Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical > Low Voltage
Old 03-01-2009, 04:51 PM   #1
Semi-Pro
gury's Avatar
Trade: Low-Voltage Wiring
Cable Management / Big bundles
What do you guys use to tie down a massive bundle of cables? I've been using those little screw in blocks with the slots that you can run a zip tie through, but I'm wondering if anybody's found a better way.
ProWire Home Services, LLC - Kingsport, TN
Audio, Video, & Communication Wiring | Home Theater Design & Installation | Home Automation | Professional Electronics | DirecTV Sales & Service
Call: 877.433.WIRE | Click: www.GoProWire.com
gury is offline   Reply With Quote
Old 03-01-2009, 06:23 PM   #2
Trade: Low Voltage
Depends on the situation.
I sometimes staple a zip tie to wood and use that. Or use the zip ties with the screw hole on them.
Or in some other cases I use some plastic cable clamps as seen in this picture:
http://www.contractortalk.com/f11/po...33/#post601296
From Datacomm Electronics, except I cannot find a picture of them on their website. Don't use them in the extreme cold.. they snap
Or you can even just staple velcro to the wall and make it nice and easy to do/undo when you add/remove cabling.
BuildingHomes is offline   Reply With Quote
Old 03-01-2009, 06:25 PM   #3
mdshunk's Avatar
I've always called those Catamounts.
For really big bundles, I like D rings or J hooks.
mdshunk is offline   Reply With Quote
Old 03-01-2009, 06:28 PM   #4
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
I built a public access TV station on the cheap and used half inch long sections of 2" diameter PVC pipe to hold bundles. Cut a slot across them, poke a screw hole in the back and attach.
olyteddy is offline   Reply With Quote
Old 03-02-2009, 01:37 AM   #5
slowforthecones's Avatar
Trade: General Contractor & Fire Protection
p clamps, drive rings, catamount zip ties
slowforthecones is offline   Reply With Quote
Old 03-02-2009, 04:27 AM   #6
Electronics Expert
Trade: My Trade: Too many to list here :)
Couldn't agree more .
wireaudio is offline   Reply With Quote
Old 03-02-2009, 07:14 AM   #7
Synacom
Trade: Information Transport Systems Installer
We stay away from cable ties because they tend to damage the cable and are one-use only. Try using 1" Velcro with a lath screw to secure it to the wall, you may like it!
Synacom is offline   Reply With Quote
Old 03-04-2009, 12:37 AM   #8
velcro is good but there is a cost factor. drive rings, catamount zip ties (with a zip tie fastner/gun) and various wire/cable clamps are pennies a piece.
Old 03-04-2009, 12:39 AM   #9
oh a trick I do for wire runs on masonry or concrete.. if you want a d ring/ drive ring in concrete... drill and put a plastic anchor, the insert your ring. Works like a charm.
Running DATA Cable, New Construction spoolin Low Voltage 31 10-16-2009 10:34 AM
floor heat cable metal lathe floor mix carterarce Ceramic & Stone Tile 9 02-01-2009 11:51 AM
Satellite / Cable-TV exterior cable routing bob_cntrctr General Discussion 10 11-25-2008 02:31 PM
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 10 11-05-2008 01:43 PM
Cable Calc. sparkengineer21 Electrical 2 02-06-2007 07:01 PM
