Trade: NETWORK INSTALL
Low Voltage Licence
im starting a network company and looking for the lincence requierments-if any apply
#2 | |
Baltimore Electrician
Trade: Electrician
Re: Low Voltage Licence
Licencing requirements are local. Check with the building and electrical departments in your local jurisdictions, and state.
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
Trade: Low Voltage
I am a liscend Lighting contractor which install outdoor lighting systems among other lighting options. Where are you located. I am in MIChigan and I am always looking to expand my bussiness sales however quality is a must and prices do apply. Bryan
Trade: Super Electrician
I have a C-10 lisence witch lets me do low voltege and high voltege. Its better to get the general electercal lisence.
Trade: Telecommunications Cabling
What state are you in?
Fentoozler
I have a NJ EC license...I can do anything electrical
#7 | |
Trade: Electrician
Pretty good for a pie taster!
Or does the EC stand for "Eclair"?
#8 | |
Fentoozler
Re: Low Voltage LicenceQuote:
Remodeling Professionals
One of our local municipalities requires a license for any electrical work over 10 volts-so basically that leaves solar lighting or 9 volt battery powered lights, if they even exist. This requirement may even be statewide, I'm not sure. I know alot of areas don't bother enforcing some of these things.
#10 | |
Fentoozler
![]() The 10v limit is statewide...the only exceptions are: Irrigation contractors up to 30V with the scope of irrigation (no landscape lighting) HO permited in their O-O SFH Fire alarm, tele/data, etc can get an "exempt" license, which limits them to that type work only. etc.... It's a very short list.... http://www.nj.gov/lps/ca/electric/eleclaws.pdf
Trade: Electrical
Re: Low Voltage Licenceim starting a network company and looking for the lincence requierments-if any apply The bad news is that unless you are licensed or have someone licensed working with you (read partner) you can't just decide to "start a network company". Legally, that is, if the jurisdictions you want to work in require a license. That's because you don't just fill out some papers to get a license. There is a verifiable experience requirement which means working for someone else who holds a license for a period of years. Then there is usually some type of formal education requirement. A Microsoft CNE doesn't mean a hill of beans in this trade. -Hal |
The CNE program was Novell's.
Last edited by L. B. Condulet; 12-10-2007 at 05:41 PM. Reason: Removed an unintentional nasty tone to my post. |
Trade: Alarm Installer
I am an alarm installer for a small company in NM and have been installing for nearly 11 years. Because I have moved up to service I never do any new construction wiring anymore. The only time I was ever asked to see my low-voltage license was when I was at a house or building that was under construction and the inspector was feeling, let's say "voltage happy". So my question is, other than running new wire in new construction, why is a low-voltage license required, or is it?
#14 | |
Trade: Electrician
One reason, of course, is $
![]() I have also seen some absolutely hideous work by low voltage installers. (And line voltage guys too). With a license, at least there is some hope that the installation is done properly, and the installer is insured. Improper bonding is an issue I see a lot.
| High Voltage vs Low Voltage Lights | robertc65 | Outdoor Lighting | 16 | 04-04-2011 06:26 AM |
| Universal voltage ballast | K2 | Electrical | 25 | 12-05-2007 04:25 AM |
| Can I provide flood lighting via Low Voltage | robertc65 | Outdoor Lighting | 8 | 11-06-2007 10:42 AM |
| cat5 voltage | jdeihs | Low Voltage | 7 | 06-17-2007 03:26 PM |
| Voltage Sag mp3 | Magnettica | Electrical | 2 | 03-08-2007 06:39 PM |
