Trap Door In Deck?
Old 06-22-2009, 03:41 PM   #1
Panzer5's Avatar
Rewards Points: 254
Trap Door In Deck?
New Question Posted Below: Trap door in deck?
HO wants me to replace cellar door (see pics) with a trap door set flush into the deck - to increase the useable space of the deck. To me, this means 'make the space useable for an impromptu drunken dance party.' <cue "Jump, Jump, Jumparound...>
My original plan was simply to build up the existing cellar cover, pretty much as seen in the pics, and leave it exposed (framing around it, but leaving it essentially unchanged) above the new deck (& building a new set of stairs down). She doesn't like the look of this & wants the trap door to blend in to the deck.
The problem is that any door will have to be big enough for folks to get down into the cellar to service the HVAC, etc... My concern is that the (small female) HO won't be able to lift a big trap door that I feel is safe enough to be walked on.
Anyone put traps into decks? Think this is a bad / or okay idea? Any suggestions on springs / other devices that would assist the HO in lifting the door? (I thought of a heavy set of hinges & a cantilevered counterweight (see drawing) - but this seems like too much work for too little money... and I'm going to have to figure a way to keep rain out of the cellar...
<From here down is the original posted question, answered satisfactorily...>
The existing space is somewhat cramped. (see photos) There are a set of concrete steps adjacent to a cellar entrance. Local code requires attaching the deck to the house via a ledger.
If I remove the steps, I can put in a ledger that is approximately 8' long. If I don't, the ledger would only span about 5' between where a set of stairs to the deck will go & the concrete steps.
Would you take out the existing steps or frame around them?
(The steps (new for the deck) down will go about where the bucket is...)
Trap Door in Deck?-jmo-deck.jpg   Trap Door in Deck?-jmo-deck-3.jpg   Trap Door in Deck?-trap-door.jpg
Scott (the ex-grunt-tanker-jarhead guy)
Last edited by Panzer5; 08-22-2009 at 09:48 AM. Reason: New question, same project
Panzer5 is offline
Old 06-22-2009, 03:47 PM   #2
JonM's Avatar
Rewards Points: 1,218
Re: Trap Door In Deck?
Remove...
JonM is offline
Old 06-22-2009, 03:50 PM   #3
AutumnWood Inc.'s Avatar
Trade: Deck Builder
Rewards Points: 550
They are in the way ... Why would you want to frame around them ...
AutumnWood Inc. is offline
Old 06-22-2009, 03:52 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,053
Out, damned spot!
Tinstaafl is online now
Old 06-22-2009, 03:54 PM   #5
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Rewards Points: 1,000
I'd frame around them, attach to the house over them, and also scab down to them... Also, this is under 30"... so their say on how you build is reduced. Be that as it may, it's still worth building it right- and stay tuned, 'cause there will be about 6 "right" ways of building it mentioned ASAP!
~Matt
BreyerConstruct is offline
Old 06-22-2009, 04:13 PM   #6
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Jack Hammer time. J.
John Hyatt is offline
Old 06-22-2009, 04:17 PM   #7
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,712
You want to spend a whole day dicking around trying to frame around the steps?
Take 2 hours to bust those up and get them the heck out of there.
Man-up, bust up the steps!!
All you have to do now is re-locate the cellar steps inside the house somewhere and you can build them a way bigger deck.
WarnerConstInc. is online now
Old 06-22-2009, 07:05 PM   #8
Windwash
Windwash's Avatar
Rewards Points: 148
Tear them out at least to below the top of foundation with enough room for your ledgerboard/framing.
Looks like they used a different siding gauge for the left side of the door
Windwash is offline
Old 06-22-2009, 07:35 PM   #9
BCULP2's Avatar
Trade: Commercial PM
Rewards Points: 33
It would take longer to frame around them then to take them out.
DEMO!!!
BCULP2 is offline
Old 06-22-2009, 07:43 PM   #10
willworkforbeer's Avatar
Trade: home remodeling
A note for those that do the occasional concrete removal.
