Trade: HVAC
Using 3"x5" Cedar Plank Decking For A Deck.
I'm a heating contractor, but I built my own home, so I know simple construction techniques. But this has me scratching my head.
I need to build a deck onto the back of my home. About 12'x40'. A friend of mine is kind of a demolitionist, and offered to me a bunch of 3.5" x 5.5"x16' double tongue & groove cedar planks from the roof of a building he salvaged. I have a few questions for those who know before I build this thing: > Is this good material to use for a deck? I live in Idaho and it will likely have up 3-6" of snow on it for a month or two each winter. Double TG planking will create a watertight deck, no? As long as I have .5"/12" slope, am I ok? > Using this material, could I build it as a simple span deck of about 10' with a 2'-3' overhang? (Did I explain that right?) > Any other "gotchas" to watch out for? I'm thinking of having an architect design it so I don't make a big mistake, but if you guys give me green light on the above questions, I'll probably just get started. |
John Hyatt
Re: Using 3"x5" Cedar Plank Decking For A Deck.
It would be better to trim off the tungues and face fasten the material
T&G decking outside drains the same way as as face fastened material. It will not be water tight and a Person dosent want it to be. John |
Trade: Log Homes
I agree trimming them into regular deck boards and bevelling the edges would be best. You will end up with some problems your way buckling rot to name a few. make sure to finish the boards on both sides and the end grains after each cut. before installing with a high qulity stain such a sikkens cetol 1 use two - three coats don't use cetol 23 on deck boards it will peel.
Trade: Log Homes
yes to all you other question
Deck Parts Retailer
![]() ![]() Trade: deck builder
How much of this 3x5 is there, is it clear?
steve scholl |
John Hyatt
YO Steve.
You do know that was a 07 post right ? |
Wasn't Steve
Deck Parts Retailer
so what's it doing up now
Trade: Log Homes
Because of similar threads
I wanna know too. By now it is perfectly aged.
www.seattlesurfaces.com 218 Main St. Suite 173b Kirkland, Wa 98033 (425) 586-0706 Twitter @SeattleSurfaces |
Trade: General
I love it when people answer a 4 year old post...makes me giggle!
| New Clear Cedar Deck Finish Question | TRISTAN | Painting & Finish Work | 6 | 10-25-2011 10:33 PM |
| Correect Deck ?'s Robert and others | IHI | Decks & Fencing | 9 | 05-21-2008 10:45 PM |
| Cedar Deck Prep Problems | Larman | Painting & Finish Work | 2 | 05-04-2007 05:31 PM |
| new cedar deck problem | mickchipp | Decks & Fencing | 5 | 12-04-2006 11:23 AM |
| cedar deck | Alkyd | Painting & Finish Work | 4 | 05-21-2006 01:02 AM |
