Diy Cat5 "feeder"?
Old 03-04-2009, 08:18 PM   #1
flashheatingand's Avatar
Trade: H.v.a.c.
Diy Cat5 "feeder"?
I hope this is a basic task:
I want to install a wireliess router in the entertainment area of our home. However, the modem is hard-wired to the main computer.
Can I install a "splitter" (close to the modem), and run a line directly behind the entertainment center? Or are there several other factors that I am likely missing?
flashheatingand is offline
Old 03-04-2009, 08:40 PM   #2
ABLE1's Avatar
Re: Diy Cat5 "feeder"?
Please expand on this statment.
I am likely missing? Yes, explain above and I will do my best to explain.
ABLE1
ABLE1 is offline
Old 03-04-2009, 08:45 PM   #3
mdshunk's Avatar
How do you hardwire a modem to the computer? That's a trick I'd like to see pictures of. I've never seen one that didn't use RJ45 modular cords.
mdshunk is offline
Old 03-04-2009, 08:56 PM   #4
ABLE1's Avatar
It would seem that we are on the same thoughts.
ABLE1
ABLE1 is offline
Old 03-04-2009, 09:09 PM   #5
Kgmz's Avatar
I am assuming he means the modem is wired direct with a cat 5 cable to one computer, no router.
First you cannot use a splitter. You can use that wireless router, but you will need to another cat 5 cable back to the main computer from that router. And assuming that the modem is next to the computer you will need 2 runs of cat 5 to the wireless router, one from the modem to the router and the other from the router back to the computer.
This is why I hate wireless routers, the cable jack for the modem never seems to be in the right place for the wireless part of the router. I prefer a standard router and a switch if more ports are needed and then a wireless access point.
Kgmz is offline
The Following User Says Thank You to Kgmz For This Useful Post:
flashheatingand (03-04-2009)
Old 03-04-2009, 09:17 PM   #6
ABLE1's Avatar
This is always the scary part...........................
ABLE1
ABLE1 is offline
Old 03-04-2009, 09:19 PM   #7
Electronics Expert
wireaudio's Avatar
Trade: My Trade: Too many to list here :)
Give me a sec, ill type up a nice totorial, hopefully it'll help.
wireaudio is offline
Old 03-04-2009, 09:33 PM   #8
Trade: H.v.a.c.
Thanks guys. When I said hardwired, the connection is from the modem directly to the computer via an ethernet cable.
Old 03-04-2009, 09:36 PM   #9
Electronics Expert
wireaudio's Avatar
Ok here goes:
You have a computer and a modem. To be able to install a wireless router you will have to do the following:
Go to where the modem is and look at the back of it. You should see (in most cases, unless it's a phone/data modem) three cables going in the modem: A coaxial (tv) cable OR a phone cable (depending if its a cable or dsl modem), a power cable (either regular power cable or a thin one coming from a power supply), and a network or usb cable that connects to your computer.
If you purchase a wireless router, make sure it is wireless BUT it supports wired connections (look on the back if it and see how many "holes" for network it has, if it's only 1, that's a strictly wireless router).
A good example would be a WR850G router from MOTOROLA.
Take a look at this picture:
Here are the ports on this router (should be very similar to yours):
1 is POWER.
2 is Reset button (this might or might not exist on your router)
3 is the 4 ports where your computers can be connected, also called LAN (local area connection) ports.
4 is the WAN (wide area network), in other words, the port where your modem gets connected
5 is the wireless Antenna
OK, first of, there is no such thing as a splitter for cat5 cable. That will not work.
Second, if you wish to install the router in the entertainment room, you will have to run a cable from the modem to the router, and connect your PC that is currently connected to the modem to the ROUTER instead.
Your connection should be something like this:
Modem -> Router -> Wired Computer(s) and/or other wireless devices.
How do you do this?
Follow these steps:
1. Run a cat5/5e/6 cable from the modem to the entertainment room. Connect this cable between the modem and your router (the cable from modem to router MUST be inserted into the WAN port - sometimes labeled as internet, extranet, etc. - on your router).
2. Run a cat5/5e/6 cable from the entertainment room to your PC that is now connected directly to the modem. Connect this cable in any of the other LAN ports (NOT the wan, thats where the modem gets connected) on the back of the router.
3. Connect any additional devices to the router if you have any more spare LAN ports.
4. Access the router configuration page and set up the router (this varies on modem, but if you require any additional help after you install this, let me know).
5. Connect any additional WIRELESS devices you have (given that you already set up the router, with or without authentication for the other devices to connect).
Good luck. Let me know if you need more help!
Old 03-04-2009, 11:14 PM   #10
Trade: H.v.a.c.
Thanks a lot. I really appreciate this. I will let you know. Once again, Thank You
cat5 voltage jdeihs Low Voltage 7 06-17-2007 03:26 PM
Extending CAT5 cable JPV123 Technology 6 01-28-2006 12:20 PM
