Under Deck Drainage Systems
Old 09-30-2011, 08:06 PM   #1
scottyb488's Avatar
Trade: general
Rewards Points: 55
i have a customer looking for an under the deck drainage system. i have installed the one from lowes..ugh! cheap looking. this customer house is 3/4 million dollars....can't use the one from lowes. anyone know of a quality system that is not crazy hard to install?
thxs
scott in georgia
scottyb488 is offline
The Following User Says Thank You to scottyb488 For This Useful Post:
Beerman (04-27-2016)
Old 09-30-2011, 08:08 PM   #2
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Under Deck Drainage Systems
Timbertech has a nice one we have used.
ohiohomedoctor is offline
Old 09-30-2011, 10:33 PM   #3
BuildingDecks's Avatar
Trade: Decks and Backyard Construction
Rewards Points: 25
Few options:
TimberTech Dryspace.
Trex Rain Escapes.
Drysnap under deck waterproofing.
Wahoo decks systems.
Epdm membrane and a talented installer.
BuildingDecks is offline
The Following 2 Users Say Thank You to BuildingDecks For This Useful Post:
parkers5150 (04-27-2016), Tom Struble (09-30-2011)
Old 10-01-2011, 09:22 PM   #4
Munanbak's Avatar
Trade: Renovation, Remodeling
Rewards Points: 135
Those products look great. If you were on a stricter budget, strapping + closed soffit will work.
Munanbak is offline
Old 10-02-2011, 02:31 PM   #5
DeckPros's Avatar
Trade: Outdoor Construction
Rewards Points: 250
Stay away from Drysnap. I have used it in the past w. great results. But I did one last year and it was a mess. Had to go back several times. They must have changed where/how it is made.
I'm doing a large deck w. EPDM right now. It's a bit tricky the first time. But it was bone dry underneath during two torrential downpours in the last week.
I'm going to put beaded soffit under the joists when done. I wanted to do Azek beadboard, but we were already 10K over what the HO wanted to spend.
http://www.thedeckpros.com
DeckPros is offline
The Following User Says Thank You to DeckPros For This Useful Post:
Tom Struble (10-02-2011)
Old 06-09-2012, 08:00 AM   #6
Albinohawk's Avatar
Trade: Construction
Although the product looks great, unless you have a simple deck that comes straight off of one wall, you will be scratching your head. Don't even bother trying to contact the company, I sent them 3 emails and 2 phone calls with no response. I had an extreme scenario of three walls and four stone columns. I made it work after 4 extra days and $600 in extra materials. This was on a multi-million dollar house in one of the richest towns in America and I will never use this product again. Find a company with better customer service in case you have any questions. DRYSNAP and AMERIMAX SUCK!!!
Albinohawk is offline
Old 06-12-2012, 02:48 PM   #7
ASIinc.'s Avatar
Trade: Deck/Remodeling Contractor
Rewards Points: 75
Ive used drysnap. Seemed like an ok product but you most likely will have to change the way you frame to accommodate it better. Just got done a Gorilla Deck, works pretty good. Not thrilled with it but cheaper alernative to the under deck systems. The decking locks together and has channels underneath that drain out
ASIinc. is offline
Old 06-12-2012, 07:41 PM   #8
maineuropa's Avatar
Rewards Points: 75
I did just finish up installing an Underdeck sytem on a fairly straightforward 16" on center deck, 12' x 30'. I installed continuous gutter at both the house and the header end to ensure adequate and attractive drainage. The customer also wanted perimeter screening which made things interesting...especially at the header end where we needed to seal off the half ovals above the header in every joist pocket.
One thing in this product's favor: it is after deck installation compatible; meaning you can come in and install this product under an existing deck.
I think that this may be the product offered in Lowes...so hopefully there is a more elegant product for you out there. This was under a summer cottage deck in Maine...hardly 3/4 $million...but at least it works.
maineuropa is offline
Old 06-21-2012, 05:03 PM   #9
stillwater's Avatar
Trade: Stone, Masonry, Concrete
I'm definitely not a talented installer but this project went pretty smooth and has been a great solution for a deck with a large concrete patio below it.
There are other threads on here from more experienced people and professionals that may be helpful if you go this route.
