tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Internet Wiring
Old 06-15-2013, 07:44 PM   #1
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 298
Internet Wiring
Am helping my sister on a house she bought for my nephew and some room mates while he is going to college.
There is 4 bedrooms and am running cat 5e wire to each room for internet , all of them being on one incoming line. So my question is what kind of a distrubution box should I use on this. She does what to use just a router .
Thanks for any help.
Randy Bush is online now
Old 06-15-2013, 07:48 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,184
Re: Internet Wiring
Most residential routers have a 4 port switch built in, just plug em in.
Inner10 is online now
Old 06-15-2013, 07:52 PM   #3
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 9,908
Re: Internet Wiring
Bring the innernets to a router, and terminate all the cat 5s and plug 'em into the router.
Mebbe get a router with the 4 normal outlets, plus wireless for your laptops and smart devices.
Chuck Norris can start a fire by rubbing two ice cubes together.
480sparky is online now
Old 06-17-2013, 08:13 AM   #4
ABLE1's Avatar
Rewards Points: 918
Re: Internet Wiring
All above is correct. If you find that you need more than the 4 ports on the wireless router then just get a 5 or 8 port 10/100 data switch. Plug it into the router and the remote cables into it. All will work nicely.
BTW I would recommend installing your Cat5e cables to a box and use Cat5e jack on the ends of your cables and then use Patch cables to connect to the router or switch. Do the same at the other end for a clean professional looking install.
Good luck.
Les
ABLE1
ABLE1 is online now
Old 06-17-2013, 09:20 AM   #5
Randy Bush's Avatar
Rewards Points: 298
Re: Internet Wiring
Good luck.
Les
That is how I am doing it . Thanks for the tips.
Todays wiring rotarex Electrical 11 06-15-2013 04:41 PM
Explanation for wiring? CarpenterSFO Electrical 42 04-05-2013 11:50 AM
Keep vigilant about overseas internet scams rselectric1 General Discussion 64 08-22-2012 08:55 PM
Hello from an Internet Marketing consultant/wife of an electrician! Kristen Introductions 4 08-12-2012 03:28 PM
Electrical wiring for internet cafe tony_s Electrical 25 10-16-2007 07:35 PM
