Wood 'footing' On Ground At Bottom Of Steps Up To Deck ???
Ideas on good base for stringers at bottom of deck (2-3ft above grade) steps at ground... other than poured concrete ?
Thinking of ground contact PT timber laid horizontally across bottom of steps and under stringers (and extended a few inches beyond)... and if ok, what size, how deep, etc ? Other suggestions ? Weather = Pacific NW (lots of rain in winter, some freezing temps but not too deep)
Thanks again for your help. akm |
Deck Designer/Builder
Re: Wood 'footing' On Ground At Bottom Of Steps Up To Deck ???
Patio stones or interlock stones under each stringer.
Don't use the wood, it will only rot and make your stairs sag. |
KemoSabe
I have used 4x8 concrete lintles for stairs up to 6' wide with good results.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Trade: carpenter
Up here if the deck is attatched to the house, it and the stairs are req'd to have footings 4' deep under them.
Trade: Fan of Bodger
we have to pour a pad now or stone. used to be able to suspend stringers between posts years ago.
Trade: Framing
i like the poured concrete pad myself. but for all sakes and purposes a railroad tie would work just as well. a 6x8 laid flat would work like a concrete pad. remember, there isn't much live load on a set of stairs. most of the dead load is carried by the upper header. tamp the dirt. and use your judgement on the size of your grade beam.
#7 | |
Trade: Construction
Re: Wood 'footing' On Ground At Bottom Of Steps Up To Deck ???Quote:
one thought...3/4"- gravel packed and tamped. 2-3 ft. above grade is nothing...run a 2x6 as a kicker at the bottom of your stringers sitting on the gravel. Gravel will promote drainage so wood doesn't sit in water... Dig down 4" - bring back up to grade w/ gravel... Mac |
Thanks much to all for the comments !
Seems split... wood vs conc. Still thinking of going with the ground contact incised treated landscaping timbers, 6x6, and end cut treat with all incised treated wood framing (OW closed risers etc) on top. Guess partial to the idea of a continuous 'ftg' (eg PWF) ilo something like precast post pier ftgs under just the stringers. Ps: Glad we are not trying to build '4ft deep' in Kirkfield, Ontario
| Whats The most expensive deck you've built | deck king | Decks & Fencing | 96 | 07-10-2010 09:02 PM |
| Spiral wood steps | rbsremodeling | Framing | 28 | 07-10-2009 09:40 AM |
| how to install porcelain on outdoor wood deck? | thebasman | Ceramic & Stone Tile | 33 | 06-26-2009 07:55 PM |
| wood over concrete steps | Patrick | Decks & Fencing | 3 | 04-09-2008 11:51 PM |
| painting wood deck | pauls painting | Painting & Finish Work | 16 | 12-14-2005 01:04 PM |
