemans Pliers 6"
1 CTC Needle Nose Pliers 6"
1 CTC Long Needle Nose Bent Tip
1 7/16" Wrench
1 1/2" Wrench
1 6" Spanner
1 Black Sharpie Marker
2 PVC Tape, white
1 Fatmax 25' Wide Tape Measure
1 Torpedo Laser Level
x Zip Ties
1 Klein Toolbelt
1 Padded Toolbelt
I have a case that I carry around that is full of all the specialty tools like, compression tools, connectors, drills, drillbits, staplers, etc.. I just add them to the toolbelt when I need them.
GregS is offline
Old 09-08-2008, 10:33 AM   #9
Synacom
Synacom's Avatar
Trade: Information Transport Systems Installer
You will need a tester. On the low end I use a Test-Um Validator to cover network, coax, telco, etc. A TDR is nice to isolate faults when troubleshooting. Don't leave home without a label maker. A toner/ tracer is good to have, UR or Dolphin connectors. I better quit now before I fill a few pages.
Synacom is offline
Old 10-20-2008, 08:33 PM   #10
Custom Prewire's Avatar
Trade: Low Voltage Wiring Installation and Repair
Don't forget a D718 type impact tool e/w 66 and 110 blades as well
Custom Prewire is offline
Old 10-20-2008, 08:42 PM   #11
mickeyco's Avatar
1 Telescopic Magnet
1 7/16" Wrench
1 1/2" Wrench
1 6" Spanner
2 PVC Tape, white
x Zip Ties
1 Klein Toolbelt
1 Padded Toolbelt
Nut drivers?
mickeyco is offline
Old 10-20-2008, 09:23 PM   #12
GregS's Avatar
Trade: Low Voltage
Nut drivers?
I keep losing them. I just use pliers now
Compression tools and such I keep in a separate tool case if that's what I happen to be working on at that time.
GregS is offline
Old 10-20-2008, 10:56 PM   #13
mickeyco's Avatar
Losing them, or having them stolen, I used to have Klein nut drivers, but they would always be stolen, I think they're the best but now it's Craftsman for me.
mickeyco is offline
Old 10-21-2008, 08:12 AM   #14
GregS's Avatar
Trade: Low Voltage
Losing them. For some reason the Kleins fell out of the toolbelt the easiest and I wouldn't notice until the next job I needed it. They are expensive to buy individually and I don't need to use them often enough.
GregS is offline
Premium tools...worth it (warning, long post) samthedog General Discussion 25 12-31-2011 06:57 AM
Tape Apla-Cator(Apla Tech Tools) tonyvlx Drywall 27 01-07-2010 07:58 PM
how fast with auto tools rotarex Drywall 6 09-02-2008 03:22 PM
Is anybody using SHEETROCK Tools? Big Bison Tools Drywall 1 11-01-2007 07:47 PM
Opinions on the best tools for Pex Dragonheart Plumbing 1 07-06-2007 04:16 PM
