Small Project Specialist
Trade: Home Repair and Maintenance
Where Deck And Pool Meet
Got one I haven't come across before ....
Customer wants deck around pool but wants deck boards to overlap top rail of pool leaving enough room to pull his pool cover on for winter ... Will be using Azek / Procell ... Top rail of pool is 10" wide ... Looking for ideas ... Thanks in advance John |
Workin' Hard & Havin' Fun
Trade: Deck Designer/Builder
Re: Where Deck And Pool Meet
Umm,
#1. Can't happen. Sorry. #2. Install an aluminum (protected from the ACQ lumber) bracket/"L" from framing over the pool edge, then install decking over that. Pick one. ![]() ~Matt |
egotistical prick
Trade: Wood Inlay
Is this an aboveground pool?
#4 | |
Re: Where Deck And Pool MeetQuote:
Hmmmmmm .... Thanks |
Re: Where Deck And Pool Meet |
egotistical prick
Trade: Wood Inlay
Is this deck floating or deep enough to avoid frost heave if you get that? If it ain't your pool and deck will 'meet' in the future and it won't be pretty.
Trade: carpenter/ handyman
Hey Woodbutcher,
That looks really nice! And the scenery looks great too. Steve |
John Hyatt
With above ground pools I tuck the decking under the copeing,install flip up countersunk loops in the decking for the pool cover. J.
#10 | |
One way I was considering was to notch the joists to hang over pool then box the end with matching trim board ... If I use a 2" x 10" joist I should be able to make the notch leaving the equivalent of a 2" x 4" I think (?) It's an oval pool with the deck surrounding 1 end and 1 side ... |
#11 | |
Yeah I know it sounds excessively deep, but that's what our building inspector madates for all deck footings ... |
John Hyatt
One thing if the Wallet ever has to replace the liner the top rail/copeing will usually have to come off. With the decking extended over the rail its a real pain or impossible to do this. J.
#14 | |
Thanks for ideas and listening ... John |
Trade: Custom Cabinetry
I have done a couple of decks over the top of the rails of an above ground pool.
We are in CA so we don't have to worry about freeze. That helps but you should be able to use the same technique where ever you are. We frame the joists tight against the pool rails. We use a starburst or a herringbone pattern when laying the decking so we always have deck boards running perpendicular or at a 45 degree angle to the rails. This allows us to let the deck boards cantalever over. If the client doesn't like the end grain sticking out over the rails we custom mill a cap that runs over the ends and we curve it around to match the rails. The cap really adds a nice look and the milling isn't too bad so the client loves it and we can charge a pretty fair premium for the it with a nice profit margin. This works great with wood but I haven't found any composites that are stiff enough. |
| Correect Deck ?'s Robert and others | IHI | Decks & Fencing | 9 | 05-21-2008 10:45 PM |
| Pool deck drains | Bruce Fleming | Pool Construction & Enclosures | 3 | 03-02-2008 11:53 PM |
| Ipe around a pool? | obxdeck | Decks & Fencing | 5 | 09-14-2007 04:49 PM |
| to tie deck or not | POOLMANinCT | Pool Construction & Enclosures | 22 | 03-10-2007 08:40 AM |
| Need Help: Painting Pool Deck | Guardi Pro | Painting & Finish Work | 8 | 04-17-2006 10:04 PM |
