Carpenter/fencing
Trex Railings
My customer is starting to drive me to drink,we plan on building a small deck,first she wants wood railing,then pvc ,now she wants some type of composite railing ,to match the decking,Trex. does trex even make a railings ?Anybody know where to get this stuff? I'm in lindenhurst,long island.thanks.
Learning without thought is labor lost; thought without learning is perilous. |
Workin' Hard & Havin' Fun
Trade: Deck Designer/Builder
Re: Trex Railings
trex.com
Carpenter/fencing
Re: Trex Railings
I meant a local supplier,but thats alright i found a place that sells it locally.I don't work with composite railings,generally pvc or wood.whats the best method to assemble and install, trim screws? It doesn't look like it takes nails very well.
#4 | ||
Trade: Construction
Re: Trex RailingsQuote:
If you're going with Designer or Traditional, you might see if she's interested in metal balusters instead of the TREX balusters. Their 2x2s just look clunky as hell (to me) and are difficult to see through. Aluminum balusters (like deckorators - http://www.deckorators.com/Classic-Baluster.htm) look very nice with the Designer series handrail components. Oh, and they're less expensive - $2/per instead of 2.40/per so even though it's not a material upgrade, it could be sold as an upgrade. This first picture is of my back deck with TREX Designer series handrail components in Win. Grey and Deckorators Classic balusters in Black. The second picture is of a client's deck I did w/ LP WeatherBest decking/railing. The second pic is more like what TREX Traditional series handrails would look like w/ Deckorator balusters. Artisan handrail systems are a completely different beast - you have to use all their components and it's a snap together system. I personally don't like the look but hey, that's just my opinion. If you're going with the TREX balusters, follow the directions on the site for attaching the balusters to the bottom rail (pre drill and screw up into balusters from the underside of the bottom rail) but for the top rail, instead of nailing the tops of the balusters through the side of the top rail (VERY VISIBLE), pre drill the tops of the balusters at a 45º angle and run screws up into the underside of the top rail. Since you're installing balusters one at a time and before you mount the top/bottom rails to the handrail posts, you will have no problem getting those screws tucked up out of sight. See my second attachment - red lines indicate screws through tops of balusters at 45º angle into underside of top rail, completely out of sight. Hopefully my description makes sense... Mac |
Re: Trex Railings![]() ![]() |
#6 | |
Carpenter/fencing
Carpenter/fencing
Re: Trex Railings
I've seen this template before and although it may be good for the straight railings it looks very impractical for the stair rails just from looking at your pictures.(deck looks nice thought)
#8 | |
Trade: Home Remodeler
Carpenter/fencing
Re: Trex Railings
I should of just went to Nassau Suffolk lumber ,i didn't realize they were on the way to the job, job site was in miller place, i take North ocean ave,Nassau Suffolk lumber is only 2-3 exits before.I've already picked up the railings ,I'm just waiting for the post to come in. I need to get this job buttoned up ,i got two balcony decks to do this week and i have plans to go to Virginia beach on the 28th,not much time left. Here's what i got done so far.
Re: Trex Railings
There is also a Nassau Suffolk location by Port jeff train station too. It is about 5 minutes from 25A and Noth ocean Avenue.
The deck looks nice Steve |
Trade: Custom deck builder
Re: Trex Railings
What kind of PT is that? It sure does not look like the trash we get around here. ACQ hem-fir or SYP and wolmanized are about the only thing we have here and that stuff is horrible.
Carpenter/fencing
Re: Trex Railings
Its probably because of the new chemicals they are treating it with now,that it looks a bit different.Sometimes the stuff here don't look so great either,but i am very picky and will go thru quite a bit and pick the choice ones for the rim boards and stair parts.
Carpenter/fencing
Re: Trex Railings
Thanks, I ended up going to East Islip lumber,there not too far from were i live and they stock everything i need.I went on nassau suffolk lumbers web site and it showed they carry trex railings but when i called they said they don'y carry it anymore,i told them then maybe its time to remove it off your web site.
Trade: Deck Design and Installations
Re: Trex Railings
I have a customer interested in the Trex Designer railings and Deckorator balasters. How are the balasters connected to the Trex top and bottom rails ? Did you use the plastic connectors or drill the rails ? What size balasters did you use, 26'' or the larger size ? Thanks.
#15 | |
Trade: Construction
![]() I know they've got some new connectors out for the Deckorators baluster that are flared at the bottom. I don't know if those will fit under the top rail but they might pretty up the bottom rail. ![]() I used 26" balusters. Mac |
Re: Trex Railings
The new connectors fade if you get the colored ones... I also think that drilling them is a little better. I have had to go and glue ones where the connector screw broke off. If you have the drill press, drill them if you dont just use the connectors they work ok.
Re: Trex Railings
Mac, how high from the deck were your railings, using the Trex Designer Top/Bottom rail kit with 26" Deckorator balasters ? I am trying to get to 36".
#18 |
Re: Trex Railings
I'd kindly suggest getting a few resources on building decks, and code.
You're allowed 4" from the deck to the bottom rail. Add in the 26" baluster, and you're up to 30". Now it's just a matter of what you use & how it's set up for the railing pieces. For example, a 2x4 Cedar bottom & top rail will put you just over 36", and higher if there's a cap rail on top. Just sit down, think it thru, draw it out, and then do the math. ![]() Also, make sure you don't take on a project that's over your head for where you are right now- that's advice we all have to remember, no matter where in life we are! Best wishes, ~Matt |
#19 |
Carpenter/fencing
Re: Trex Railings
Not with out a large toe space i would think unless another style top and bottom rail is used
Learning without thought is labor lost; thought without learning is perilous. Last edited by nywoodwizard; 09-26-2007 at 06:54 PM. |
#20 | |
Trade: Construction
![]() Also, for longer handrail sections, install some shorty baluster sections below the bottom rail for intermediate support - composite railings really like to sag! ![]() Mac Last edited by BuiltByMAC; 09-27-2007 at 01:44 AM. Reason: Get close up pic of shorty baluster piece |
| Trex Decking | craker | Decks & Fencing | 44 | 08-31-2007 11:14 PM |
| Trex Rail System pricing. | ABI.Chris | Decks & Fencing | 0 | 04-23-2007 03:34 PM |
| Iron Railings | rangie | Painting & Finish Work | 5 | 03-14-2007 11:05 AM |
| Problems with tight Trex butt joints? | RowdyRed94 | Carpentry | 39 | 02-28-2006 12:25 PM |
| Spiral staircase for Trex deck | Woodcrafter74 | Landscaping | 2 | 11-21-2005 11:21 AM |
