TT Twin Planks W/ HFS
Old 04-20-2008, 04:20 PM   #1
bjg5240's Avatar
Here are some pics of my latest deck. Yes it is a boring rectangle and their are no railings just yet & stairs are not shown.
Homeowner was happy enough to put their furniture on it already
Quality Isn't Expensive, It's Priceless
bjg5240 is offline
Old 04-21-2008, 12:29 AM   #2
Deck Designer/Builder
DecksEtc's Avatar
Re: TT Twin Planks W/ HFS
Very interesting to note that you have a single beam lagged to the outside of a 4x4 post. That would never pass code here.
DecksEtc is offline
Old 04-21-2008, 08:45 AM   #3
Stone Mountain's Avatar
Trade: Outdoor contracting: fences and decks
I was about to make the same comment, Terry. You beat me to it.
Residential Deck Specialist: Vist our Website
www.fenceanddeck.ca
Stone Mountain is offline
Old 04-21-2008, 08:47 AM   #4
bjg5240's Avatar
That may just be the camera angle. They are notched 6x6 posts with a double 2x10's. They are not lagged, they are carraige bolts. And yes, it did pass inspection without a problem.
Take one more run through the pics from the other angles. You can see the double beams cut, and the outside pics show obvious 6x6's. Rough crowd!
bjg5240 is offline
Old 04-21-2008, 09:59 PM   #5
Troutstreamguy's Avatar
Trade: Siding
What did you think about the concealloc?
Troutstreamguy is offline
Old 04-21-2008, 10:49 PM   #6
bjg5240's Avatar
It was my first time using it, so I thought it was a little time consuming. I'm sure that I would be much faster now. Just make sure you fasteners are installed correctly (screw on a 45 degree angle) and make sure they seat correctly against the board or you'll start getting a wavy pattern.
I talked to the supply house guy & he said he has gotten quite a few negative responses (mostly about the time consumption) about the CONCEALoc, and highly recommened the Correct Deck HFS.
bjg5240 is offline
Old 04-22-2008, 02:04 AM   #7
BuiltByMAC's Avatar
Trade: Construction
I don't get the comments about ConcealLocs being slower. When I'm looking at using a template to mark hole locations, predrilling and running screws for a top screwed composite board, ConcealLocs are a lot faster. But I also need my lines of screws to be perfect.
I've also heard good things about the CD Fastenators, I just haven't used them yet.
HFS is where composites are going - understand that and stay ahead of the curve (and the competition)... no one is going to want to spend that much on composite (or plastic) decking and have visible screw heads all over the place. Unlike screws in wood, the screw holes in a composite board will just get more noticeable over time.
Mac
BuiltByMAC is offline
Old 04-22-2008, 08:51 AM   #8
bjg5240's Avatar
I agree Mac that the finished product is much nicer with the HFS. I was just saying that the HFS take a little adjustment over surface attachment.
bjg5240 is offline
Old 04-22-2008, 10:05 AM   #9
BuiltByMAC's Avatar
Trade: Construction
Sure, first time you work anything new, it's gonna be an adjustment...and you're gonna move slower. I was responding more to the negative comments that your supply house guy was telling you about.
(Just re-read my earlier post - yeah, that came across wrong... my bad.)
Mac
Old 04-22-2008, 10:20 AM   #10
Charitable animal
Bone Saw's Avatar
Trade: decks
bjg, looks pretty good to me
Bone Saw is offline
Old 04-22-2008, 06:03 PM   #11
The Deck Guy
Greg Di's Avatar
Ditto. It's one screw and a clip. The only way to be faster is to have the boards come with the joists already installed!
Greg Di is offline
Gluing Tongue & Groove Planks to the Floor Journeyman T Flooring 11 10-21-2007 07:02 PM
osha approved planks - BS oldrivers Health & Safety 12 06-03-2007 10:10 PM
pine planks moisture content Vermonster Flooring 2 03-13-2007 07:33 AM
Rules for wooden planks? metomeya General Discussion 17 02-11-2007 11:07 AM
Do you have extension planks? Need help! metomeya Painting & Finish Work 3 01-19-2007 11:03 PM
