How To Drop Some Load In Case There Is The Mains Failure?
Old 12-04-2007, 02:07 PM   #1
adindas's Avatar
Trade: PG building Adindas
I have a switch boards which have got two supplies:
- Mains supply 800 KVA from utility company
- 500 Supply from standby Genset
There is Automatic mains failure (AMF). So in case there is a power failure, the generator is automatically kicking on.
But I have the following problem because my Genset can not take the full 800 KVA,
- I am aware that I could add Bus Couplers CB and divide it into essential/priority load and non essential/non priority load. And In case of power failure, the bus coupler will open and generator will only need to supply Essential load.
However, I do not want to do this as I prefer to do it by U/V relay and manual reclosing (for non motorised MCCB) or auto reclosing for motorised MCCB. I have the following situation. The switchboard is in building A. the Distribution board that I am going to drop in case og mains failure is in Building B. So instead of installing U/V realy in the outgoing ways of the switchboard, I want to install it in the Distribution board in building B (probly part of the distributionboard).
Is it possible to put U/V relay as part of the distrbution baord, or U/V relay have to be insatlled in the Main swich board ?
adindas is offline
Old 12-10-2007, 05:39 PM   #2
L. B. Condulet's Avatar
Trade: Super Electrician
Re: How To Drop Some Load In Case There Is The Mains Failure?
This can be done quite easily with PLCs.
L. B. Condulet is offline
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
Main v.s. Load 2 Gang Meter Bubbles Electrical 5 10-05-2007 08:05 PM
removing a none load bearing wall?? samiam Framing 7 09-12-2007 08:33 AM
Electric Drop on rake Patrick Electrical 8 05-26-2007 04:07 PM
Drop ceiling question Eric K Remodeling 5 12-16-2005 07:47 AM
