Flat Roof Recovery Crew Available Will Travel Seeking Partners
Old 05-21-2007, 11:51 PM   #1
roofsmart's Avatar
Trade: roofing
I have a plural component rig for recovering flat roofs,the system is a one piece seamless spray applied system that is fully adhered with no seams and it is self flashing.After it is sprayed it can be topcoated within 5 minutes with the ultraviolet blocker which blocks 87% of the suns rays.It reduces roof temps by 70 degrees and interior temps by an average 20 degrees. The beauty is it saves on tearoff which takes away a lot of labor and the possibility of collateral damage with rain.It comes with a 10 tear manufacturer backed warranty. You can sell system for $4OO.OO a square easy and i will personally do job for you for $250.00 a sq. material and labor.I can complete 70 square a day easy.If interested call me at 1-800-804-3898 we can both make a good amount of money.I have alot invested in this rig I am very serious about getting some other companies to join up and make some long lasting relationships.Also this system is for recovering metal roofs too,tried and true product been around for 32 years.
roofsmart is offline
New flat roof "ponding" medusa Roofing 67 12-12-2010 04:17 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