This is a lake front home we're renovating right now. That whole front wall was rebuilt from the framing on up due to an inexperienced builder trying to use site-built windows 10 years ago.
Total costs for all of the parts and materials to do the waterproofing ran about $1/sq foot. That includes the flashing, Vycor, EPDM.
I used a 10' wide of EPDM and installed it in full pieces for the majority of it. Covered 5 joist bays at a time. Not sure I would do it that way again as there was more waste than cutting individual pieces and it was probably break-even on time.
It will be entirely hidden once the decking is complete and the lower ceiling is installed. Has room for lights, etc.
under deck drainage systems-epdm_deck1.jpg   under deck drainage systems-epdm_deck2.jpg
stillwater is offline
The Following 2 Users Say Thank You to stillwater For This Useful Post:
Munanbak (04-01-2013), Tom Struble (07-01-2012)
Old 07-01-2012, 03:22 PM   #10
Deck Masters's Avatar
Trade: Decks
Take a look at ZipUp Ceilings. Nicest looking underdeck treatment we have worked with and very fast. 2 colours & 3 finishes to choose from.
Deck Masters is offline
Old 04-27-2016, 06:44 AM   #11
mkwnesq's Avatar
Trade: Deck weatherproofing
Rewards Points: 6
There is a great new product called Dexerdry.
An easy to install, flexible, above-joist gutter flange which fits between deck boards.
Very easy to work with and it is economical.
Check out the web site - www.dexerdry.com
mkwnesq is offline
The Following User Says Thank You to mkwnesq For This Useful Post:
Tom Struble (04-27-2016)
Old 04-27-2016, 06:51 AM   #12
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
guaranteed not to leak?
Tom Struble is offline
Old 04-27-2016, 08:23 AM   #13
mkwnesq's Avatar
Rewards Points: 6
yes, with a 10 year limited warranty.
mkwnesq is offline
Old 04-27-2016, 08:45 AM   #14
Stunt Carpenter's Avatar
Rewards Points: 972
So it prevents using any hidden fasteners ?
builddaley.com
Stunt Carpenter is offline
Old 04-27-2016, 01:00 PM   #15
mkwnesq's Avatar
Rewards Points: 6
If the fastener in question uses the board slot, then yes.
The recommended fastener would be Cortex, Grabber or Starborn.
mkwnesq is offline
Old 04-27-2016, 05:07 PM   #16
Trade: siding
Rewards Points: 20
usually when we do under deck installations we drain at the girder which can be an issue with water not hitting the gutter right This seems to eliminate that issue but most decks i see these days have a picture frame which to me seems to be a problem
Old 04-30-2016, 02:21 AM   #17
GC/carpenter
Californiadecks's Avatar
Rewards Points: 5,908
So you would have to give up the hidden fastener and the picture frame? What else is there to make a deck look good?
Californiadecks is online now
Old 04-30-2016, 07:28 AM   #18
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Plugged Ipe.
J.
John Hyatt is offline
Old 04-30-2016, 08:05 AM   #19
Trade: siding
Rewards Points: 20
you're always plugging ipe..
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
aptpupil (05-03-2016), donerightwyo (04-30-2016), John Hyatt (04-30-2016)
Old 04-30-2016, 08:39 AM   #20
Talking Head
EthanB's Avatar
Rewards Points: 22
I checked out the Dexerdry system at JLC Live. I haven't used it. I can see how it would be advantageous in some situations. Particularly for builder grade decks where you can face screw and the appearance of the under-side of the deck isn't as important as the waterproofing.
On the downside, in addition to limiting the fasteners and layout, I wonder what it does to install time to have snug in a gasket on each side of each board. Probably not too bad on the first one but I bet it takes a lot of kicking to get the next board in.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
Almost Under Deck Roof doublejz Roofing 6 04-18-2010 11:50 AM
Timbertech's under deck drainage product deckman22 Decks & Fencing 4 03-25-2010 08:21 PM
Dry snap deck drainage system. catocontractors Windows, Siding and Doors 2 02-02-2010 09:06 PM
Why Build ICF monsterconstruc Green Building 32 09-28-2008 10:48 PM
Gravity drainage basement systems skidmark845 Construction 5 08-01-2007 09:22 PM
