Jason
Trade: Mason
Cat5e Cable
A friend is giving me 200' of cat5e cable for $20, and instead of buying a USB cable can I use the cat cable and just put the USB ends on it? And do you need a special crimp or something to do it? I have done phone cabbles before like this. But havent done it on the USB.
And how would you run it thought 3 floors? Should I try and go in the walls or what about takeing the bottom molding off and running it behinde that? Thanks |
Re: Cat5e Cable
USB? You're goofy. Stick to laying bricks.
Trade: Residential General
Re: Cat5e Cable
Two words:
wireless |
Jason
Trade: Mason
Re: Cat5e Cable
I try to stick to bricks, but I was told you could, but I tought it was ethernet. But I might be wrong there too.
Ill probly just go buy the cable. |
pro picnic table builder
Trade: gc
Re: Cat5e Cable
you won't need it. I mean you can use it for a few years. Go wireless. i mean hell cable companies will be gone hgtv is replacing vhf.
Re: Cat5e Cable
HUH?
Remodeler Extraordinare
Re: Cat5e Cable
A.W. Davis Construction Co. http://www.awdavisconstruction.com/ Your friendly remodeling contractor |
General Contractor
Trade: Low Voltage/Home Automation
Re: Cat5e Cable
You're looking for ethernet ends, you crimp them on with a rj45 crimper. Look up how to do it and run the wire however you want. It's not hard, you can get a crimper for $20. You just have to get the wires in the right order in the plug.
Wireless isn't always the answer folks. |
Re: Cat5e Cable |
Trade: Low Voltage
Re: Cat5e Cable
The USB-IF cable spec is a maximum of 5 metres. And even at that length with manufactured/molded cables that can sometimes be iffy because the equipment you are connecting may suck. (most of the Chinese OEMed stuff just barely meets USB-IF compliance, if at all)
Just what do you need to run at that length? |
Jason
Trade: Mason
Re: Cat5e Cable
I havent done it yet. What I need to do is wire a PTZ camera. It doenst come with a wire less set up. And it is far from were it will be watched. So now that the USB is out, I do have a 2.4 GHzWireless B broadband router, 802.11b by Liksys router at my computer. So after that I need some help. I will look around for transmitters and recievers.
Here is the link- http://www.spytechs.com/spy_cameras/ptz-c3090.htm Ideas/suggestions? EDIT-It has to go from my basment up to the second floor. And idk if that is 200' but that is how much I had. Thanks |
Trade: Low Voltage
Re: Cat5e Cable
That would qualify as cheap Chinese OEMed product.
Doesn't really make any sense to have a PTZ camera on USB when you require a computer less then 5M away to drive it. For another hundred USD you could have purchased a DLink DCS-5300. Plugs into ethernet. http://www.tigerdirect.com/applicati...456&CatId=1931 If you can return it, I'd recommend it and go for the proper device to run that length. Or if you want to seriously get into CCTV, pick up a few composite video cameras, run RG6 to them and plug them into a capture card on a dedicated computer. |
Jason
Trade: Mason
Re: Cat5e Cable
I didnt but it yet. And I might go with the one that you suggested.
#14 | |
General Contractor
Re: Cat5e CableQuote:
http://www.ramelectronics.net/HTML/u...t_adapter.html I have no idea if this would work for your application or not, but it's cheaper than the $250 camera. You could hook it up to an ethernet cable long enough to go where you want just to test the picture. We usually run RG59, cat5, and some kind of power, 14-2 or so to each camera, but these are $5k cameras. Good luck on your project, I'd like to hear your solution. |
#15 | |
Trade: Low Voltage
This is an ethernet adapter for a computer that plugs into a USB port, not a "turn peripheral USB into ethernet" adapter. Interesting is it states gigabit speed, when USB 2.0 high-speed has a theoretical maximum of 480 megabits.. (which is near impossible to hit because of the overhead of USB processing performed by the host CPU) |
General Contractor
Re: Cat5e Cable |
| Cable Calc. | sparkengineer21 | Electrical | 2 | 02-06-2007 07:01 PM |
| Coaxial cable and Electric | amanandhisvan | Low Voltage | 2 | 12-28-2006 12:53 PM |
| Porter Cable Framing Nailers | Reno | Tools & Equipment | 10 | 05-04-2006 11:44 AM |
| GREAT Custome Service from Porter Cable | JPV123 | General Discussion | 3 | 04-06-2006 09:06 PM |
| Basement Office DSL/ Cable/ CAt 5 Auggg!!! | heavyparts | Electrical | 9 | 02-16-2006 04:53 PM |
