Treating End Grain Joints
Old 07-07-2007, 05:58 PM   #1
Chris G's Avatar
Trade: Porch and Deck Builder
I'm doing a cedar deck with a picture frame border. Do you suggest gapping the mitered corners to let the ends breath, or do you treat with a sealer and butt them? Hope that makes sense. The first place I tend to see rot on decking is at the butt joints, hence the question.
Chris G is offline
Old 07-07-2007, 06:48 PM   #2
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Re: Treating End Grain Joints
When I did my last deck I didn't seal them but I used a polyglue and biscuts on the mitered frame ends. The butt joints in the field of the deck I used a lapped mitre. My exwife still has the house and the deck is seven years old and going strong, not like she ever powerwashes it or seals it anymore.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 11-14-2009, 10:41 AM   #3
John Hyatt
John Hyatt's Avatar
With end grain joints I use tighbond 111, rub/pat the glue into both sides and wait..... the grain will suck up the glue..then put the glue on again. This is a very old trim trick. J.
John Hyatt is offline
Old 11-14-2009, 03:04 PM   #4
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
If you gap it, it will look like hell. I suppose you could put a clear sealer on it, but I'd be leary of it showing through. I always just glue and screw my corners. Maintain it with a high quality stain applied every couple years is the only way I can think of to make it last forever. Or build it out of iron wood instead of cedar.
KennMacMoragh is offline
Old 11-14-2009, 05:18 PM   #5
Originally Posted by kestrel38 View Post
Glueing joints is often thought of as a solution by carpenters but what must be remembered is that lumber needs to move. If you glue something so well the lumber will split when it expands and later contracts.
Mitre, fix and preserve as you install would be answer but not glue.
That's true, but it depends on your design. I saw someone glue a 1x mitered column wrap, and after a few days, the wood split but the miters stayed together. I did a mitered column wrap with glued corners, but I cut it a quarter inch big to allow for shrinkage, attached it with thin finish nails that could bend while the wood shrinks. I think it worked, but I haven't gone back to look at it.
Wood shrinks very little length wise though, it shrinks width wise the most. I've never seen an issue with shrinking and cracking when gluing end grain miters.
Old 11-14-2009, 05:32 PM   #6
Chris G's Avatar
Considering this is a two year post I can't even remember what I did. I think I mitred them tight. No glue.
It's in my 'hood, so I'll take a pic and you can see what it looks like now. My guess is that the heel has opened up.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 11-14-2009, 05:38 PM   #7
Cool, didn't notice the date.
Old 11-14-2009, 06:27 PM   #8
John Hyatt
John Hyatt's Avatar
After 30 years in the trades , 20 of them building outdoor areas and 12 of them working with S American lumber I have never had an endgrain joint fail because it cant move.
Keeping it from moving is the whole idea!! Kest,,thats the stupid to the max post.
In fact the more I think about it the more stupid it gets. Most Carpenters make a mistake gluing up wood Joints???? DMF J.
Old 11-30-2009, 06:50 PM   #9
PlaneWoodworker's Avatar
Trade: Finish Carpentry, Woodworking, Cabinets
Someone was reading my mind
Matt Fuller
Prestige Remodeling
"Do it once, do it right."
PlaneWoodworker is offline
Old 12-02-2009, 08:51 PM   #10
Mr know it all....not
Btrbimmer's Avatar
I've had very good results using Tite Bond III on s.american lumber, but its getting colder and it does not seem to set up properly below about 50 degrees.
Can anyone recommend an alternative that may work better in colder temperatures?
"Well, sir, opinions are like assholes, everybody's got one." -Clint
Btrbimmer is offline
Old 12-03-2009, 12:15 AM   #11
This...
neolitic is offline
Old 12-03-2009, 12:37 AM   #12
Teetorbilt's Avatar
Gorilla Glue, follow instructions and trim off the excess. Polyurathanes are bad A, I've been working with them for over 30 yrs.
Wear some latex or vinyl gloves if you don't want it on you until you shed it.
Albert Einstein
Teetorbilt is offline
Old 12-03-2009, 07:54 AM   #13
John Hyatt
John Hyatt's Avatar
The monkey glue folks also make an two part epoxie that works well. Nothing about temp at all in the instrustions I have used it in 40 degree weather set up time was about 10 min but I kept the clamps on over night. J.
Azek butt joints holding up? LeonardDB Finish Carpentry 39 11-28-2009 08:30 PM
Tiling over Concrete Expansion Joints Clueless Ceramic & Stone Tile 16 11-25-2007 11:48 PM
Hardwood Floor Pattern and End Joints 4yanx Flooring 25 07-29-2007 07:14 AM
Expansion joints for underground fed meter cans mdshunk NEC Discussion 12 02-02-2007 03:13 PM
obtuse ceiling joints and bubbles in mudd Spencer Drywall 12 03-04-2006 10:45 PM
