Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical > Low Voltage
Old 09-03-2009, 06:20 PM   #1
Trade: Remodeling / Carpentry
Getting Dark Soon ?
It'll be getting dark soon and I want to install a couple of halogen fog lights inside my work van.
I would like to turn it on / off from a switch at the rear doors and / or side cargo doors.
Is the wiring the same as a resi 3 - way using 2 3 - way switches ?
If not, can you advise how to wire it.
We Fix Houses is online now   Reply With Quote
Old 09-03-2009, 06:24 PM   #2
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
Two 3-ways will work exactly the same in your truck as it does in your house.
+12v to the common, travellers between them, and the other common to the lamp(s). Ground the lamp(s).
If you want to use 'automotive' switches, get SPDT and consider the center terminal as the common, the outer terminals the travellers.
Age is just a number but mine is unlisted.
480sparky is online now   Reply With Quote
Old 09-03-2009, 06:42 PM   #3
Thanks Sparky - I wasn't sure about the rockers either. Good to know if I use them.
Old 09-03-2009, 08:33 PM   #4
Trade: electrical contractor
Had this done in a work van it worked out great!!
Accuracy is offline   Reply With Quote
Dark color RANT!!! NCPaint1 Painting & Finish Work 6 08-13-2009 10:32 PM
Dark marks on walls Danno6102 Painting & Finish Work 20 01-01-2009 08:47 PM
Stain not dark enough problem Jerdog44 Painting & Finish Work 5 12-24-2008 05:31 PM
Flash / Dark Colors ?? We Fix Houses Painting & Finish Work 11 09-19-2008 01:22 AM
A REAL riddle! AAPaint Off Topic (Non Trade) 122 09-08-2006 04:41 AM
