Trade: Low Voltage installation
Cat5 Voltage
I just wanted to see if anyone can tell me if there is a tester that can be used to determine if the voltage in cat 5/6 wiring is being affected by high voltage lines. I have a customer that has some issues and I think that the people that wired his home may have ran the low voltage lines a little to close to the romex. There are numerous testers available but I am not sure which one would be the best. I really do not want to cut a bunch of holes in the walls to determine if the lines are to close to romex and causing an issue. If anyone can offer any help it would be greatly apperciated. Thanks
Re: Cat5 Voltage
Cat5e UTP is almost 100% resistant to voltages that exist in the home. There are BICSI standards on the distance, but there's no evidence anywhere on this planet that any coupling occurs at dwelling voltages. In a commercial occupancy, the possibility might exist.
Lift the connection at both ends and listen with your butt set. |
Trade: Builder
Re: Cat5 Voltage
What is the Cat5 being used for, phone, computer, video with boulans?
Re: Cat5 Voltage
The Cat5 is being used for phones, data IR and volume controls.
Trade: Low Voltage
Re: Cat5 Voltage
I had faint hum on cat5 line that was run right parallel with an electrical line for about 12 metres through a basement. (no I didn't do the install)
I moved the cable over about 30cm and the hum on the line was gone. There's other stupid things that _may_ affect it such as flourencent lights. Any low voltage line should avoid those. |
Re: Cat5 Voltage
Depending upon exactly what the problem is it may be an issue that the installer DID NOT use the pairs for wiring. Meaning that instead of using the BW/WB - OW/WO pairs etc. they used BW/OW - WB/WO as pairs for connections. This will effectively cause the wiring to be parallel thus allowing the induction of voltage on the cable or cables.
If this is the problem it is much easier to fix than ripping holes the wall. Good luck. Les
ABLE1 |
Trade: Electronic Systems Contractor
Re: Cat5 Voltage
Are you still having trouble? Try turning off the mains, then see if there is still noise. Make sure you have a test set or at least not electronic handsets. Then test one line at a time. It takes time but sometimes you just gotta go 1 step at a time. Good luck.
#8 | |
Trade: Data Cabling - Fire Alarms
Re: Cat5 VoltageQuote:
Testing Cat 5 installations with a butt set is a technique I'm unfamiliar with, no wonder believe there's no proof of inductive coupling on Cat 5, you've been using a butt set as your testing device. Anyway, the statement that Cat 5 UTP is almost 100% resistant to voltages found in the home is not supported by any facts. |
| High Voltage vs Low Voltage Lights | robertc65 | Outdoor Lighting | 16 | 04-04-2011 06:26 AM |
| Universal voltage ballast | K2 | Electrical | 25 | 12-05-2007 04:25 AM |
| Can I provide flood lighting via Low Voltage | robertc65 | Outdoor Lighting | 8 | 11-06-2007 10:42 AM |
| Voltage Sag mp3 | Magnettica | Electrical | 2 | 03-08-2007 06:39 PM |
| feedback or stray voltage | toastermaker | Electrical | 4 | 11-20-2005 08:11 PM |
