Wood Deck Over Fiberglass Deck
Old 07-12-2009, 08:33 AM   #1
mike stanislaw's Avatar
Trade: deck contractor
Can a composite or wood deck be installed over an existing fiberglass deck over living space. I know some kind of sleepers must be installed and roof membrane could be involed.
mike stanislaw is offline
Old 07-12-2009, 08:38 AM   #2
KemoSabe
loneframer's Avatar
Re: Wood Deck Over Fiberglass Deck
Fiberglass decks are not completely maintenance free. The gel coat should be reaplied at certain intervals.In some cases, I've seen these decks pull apart at the seams of the underlayment. If you do a sleeper deck, I would make it modular so that the deck may be serviced.
loneframer is offline
Wood 'footing' on ground at bottom of steps up to deck ??? akm Decks & Fencing 7 07-05-2009 02:56 PM
Peeling Deck Rail Dave R Painting & Finish Work 4 09-09-2008 05:26 PM
Deck stairs with a roof?? workswithwood Decks & Fencing 5 05-13-2008 11:23 AM
insulative properties of fiberglass vs wood door 72chevy4x4 Windows, Siding and Doors 1 02-17-2008 10:12 AM
Best Wood for new Deck robertc65 Decks & Fencing 23 02-02-2007 12:46 PM
