Trex Gate??
Old 04-24-2010, 06:48 AM   #1
D.Foster's Avatar
Trade: Carpentry & Remodeling
Trex Gate??
I am bidding on a job that will involve replaceing decking with trex and doing trex traditional railing and the client wants a gate about 36-40" wide. Anyone ever make one outta trex materials, or do they come madeup up already?
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 04-24-2010, 07:07 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,244
Re: Trex Gate??
You make one up to match the railing. I use Easy Gate brackets, I find them to work best on Trex or other heavy gate material and it takes about 15 minutes to make a gate .
Good luck
greg24k is offline
D.Foster (04-24-2010)
Old 04-24-2010, 07:12 AM   #3
D.Foster's Avatar
Re: Trex Gate??
Is that the brand name, Easy Gate Bracket?
D.Foster is offline
Old 05-03-2010, 02:04 PM   #4
Brittany M's Avatar
Trade: Trade Professional
Re: Trex Gate??
Hello, I am a representative of Trex. This can be done but there is a great potential for the gate to sag due to the weight of the Trex. One thing we recommend using is fence gate hardware in that it is made to hold heavier material than that of standard gate hardware. Another recommendation is to install a wheel on the bottom of the gate to allow for added support. The problem with this is that the wheel could leave a mark on the deck over time. The only other possible solution would be to build the gate out of both pressure treated framing and the Trex balusters and top rail. The pressure treated would have to be painted but it would help prevent sagging.
Brittany M is offline
Old 05-03-2010, 02:08 PM   #5
genecarp's Avatar
Rewards Points: 2,000
Re: Trex Gate??
I was going to suggest building a Hybrid of Trex with the main structure being ACQ, GMOD
genecarp is offline
Old 05-03-2010, 06:25 PM   #6
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Re: Trex Gate??
I would rather use glued up pasta than trex.
JonMon
John Hyatt is offline
The Following User Says Thank You to John Hyatt For This Useful Post:
naturalwood (06-01-2012)
Old 05-03-2010, 07:53 PM   #7
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Re: Trex Gate??
I was going to say you could use a quality product and not have issues at all and you could add a wheel and it would not mark up a quality material... (in other words trex sucks)
RobertCDF is offline
Old 05-03-2010, 09:37 PM   #8
Deck Designer/Builder
DecksEtc's Avatar
Rewards Points: 1,000
Re: Trex Gate??
What he said...
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
Old 05-03-2010, 09:54 PM   #9
dkillianjr's Avatar
Rewards Points: 2,464
Re: Trex Gate??
I've built one out of trex before with no problems.
I built a mitered flat 2"x4" frame, screwed the ballusters to it, them capped it with a trex 2"x4" to match the rail. I just used regular gate hinges and latch. To keep it from sagging I just used one of those anti sag adjustable rods, I cant remember the real name of them. I think a wheel on the bottom sounds a little goofy lol.
dkillianjr is offline
Old 05-04-2010, 05:32 PM   #10
Greg's Avatar
Trade: Custom Decks
Rewards Points: 282
Re: Trex Gate??
I have built many gates from Trex. The anti -sag kit is #1, along with making some sort of support to hold the weight of the gate when closed or open. Even just an eye hook that takes a little uplift to latch will do wonders for the longevity. Normal hinges work fine and it looks better than a lot of bracketry,
Everytime I go back because the **** is delaminating, the gates have held up suprisingly well.
http://www.centennialdecks.com
Greg is offline
Old 05-06-2010, 08:52 AM   #11
D.Foster's Avatar
Re: Trex Gate??
Thanks guys,
The wheel does sound hokey to me.
And Trex would'nt be my first choice either but, it's not my deck.
Anyway,they apparently had no idea how much the project would cost, so they need to save more...
D.Foster is offline
Old 05-06-2010, 03:16 PM   #12
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: Finish carpentry, drywall, Tile
Re: Trex Gate??
get out of here!!!!
mnjconstruction is offline
The Following 2 Users Say Thank You to mnjconstruction For This Useful Post:
D.Foster (05-07-2010), John Hyatt (05-06-2010)
Old 06-01-2012, 02:52 PM   #13
tlfutah10's Avatar
Trade: Fence Contractor
Re: Trex Gate??
There is a placce in Utah that makes trex gates for fences, they can probably give you some numbers on a railing gate.
tlfutah10 is offline
Old 06-01-2012, 06:39 PM   #14
dvatt's Avatar
Rewards Points: 380
Re: Trex Gate??
Use Tt radiance rail and have Tt build it for you. Spend all that money on deck material and put up a pressure treated railing? I feel like slamming my head into a wall. I can't imagine how cheap that would look.
dvatt is offline
Old 06-01-2012, 07:18 PM   #15
slowsol's Avatar
Rewards Points: 2,212
Re: Trex Gate??
I hope he has this gate built by now. It's been over a year
-John
slowsol is offline
Old 06-01-2012, 08:08 PM   #16
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,430
Re: Trex Gate??
ive built em using trex, ceder frame simpsom brkts stanley hardware trex face, same deal around a/c units, looks good matches deck ho,s luv it
sunkist is offline
Old 06-01-2012, 08:32 PM   #17
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,972
Re: Trex Gate??
"you can build a gate in 15 MINUTES" thats the best one ever
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 06-06-2012, 10:34 AM   #18
CFCDistributors's Avatar
Trade: Fences and Decks
Re: Trex Gate??
Hey, check out Trex's fencing website, TrexFencing.com. They talk all about gates on there. If you call them up they might even be able to send some install instructions if they're not on the site.
I do recommend using some stronger hardware, we install a lot of Trex Fencing and designed some special hardware that fits well.
CFCDistributors is offline
Elite miracle one gate operator problem wlcm2ericcntry Electrical 11 04-08-2011 03:46 PM
trex sm partnership Bone Saw Decks & Fencing 5 02-11-2010 08:41 AM
Wooden fence gate talk roof-lover Decks & Fencing 9 02-10-2009 06:15 PM
Fence gate on a hill? Apex McGann Decks & Fencing 38 01-26-2009 03:29 PM
Vinyl fence gate posts Danno6102 Decks & Fencing 6 10-20-2008 09:42 PM
