Under Deck Roof
Old 08-18-2008, 11:51 AM   #1
dlcj's Avatar
Trade: home builder carpenter Central Alabama
Under Deck Roof
Hey guys i got a call this morn from a guy who wants his new elevated deck to be sealed underneath (ceiling only no walls) to be used for parking golf carts, atvs and such. Ive never done one and dont think i have ever seen one around hear. I know ive read a thread about it here but cant find it. To those who have done it what method or brand system you use?
This is a hunting cabin so while it has to work look decent and last it does not have to be top notch high end million dollar home stuff.
One thougt i had was use taperd and treated strips then put up vinyle sofit material. Trim with alluminum or treated wood and use gutter on the low end.
Could use metal too.
What you think? Thanks.
dlcj is offline
Old 08-18-2008, 07:52 PM   #2
John Hyatt
John Hyatt's Avatar
Re: Under Deck Roof
Best Way>>> plywood over the joists,torchdown roof over the plywood with all needed flashing, .40 acq stringers laying in the direction of the flow Not screwed into the roof<<< screw the decking to the stringers Not thru the roof<<
A way that will work>>> regular metal roofing installed under the deck on tapered rips fastened to the bottom of the joists<< Al the DeckMan is a Master at this. J.
John Hyatt is offline
Old 08-18-2008, 07:55 PM   #3
Professional Instigator
rbsremodeling's Avatar
Re: Under Deck Roof
There is a thread about this somewhere on this site
rbsremodeling is offline
Old 08-18-2008, 07:58 PM   #4
dlcj's Avatar
Re: Under Deck Roof
deck was just built last week so tearing it down and doing a tourch down is not an option. Besides i cant do that anyway.
Metal on the underside is what im leaning toward so any help or experience with this i will appreciate.
dlcj is offline
Old 08-18-2008, 08:03 PM   #5
dlcj's Avatar
Re: Under Deck Roof
yea i know i remember reading it but i cant find it.
I think it was about the expensive hi tech stuff though.
I may end up doing that anyway just need to present the expensive and cheap options to the owner sense i dont think he really cares about first class looks on this.
dlcj is offline
Old 08-18-2008, 08:52 PM   #6
j_builder's Avatar
Trade: Specializing in residential remodeling
Re: Under Deck Roof
Under deck,under ceiling,under deck cover
I'm sure that this product has been mentioned here before...why not one more time. http://www.underdeck.com/
j_builder is offline
Old 08-18-2008, 09:13 PM   #7
BuiltByMAC's Avatar
Trade: Construction
Re: Under Deck Roof
There's this thread, which covers TimberTech's DrySpace in some detail...
http://www.contractortalk.com/showthread.php?t=33626
Mac
BuiltByMAC is offline
Old 08-18-2008, 11:17 PM   #8
dlcj's Avatar
Re: Under Deck Roof
Mac
That looks nice. Havent checked yet but i bet it will have to be special ordered here. Im going out tomorrow to look at the deck. If there's no post or beams in the middle i'll probably just build and upside down metal roof with corragated 26g metal.
dlcj is offline
Old 08-19-2008, 09:22 AM   #9
deckman22's Avatar
Trade: Deck Builder
Re: Under Deck Roof
The metal roofing under decks works well for storage area like your customer wants not high end homes that want a covered patio.
I used a new product earlier this summer on a deck. It was a rubber membrane that went under the decking between the joist, too late for that now tho. It seemed to work well, but time will tell.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 08-19-2008, 06:02 PM   #10
buckeyeso2's Avatar
Trade: carpentry
Re: Under Deck Roof
I have used underdeck once with good results. Fairly easy to install also. I got mine from Menard's.
buckeyeso2 is offline
Old 08-19-2008, 06:23 PM   #11
GGCLLC's Avatar
Trade: General Contracting
Re: Under Deck Roof
I have considered DrySnap but have not a need to use it yet.
Google DrySnap...............
GGCLLC is offline
Old 08-19-2008, 10:41 PM   #12
BuiltByMAC's Avatar
Trade: Construction
Re: Under Deck Roof
If you search on this forum for "drysnap", you'll find folks are less than pleased with that product...
Mac
Old 08-19-2008, 11:01 PM   #13
dlcj's Avatar
Re: Under Deck Roof
That does look like a snap.
I was over there today working on two other houses on the property and took a look at the deck on my way out. It is about 750sqft in an L shape and 2 differnt levels. The guy was not there so i still dont know exactly what part if all he wants done. O and most of it is about 12' high on level ground though.
dlcj is offline
Old 02-22-2009, 07:31 PM   #14
jerzeedivr's Avatar
Trade: electricial
Re: Under Deck Roof
At the jersey shore they install fiberglass decks. its a coating gray in color over the under layment. Its a nice looking job. They do it on long beach island nj.
jerzeedivr is offline
Old 05-06-2009, 10:04 PM   #15
dlcj's Avatar
Re: Under Deck Roof
I just found my pics on this project done last year.Thought it came out nice for my first attemt at it. In the first pic you can see the spacers i made out of pvc and used 3 different length screws to get my pitch.
dlcj is offline
Old 05-07-2009, 06:53 AM   #16
PA woodbutcher's Avatar
Re: Under Deck Roof
Roofing on the bottom looks like it would work and looks pretty decent. Steel roofing prices are down now.
Couple of questions though....where are you dumping the water, right out the end?
Why no notching in of the rim joist and why not just set the header on top of the 6x6s instead of bolting it on to the side of them? Also how are those stairs attached to the deck?
How did you hang and protect the lighting that's in the ceiling?
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
Last edited by PA woodbutcher; 05-07-2009 at 06:54 AM. Reason: add lighting question
PA woodbutcher is offline
Old 05-07-2009, 10:00 AM   #17
dlcj's Avatar
Re: Under Deck Roof
I thought I would get questions about that deck framing. You should have seen it before the metal. No I did not build the deck and i dont like i either. I would have notched the 6x6s, tripled the rims perpendicular to the joist and used hangers on the stair stringers. But whata yougona do?
As far as dumping the water, the roof is pitched to the middle about 2". See the gutter? If you look close you can see the receptor for a down spout on each end I havent yet done when i took pic.
I did hang the lights and they are screwed dirctly to the 26ga metal with a water tight grommet for the wire and a generous helping of silicone for added sealing. Also drilled a weap hole in the light housing just in case.They are exterior deck lights btw. The wire is direct burial 12ga.
dlcj is offline
Old 06-30-2009, 05:04 PM   #18
DeckMan77's Avatar
Trade: Decks & Fences
Re: Under Deck Roof
In regards to lighting in the underdeck system could you use low voltage landscape deck lighting. It seems like it might work?
I'm now a big believer in Tiger Claw fasteners. Knocked out my last project quicker than expected thanks to the install gun. Hope other hidden deck manufacturers learn somethin from them.
DeckMan77 is offline
Old 06-30-2009, 06:31 PM   #19
John Hyatt
John Hyatt's Avatar
Re: Under Deck Roof
hold on to your Lug Nuts its time for a OverHaul..
Gutta live The Mask. J.
Old 07-02-2009, 11:34 PM   #20
Eckhoff Const's Avatar
Trade: contractor
Re: Under Deck Roof
We have used them all and the best product by far out there is inside out underdeck by QE. I do not have enough post to show pics, but do a search for inside out underdecking and you will be able to find it.
Eckhoff Const is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Deck stairs with a roof?? workswithwood Decks & Fencing 5 05-13-2008 11:23 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
