Wrap Around Stairs
Old 08-06-2005, 02:51 PM   #1
...jammin
slickshift's Avatar
Trade: Rock Disciple
Wrap Around Stairs
I just can't picture how to run the stringers for wrap-around stairs
There's none around here for me to look under
Does anybody have any links to pics or plans that shows how they go?
Thanks in advance for any info
slickshift is offline
Old 08-06-2005, 03:26 PM   #2
Tom R's Avatar
Re: Wrap Around Stairs
What kind of wrap-around stairs, - - do you mean perimeter stairs on a deck?? What shape is the deck??
If so, you're stringers would basically just be cutting the joined angles in half at the meeting-point. If it's a square or rectangular deck, - - your end-stringers would extend out from the corners at 45 degree angles, - - if your deck-corners are a 45 degree angle, - - your end-stringers would extend out at 22 1/2 degree angles, - - etc.
http://www.tr-built.com
Tom R is offline
Old 08-06-2005, 05:39 PM   #3
...jammin
slickshift's Avatar
Thanks for the reply
It is rectangular, about 4x8
The stairs would go along one of the short sides and half the long side, and meet at a 45* angle on the corner
Would that be called perimeter stairs?
Just run that stringer out at a 45?
How do I figure out how to cut the steps on that stringer?
Old 08-06-2005, 06:36 PM   #4
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
What will it look like?
Floorwizard is offline
Old 08-06-2005, 07:19 PM   #5
...jammin
slickshift's Avatar
Sorry, none of the above
Hmmm...not sure how to describe this now
OK, it's 4 x 8, with 8 feet against the house
Pretty small right?
If I am looking at the house, the left side of the deck has a top step that runs the whole length of the left 4 foot side, comes around to the front, and goes for 4 feet along the left side of the 8 foot front
So it runs along a 4 x 4 section of the deck
The next lower step also runs along the entire left side, comes around to the front, and goes for the four feet of deck
The third step from the top does the same thing, etc....for six steps
These steps meet at the left corner (away from the house) at a 45* angle
As we go down the steps, the actual length of the boards I cut at a 45 increases
(If they didn't meet at a 45 and wrap around the deck, they would stay the same)
Now here's the thing I can't figure
Almost all the stringers will have the same dimensions
Theoretically I could go to Big Orange and get pre cut stringers and be done with it
But, there's that one stringer, the 45* one
If I use the pre cut stringer, it won't work
The steps are cut at a 45* angle and their width at the cut is greater than the 90* cut on the other ends
The pre-cut stringer is too small in the step area
It also looks bad, the tread is not flush with the riser part of the stringer
There's a little triangle in there
How do I figure out how to cut that 45* stringer so the tread fits and it looks good?
Old 08-06-2005, 07:40 PM   #6
Tom R's Avatar
Pythagorean Theorum, - -
A(2) + B(2) = C(2)
Let's say your 'straight' stringers have 11" treads, - -
11(2) = 121
121 + 121 = 242
Square root of 242 = approximately 15 1/2"
So 15 1/2" would be the tread length of your corner stringer.
The 'rise', of course, stays the same.
Tom R is offline
Old 08-06-2005, 07:44 PM   #7
Tom R's Avatar
Oh, and you're right, 'wrap-around' steps may be the better name, - - perimeter steps usually go all the way around all sides of the deck.
Tom R is offline
Old 08-06-2005, 08:12 PM   #8
...jammin
slickshift's Avatar
Pythagorus?
The math guy? With the theories?
Argh...
Miss Brockway was right, I do need this stuff later in life
If only Deana Marsh didn't sit next to me in class that one might have sunk in
If you knew Deana Marsh, you'd know why it didn't
lol
Thanks Tom R
I think that's what I was looking for
If not, thanks for making me remember Deana Marsh
Old 08-06-2005, 08:27 PM   #9
Tom R's Avatar
Deana Marsh, - - yes, yes, - - I know the type, - - explains how you came up with the term 'wrap-around' so fast!!
Tom R is offline
Old 08-06-2005, 08:31 PM   #10
...jammin
slickshift's Avatar
Originally Posted by Tom R
Deana Marsh, - - yes, - - I know the type, - - explains how you came up with the term 'wrap-around' so fast!!
LOL!
Yeah....ha ha ...you got me there....
Old 08-06-2005, 08:58 PM   #11
Teetorbilt's Avatar
I had an 11th grade English teacher that was the same. I had attended English schools and my command of the English language was better than hers but I learned American to impress her.
By coincidence, I met her many years later. She was still a dish and I was married to Ol'#1. Another fantasy not meant to be.
Albert Einstein
Teetorbilt is offline
Tyvek Roof Wrap Hardibuilt General Discussion 15 06-18-2007 11:31 PM
Framing Stairs Hardibuilt Framing 4 04-10-2007 09:54 PM
Boston Back Wrap JoeTedesco Electrical Picture Post 3 01-18-2007 10:51 PM
Concrete stairs summertime Masonry 20 11-04-2006 01:35 PM
Are uncut stringers old fashioned for stairs? atari Finish Carpentry 2 05-30-2006 01:59 PM
