Vinyl Fencing
Old 08-22-2009, 12:28 AM   #1
cleveman's Avatar
Trade: custom home building
Vinyl Fencing
Guy wants to fence a 160' x 160' lot with some vinyl fencing in order to contain Yorkie dogs.
He wants to buy my house and install this fence. Wants me to bid the installation. Says that 6' sections of this fence sell for $34 each and wants an installation estimate.
I'm thinking 4 days to intall the 640' of fence. Is this reasonable? Apparently, you just auger holes, put the vinyl posts in, brace them up plumb and put in some quikcrete and add water.
Yes, 4 days, 1 man with auger on tractor.
Please advise.
cleveman is offline
Old 08-22-2009, 05:37 AM   #2
robert c1's Avatar
Trade: remodeler/gc
Re: Vinyl Fencing
"Says that 6' sections of this fence sell for $34 each and wants an installation estimate."
Sounds like he has all the material costs all figured out. No need for an estimate.
robert c1 is online now
Old 08-22-2009, 08:45 AM   #3
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Re: Vinyl Fencing
I used to instal vinyl fences working for a company. I can't remember the time it takes to put one in, but they are a lot more time consuming than a wood fence. The company I worked for had a hydraulic router table set up in a shop to auger out the holes. We had notching tools to put notches in the rails so when you slide them in the posts they can't come out, the notching tools are specially made.
If you only have one fence to build, I would make a router template out of plywood for your posts. And to make it so the rails can't come out, I think there is a way to drill holes in the rails and put in some rings with pins in them instead of notching them. That way you wouldn't have to get a notching tool, but check that, ask the manufacturer. And get some vinyl glue too.
Some tricks I learned for installing is if the rails aren't very flexible, add the rails to the posts as you are concreting the posts in. If the rails are thin and flexible, then add the rails after all the posts are in. Also, if you have non-flexible rails, if you do some planning you can cut the rails tight so you only have to notch or add pins in the first set of rails, then the rest of them won't come out. You need to router out holes for the pickets too in the rails.
And if the fence is on a slope, you have to check the angle of the slope and design where to auger the holes in your posts, the holes will have to be wider too, to accommodate for the slope.
I think it takes about twice as long as a wood fence. So if you figure two days for a wood fence, then four days for a vinyl. But honestly if you've never built one, it might take you about three times longer. Maybe bid five days and do some good planning.
KennMacMoragh is offline
Old 08-22-2009, 09:04 AM   #4
cleveman's Avatar
Re: Vinyl Fencing
Thanks for the insight.
cleveman is offline
Old 08-22-2009, 09:27 AM   #5
JonM's Avatar
Re: Vinyl Fencing
I've never heard of 6' vinyl fence for 34 dollars a section....
JonM is offline
Old 08-22-2009, 06:06 PM   #6
curapa's Avatar
Trade: Carpentry / Fencing / Decks
Re: Vinyl Fencing
Vinyl fence goes up way faster than wood. Most all vinyl comes with the holes pre routed in the posts now.
If 6' sections are $34 each, I would imagine this is a very, very low grade of 4' tall vinyl fence. It is possible that the sections mount between the posts with brackets. If so, as long as you space your posts correctly the install is a breeze.
Check out the details of the particular vinyl he is speaking of and let him know you pay for what you get. You dont want to be called back being blamed for faulty installation when the pickets fall off.
I would agree on the 4 days with one man, maybe add a bit of time for the small learning curve.
www.ParkerFenceandDeck.com
curapa is offline
Old 08-23-2009, 12:07 AM   #7
Re: Vinyl Fencing
Pre-routed holes would be nice, wouldn't work on a hill though.
Old 08-23-2009, 12:51 AM   #8
SC sawdaddy's Avatar
Re: Vinyl Fencing
Find out where he can get 6' panels for $34. That doesn't sound right.
