Trade: Low Voltage Installation
Dealing With Floor Joists
How do you handle running wires into walls that run parallel to and on top of floor joists when running cable up from a lower floor to a upper floor?
I have always brought the cable up a wall that ran perpendicular to the floor joists and then back down the wall from the ceiling to the jack. However, the other day I encountered a situation where POTS cable (Quad, whatever you choose), was run to a surface mount box on the baseboard by drilling diagonally from the joists in the basement up to the first floor through wall and baseboard. I was under the impression holes could not be drilled into floor joists closer than 2 inches from the ends of the joists. Obviously at some point to reach the upper level the drill hole needed to piece joist closer than 2 inches from the top of the joist. Is there an exception to the code somewhere that I am missing for a "diagonal" drilling that is justified on the concept of a drill hole becoming a notch as the direction of the drilling approaches the floor above or was the installation out of compliance? |
| How Are Contractors Dealing With Floods? | Carport King | Marketing & Sales | 3 | 06-29-2008 10:57 AM |
| Strategies for dealing with current market conditions | john elliott | General Discussion | 11 | 03-22-2008 12:50 PM |
| methods for dealing with caves | Steve Manning | Excavation & Site Work | 4 | 01-12-2008 10:50 PM |
| Dealing with subs... | ruskent | Pool Construction & Enclosures | 2 | 04-03-2007 05:11 AM |
| Dealing with flaking paint....help!!!! | Zeebo | Painting & Finish Work | 9 | 11-28-2005 11:03 PM |
