Who Knows About Chain Link Fences?
Old 06-15-2008, 09:36 PM   #1
The Deck Guy
Greg Di's Avatar
How big of a deal is it to put a gate in an existing chain link fence that currently has no gate? Is it as simple as cutting out the section, adding two posts, and restretching?
My neighbors and I are the best of friends and our kids currently hop yard to yard by using my little giant ladder that I set up over the fence and it's getting old. A gate would be better.
Not looking to DIY, just an approximate feel for cost so I don't have to waste another professional's time for a FREE estimate on a job we are not 100% on doing. What's good for the goose...
Greg Di is offline
Old 06-15-2008, 09:59 PM   #2
John Hyatt
John Hyatt's Avatar
Re: Who Knows About Chain Link Fences?
Chain Link is intersting,linkng chain, I always liked the idea. Think about chain that was not linked!!! it would be an orphen deal like no Moma at all!!
Its always a good idea not to waste a Pros time. J
John Hyatt is offline
Old 06-16-2008, 02:35 AM   #3
Stewy's Avatar
Trade: home improvements and renovations
depending on the height of the fence and the size of width of gate you want i would say about $500-600 for a 4' wide gate in a 4' high fence material and labour. you may save a bit buy putting the gate next to an existing terminal post if possible.
Stewy is offline
Old 06-16-2008, 02:53 AM   #4
Maxi-Pier Tech
essrmo's Avatar
Trade: foundation specialist
Lightbulb
Put in your posts first and attach the fence before you cut, then you won't need to re-stretch.
essrmo is offline
Old 06-16-2008, 08:03 AM   #5
threaderman's Avatar
Trade: Plumbing & Gas Contractor
Agreed,good advice.
threaderman is offline
Old 06-16-2008, 01:49 PM   #6
Mod / ArchiBuilder
Cole's Avatar
Greg, you should be able to install a gate in the existing chain link, no problem. But if you were going to hire someone, $450-700 should get it done.
Cole is offline
Old 06-16-2008, 03:34 PM   #7
Carpenter/fencing
nywoodwizard's Avatar
Greg exactly as you describe, Some one suggested setting post and not cutting fence till attached, sorry whoever, that doesn't make any sense, its not how its done, besides you could use the leftover to wire your gate. You could also convert a line post into a latch post, Just sleeve with a taller post and turn it into a terminal, leaves only one post to set.
Job like that could run around $400-500, depends on the companies minimum labor charge, its only an hour or so, set and stretch same day. Materials are probably around $100-125 (using old wire).
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 06-16-2008, 08:50 PM   #8
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
There's a lot of hardware involved in one gate install. It's fairly easy for a company that does it because they have all of it. They'll weld up the gate and swing it.
Probably 4 hours to do the gate and 6 hours (in two trips) to make it happen.
I did it as a summer job for two years on the NYS Thruway. Ugh! Those 50' rolls of 8 foot fence are killers!
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 06-16-2008, 09:33 PM   #9
Maxi-Pier Tech
essrmo's Avatar
yeah, that'll work.
essrmo is offline
Old 06-17-2008, 02:58 AM   #10
Stewy's Avatar
Dont cut the wire. Its only a small job but there are still two visits involved. 1-sets post or posts, 2- next day reassemble and install gate. Most building supply stores will have all the parts you need to do it. Dont cut the wire, lol
Stewy is offline
Old 06-17-2008, 10:24 AM   #11
Carpenter/fencing
To all the Einsteins, how are you going to set a terminal level with the top rail in the way,the terminal is set a few inches higher? You can't in must be moved, and once its removed the wire looses tension therefore it needs to be re stretched. This is not 2 trips, two hour job at most why come all the way back for such a small job.Anybody ever set and stretch same day? once its all hooked plumb post up and let it set for a day or so.
Old 06-17-2008, 02:45 PM   #12
Bob Kovacs's Avatar
Trade: Consultant
I'll be willing to bet that if you call a fence company, you're looking at the better part of $800 or more in NJ.
Bob Kovacs is offline
Old 06-19-2008, 04:03 AM   #13
Stewy's Avatar
not sure how you are going to stretch wire to a post sitting in wet concrete?you must be bracing the post some how till the concrete sets.
Stewy is offline
Old 06-19-2008, 07:18 AM   #14
Restoration Crazy
You could, provided the existing fence has a continuous top rail. You would need to add a bottom rail at the terminal post to the line post as well. Most likely there is a tension wire at the bottom. If so, that would also need to be re-streched.
Facebook | Twitter
Old 06-19-2008, 08:06 AM   #15
stp57's Avatar
Trade: carpenter/ handyman
No one mentioned that fully assembled gates of different sizes are available for a modest price at the home improvement stores. DIY.
Steve
stp57 is offline
Old 06-19-2008, 08:33 AM   #16
Carpenter/fencing
No ,no need for bracing, once the post is locked into the ground and top rail, its becomes "braced" by those means.
Old 06-19-2008, 09:34 AM   #17
Chris G's Avatar
Trade: Porch and Deck Builder
How many contractors does it take to change a lightbulb?
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is online now
Old 06-19-2008, 09:42 AM   #18
Farm boys woulda had it done by post #3.
neolitic is offline
Email scam: ordering chain link fence Susan Betz Decks & Fencing 5 03-18-2008 03:54 PM
Installing chain link line posts Tim C. Decks & Fencing 10 01-06-2008 04:24 PM
Chain link fencing Glasshousebltr Construction 3 08-27-2006 04:14 PM
chain link fence River Rat Dad Painting & Finish Work 10 07-30-2006 10:32 PM
chain link fence Alkyd Painting & Finish Work 10 03-09-2006 08:42 AM
