Tripple 2x8 Beams On 6x6 Post
Old 06-19-2012, 12:04 AM   #1
lewisthepilgrim's Avatar
Trade: Refrigeration
Hey guys hows it goin?
I'm building a deck. I'm going to be using tripple 2x8'' beams ontop of 6x6 posts.
I don't want to spend the money on the simpson post top hardware.
What do you guys think about attaching a 2x6 scabs on each side of the post to secure the beams? nails?screws?both?
lewisthepilgrim is offline
Old 06-19-2012, 12:10 AM   #2
Dirtywhiteboy's Avatar
Rewards Points: 7,618
Re: Tripple 2x8 Beams On 6x6 Post
If the plans call for post caps use post caps. Don't worry about the money. More money will come
Dirtywhiteboy is online now
greg24k (06-19-2012)
Old 06-19-2012, 12:13 AM   #3
General Contractor
greg24k's Avatar
Rewards Points: 7,024
Why not use Beam to Post connector?
greg24k is offline
Old 06-19-2012, 12:20 AM   #4
This is MY deck...I spent the $24 a piece on the footing plate connectors(6 of them), I have 15''x15'' footers dug a Minimum of 48'' deep(80 bags of 5000psi concrete) I'm tired of spending money
Money is tight...that extra 75 bucks or so is whether or not I can get my sailboat fixed
will I be ok with my scab technique? The purpose of the post/beam connectors is really just to stop the beams from twisting or moving correct? Will my method not do the same thing just as well??
Old 06-19-2012, 12:24 AM   #5
Deck Parts Retailer
killerdecks's Avatar
Trade: deck builder
Rewards Points: 888
2 1/2 x 9" bolts will do, 12" down the 6x6 and cover the 2x8s.
I use double 2x8's for beams all day long and notch the 6x6, just have to drill more post holes, you not gaining that much more beam span.
you should look up the tables but i think a pair of 2x10's notched, will be as good as 3 2x8's, and less work and cost about the same
Really if you are that poor that $75.00 one way or the other matters why are you building a deck.
killerdecks is offline
The Following 2 Users Say Thank You to killerdecks For This Useful Post:
greg24k (06-19-2012), lewisthepilgrim (06-19-2012)
Old 06-19-2012, 12:27 AM   #6
General Contractor
greg24k's Avatar
Are you saying that you cheap and another few $$$ will break you?
greg24k is offline
Old 06-19-2012, 12:31 AM   #7
Good to know, I'll check out the double 2x10 vs the tripple 8. Where is the chart?
How much twisting/sideways force will the beams exibit? I'm assuming the 2x6 scab will be able to handle just as much force as the post/beam connector ?
No, but why spend the money if I substitute something just as effective for free?
Old 06-19-2012, 12:32 AM   #8
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Maybe this belongs in this other thread.............http://www.contractortalk.com/f11/i-...ver-do-119075/
Just say'n...........
CrpntrFrk is offline
The Following 4 Users Say Thank You to CrpntrFrk For This Useful Post:
Dirtywhiteboy (06-19-2012), greg24k (06-19-2012), griz (06-19-2012), ScipioAfricanus (06-19-2012)
Old 06-19-2012, 01:42 AM   #9
BuiltByMAC's Avatar
Trade: Deck guy
Rewards Points: 2,270
This is what happens when you scab a piece of 2x6 on the side of a post to hold a beam in place...
I don't recommend it.
Killer's got it - use doubled beams and bolt through the 2 1/2" thick notched 6x6.
Upsize your beams (2x10s or 2x12s) if you want a longer span.
Flash the tops of your beams and posts to increase your deck's life.
Mac
BuiltByMAC is offline
The Following 3 Users Say Thank You to BuiltByMAC For This Useful Post:
aptpupil (06-20-2012), greg24k (06-19-2012), ScipioAfricanus (06-19-2012)
Old 06-19-2012, 02:28 AM   #10
barry1219's Avatar
Trade: Certified Building Contractor Florida
Rewards Points: 344
This reminds me of the guy I heard today at the roofing supply house. I was picking up some stuff and the guy comes in and orders a bunch of material. The he asks if they have any smooth nails?..he does not like the ring shank because sometimes the gun does not penetrate them deep enough and he has to whack them with the hammer. Here is the best part..
Guy behind the counter says all we have is ring shank because it is Code now for any roofing to use ring shank..which it is..Old timer says.." I will get them at HD..cheaper too"..
Point I am making is...if it calls for it use it..don't re-invent the wheel..embrace the new improved wheel.
barry1219 is offline
Old 06-19-2012, 08:15 AM   #11
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
here read the whole thing, quit sounding cheap, other people read this stuff you may want to work for later.
http://www.awc.org/pdf/DCA6-Resident...9-onepager.pdf
Old 06-19-2012, 08:56 PM   #12
Talking Head
EthanB's Avatar
Rewards Points: 12
Damn Mac, you're using 4 bolts per connection?! Are you other guys doing that?
Planer.....
EthanB is offline
Old 06-19-2012, 09:15 PM   #13
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,702
Do the scabs. But you should find a better name for it. People would be more receptive.
NKLHD
knucklehead is offline
Old 06-20-2012, 12:25 AM   #14
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 24
Ethan my guess is that there are two boards butted together at that point - thus two bolts on each side & the answer would then be yes
SLSTech is offline
Old 06-20-2012, 09:21 AM   #15
BuiltByMAC's Avatar
Trade: Deck guy
SLS has it, it was a beam butt joint connection.
Mac
Old 06-20-2012, 08:17 PM   #16
Talking Head
EthanB's Avatar
Rewards Points: 12
Whew, I'm starting to price in stainless hardware for all the coastal areas and the thought of another $26 per post made me wince. Not that it really adds that much to a $15-20k deck....
Planer.....
EthanB is offline
Old 07-09-2012, 04:55 PM   #17
turns out 2 2x10 are STRONGER than 3 2x8 anyway....
soooooo when u guys notch the post, do you re-seal the exposed wood with anything?
Should I apply some type of sealant to the bottom of the posts as well?
This is what I'm shooting for...
Old 07-09-2012, 05:56 PM   #18
Deck Parts Retailer
Trade: deck builder
Rewards Points: 888
some of the "things" some people do here are because they live in the monsoon area of the us, the pacific nw. If I had to go through all that flashing that they do I would use steel like robert from cdf
Old 07-09-2012, 11:23 PM   #19
BuiltByMAC's Avatar
Trade: Deck guy
Yes, End Cut treatment. Jasco Termin-8 or similar.
I drew up the plans for this deck.
I didn't spec flashing the beam tops in the plans.
Inspector didn't 'make' me do it.
I do things like that on my projects to increase the life of my structural framing.
Mac
The Following User Says Thank You to BuiltByMAC For This Useful Post:
LEVELBEST (08-06-2012)
Old 07-09-2012, 11:34 PM   #20
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,168
trip 2x8 on 6x6 posts, who's idea what going on top of deck?, drawing/enginer, simpsons look good to me.
sunkist is offline