SC sawdaddy is offline
Old 08-23-2009, 09:21 AM   #9
IHI's Avatar
Re: Vinyl Fencing
Going to depend on who makes it and fastening method, we've done ALOT of the cheap vinyl panels for folks round here on a budget and they're the ones with the brackets that slide in the ends of each panel and then are screwed to the posts through these brackets. Biggest thing for these projects is spacing, i like to take and cut a 2x4 to the length needed....all these cheap ones seem to be 67" between posts, or 6' o.c. whatever you wanna do, i just prefer to use the 67" 2x4 and bump posts as i go.
The hardest part is setting the posts since that's kinda critical, and i would absolutely say a 2 person job to expedite it faster and correctly since 320' of fence is alot of posts for s single man to bore, space, level, and cement...54-60 posts depending on layout and openings. The sections themselves go up very very fast, again, i would'nt do it with only one guy, the panels are larger enough they're bulky for 1 guy, and a second set of hands speeds it up expotentially..it can be done by one guy, but not worth the fight. 2 of us installed 64 panels in 4 hours, and that was with one guy holding/leveling the panel and the other guy running the screw gun attaching them to the posts, then i'd take off after another section while he finish tacking/screwing....and then after they're all hung we'd both get on finish screwing the panels securely.
Post set up takes the longest since it's critical, hanging is fast, just the opposite of wood fencing LOL!!
IHI is offline
Old 08-23-2009, 07:40 PM   #10
curapa's Avatar
Re: Vinyl Fencing
Most vinyl systems work for up to a 15 - 20 degee angle or so. If you angle is more severe you can take the additional material out of the routed hole yourself.
curapa is offline
Old 08-23-2009, 08:51 PM   #11
ClemS's Avatar
Trade: Framing
Re: Vinyl Fencing
either way you play it, it's a two person job.
i don't know what kind of fencing sells for 34 dollars per 6' section. but it must be real garbage.
ClemS is offline
Old 08-24-2009, 09:28 AM   #12
hailey's Avatar
Trade: vinyl decks and fence
Re: Vinyl Fencing
There' the best reply you could get here.I'm not sure if very very goes low eneough to describe the grade but much nicer than calling it junk like I would...
hailey is offline
Old 08-25-2009, 11:08 PM   #13
Waggz's Avatar
Trade: Painter / Home Improvement Specialist
Re: Vinyl Fencing
You can get it at Lowe's but I didn't think it was that cheap but it probably is. That stuff is crap. I'm adding poly vinyl fence and aluminum/galvanized fences to my list of services. My stuff comes from Digger Specialties.
As I paint a kitchen Semi Gloss Fire Engine Red.....
HO - "Do you like the color."
Myself - "Mam, once it hits the wall it all looks green to me."
Waggz is offline
Old 08-25-2009, 11:30 PM   #14
cleveman's Avatar
Re: Vinyl Fencing
Yeah, it was Lowe's. The deal with the fence fell through. Oh Well.
cleveman is offline
Old 08-27-2009, 08:17 AM   #15
hailey's Avatar
Re: Vinyl Fencing
Sorry just can't let an advertisement for a local competitor go by...If you're close enough to get your vinyl then you're close enough to check out Vinyl By Design...come see how customer satisfaction works!!
hailey is offline
Old 08-29-2009, 09:48 PM   #16
mitch sprouse's Avatar
Trade: windows and doors tile
Re: Vinyl Fencing
I have 196 ft of vinyl fence to do but dont know what to charge? do u charge by the ft or panel and how much for the ft and how much for a panel?
mitch sprouse is offline
Old 08-29-2009, 10:02 PM   #17
Re: Vinyl Fencing
I have 196 ft of vinyl fence to do, the customer has all the materials and I need to give her a labor price but do u charge by the ft or panel? what is the going price either way
Vinyl fencing as railing PA woodbutcher Decks & Fencing 10 05-22-2009 12:47 PM
Want to order vinyl fencing material over net? kdub1777 Decks & Fencing 5 04-07-2009 06:56 AM
Tile over vinyl pros and cons tileguy7 Ceramic & Stone Tile 23 01-17-2009 09:53 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 07:04 AM
Vinyl Fencing, Railing, & Decking Specialists lawdf General Discussion 1 02-29-2008 04:47 PM
