Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Decks & Fencing
Old 10-13-2009, 08:03 AM   #1
Mr know it all....not
What is the proper gapping for exotic hardwoods on the mitered corners?
I'm concerned about the surfaces where the 45 degree cuts meet.
I've seen it both ways, but I think people differ on which way is "right".
Should it be tight or gapped??
Should the various decking materials be treated the same or differently?
"Well, sir, opinions are like assholes, everybody's got one." -Clint
Btrbimmer is offline   Reply With Quote
Old 10-13-2009, 09:47 AM   #2
Trade: Deck Builder
If you want it to look good, cut them tight.
I've seen some guys that router everthing, even mitered cuts & they left a space between, looked like hammered dog doo doo, imo.
Deckman
www.alscustomdecks.com
deckman22 is offline   Reply With Quote
Old 10-13-2009, 10:15 AM   #3
With a composite I usually factor in how warm it is when I put them down also, kinda liek vinyl siding. 90 degrees and up gets little gap. 45 degrees like today I would probably leave up to 3/16.
Hardwoods....don't know, haven't had the pleasure. Will be interesting to se the replies
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline   Reply With Quote
Old 10-13-2009, 10:23 AM   #4
I almost feel like I could attach the decking tight at the mitered cut, and then run my thin kerf circular saw (Dawalt 18 volt cordless) down the miter and it would set the perfect gap all the way down. Any variation on the miter would be fixed, as long as its not out by mor than the thickness of the blade.
The saw is very accurate compared to other larger types.
As long as a keep all the fasteners out of the way, it would seem to be a viable option.
Is Ipe or Garapa too hard for that type of saw?
Also, I'll be laying decking in a week or so, and its certainly not getting any warmer this year.
Thoughts?
Old 10-13-2009, 10:25 AM   #5
genecarp's Avatar
Tight is how i have always handled it, let the butts move, keep the miters tight. G
genecarp is online now   Reply With Quote
Old 10-13-2009, 10:28 AM   #6
John Hyatt
John Hyatt's Avatar
Trade: out door areas, decks,spa room additions,fire pits,custom design
With any of the S American lumber I not only dont leave any gap I Glue the joints together with tightbond111. I use a 10'' sliding compound Makita for all the cuts. J.
John Hyatt is offline   Reply With Quote
Old 10-13-2009, 10:30 AM   #7
Originally Posted by John Hyatt View Post
With any of the S American lumber I not only dont leave any gap I Glue the joints together with tightbond111. J.
Is that the case with any decking material, or just the S. American hard woods?
Old 10-13-2009, 11:14 AM   #8
John Hyatt
John Hyatt's Avatar
With any wood project yes. J.
Old 10-13-2009, 11:23 AM   #9
Palisade Point Const.
TempestV's Avatar
Gapping a miter sounds like a recipe for disaster. Gene and John have it right.
TempestV is offline   Reply With Quote
Old 10-13-2009, 12:24 PM   #10
Composites may be different due to the fact that they expand and contract in all 4 directions where wood is much greater across the grain and minimal with the grain.
Ipe and Tigerwood decks that I have done were done with tight miters, biscuits and glue. 4 years later they still look good.
tccoggs is offline   Reply With Quote
Old 10-13-2009, 12:40 PM   #11
Is it common to use biscuits for outdoor projects? I've only used them for making furniture and book cases, with no exposure to moisture.
Old 10-14-2009, 11:45 PM   #12
There are Plastic Biscuits for exterior use, but I use wood biscuits all the time as an alignment tool. Fast, simple, adjustable. I work alot solo, and they can make life much easier for me when trying to align things properly while tacking it in. I'm never relying on them for a structural connection.
Bond and Fill makes plastic Biscuits, and you can usually find plastic biscuits in use at solid surface shops.
Problem in corners woodchuck2 Painting & Finish Work 28 08-01-2009 10:07 AM
Proper vents (air chutes) bighammer Insulation 3 01-08-2009 08:47 PM
TimberTech Composite (Earthwood) Installation - picture frame corners and HFS jackem Decks & Fencing 6 11-06-2008 04:05 PM
help-need cost of mitered Cedar Perfection corner 72chevy4x4 Windows, Siding and Doors 2 05-22-2007 09:29 PM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