Make your own sledgehammer. I made a 110# sledgehammer out of 5-6" (cant remember, lost sledge) thickwall box steel for the head (18" long) and solid 2" steel handle. put a point on one end. Ate sidewalks for breakfast, run circles around a jackhammer. Takes some a** to run it but it was an incredible tool. Took down one end of a 9" 80 y/o poured concrete basement, had handle tied to floor joists, like a battering ram. Oh yeah I did fracture a bone in my forearm using it once so be carefull.
Eat those steps in less then ten licks.
willworkforbeer is offline
The Following User Says Thank You to willworkforbeer For This Useful Post:
B.K (06-25-2009)
Old 06-22-2009, 08:39 PM   #11
knucklehead's Avatar
Trade: Extraordinary Carpenter
Rewards Points: 2,704
That explains some things
I would tale them out . at least the top one
knucklehead is offline
Old 06-22-2009, 08:49 PM   #12
Why risk screwing up that old foundation trying to get the crete out?
decking flush with the bottom of the door, cut your joists to fit over the steps, make sure it's blocked & reinforced. This looks like a budget deck area... and that's cheaper than renting a jackhammer!
~Matt
Old 06-22-2009, 08:51 PM   #13
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
OK, if you have to have a ledger, bust it out.
But, that deck is only 18-24" high. Does it need a permit? I would not use a ledger on a low level deck, unless there were circumstances that prevented me from installing footings near the house.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 06-22-2009, 11:41 PM   #14
RobertCDF's Avatar
Trade: Custom deck builder
Rewards Points: 1,533
Are some people forgetting crucial things?? GROUND HEAVE! take them out... spanning over them and if the ground heaves... see where this is going??
Doing things "wrong" just because a permit may not be required is not right.
RobertCDF is offline
Old 06-23-2009, 09:10 AM   #15
redwood's Avatar
Rewards Points: 476
In my area, it is not wrong, just smart. We don't have ground heave, just earthquakes. If those steps are stable, they probably provide just a much support as a footing would. I won't tear into the siding of a house unless I have to.
Mark
Pioneer, CA
redwood is offline
Old 06-23-2009, 03:25 PM   #16
CBHomes's Avatar
Trade: Flooring
that's gonna be a b**** to frame around those bad boys, not to mention what RobertCDF said. Have fun : )
CBHomes is offline
Old 06-23-2009, 03:35 PM   #17
PA woodbutcher's Avatar
Another variable involved...how far are you coming out with the deck?...If your not already stretching your joists, framing around can be an option. Trying to flash under an old beat up clap board siding can be a real bear without tearing it up and replacing a bunch of it
When you rob Peter to pay Paul, chances are pretty good you will receive Paul's vote. Apparently the object of the game is to create more Pauls than Peters....What happens when the Peters can no longer support the Pauls? .
PA woodbutcher is offline
Old 06-24-2009, 06:47 PM   #18
General Contractor
greg24k's Avatar
Rewards Points: 7,358
That little step will come right out
greg24k is online now
Old 06-25-2009, 02:40 PM   #19
Panzer5's Avatar
Rewards Points: 254
Thanks for the responses everyone. I'll probably jack it out. It's got some separation between the steps and the house already, so I'll hopefully be able to get it out without damaging the foundation. (fingers crossed!)
Panzer5 is offline
Old 06-25-2009, 02:47 PM   #20
B.K's Avatar
Rewards Points: 75
You sir are god! A homemade tool that ate concrete breakfast, run circles around a jackhammer, and it takes some balls to run it!
To top it off it actually bit back at you! Yes sir, you are god!
You laugh because I'm different...........
I laugh cause I just farted!
B.K is offline
Ipe deck Clemens Decks & Fencing 64 06-20-2017 11:13 PM
Whats The most expensive deck you've built deck king Decks & Fencing 96 07-10-2010 08:02 PM
Slope a deck or a level deck? wallmaxx Decks & Fencing 28 08-13-2009 12:36 AM
24x24 Deck amanandhisvan Decks & Fencing 63 09-24-2008 10:59 PM
Looking for deck and fence builder - Chicago west suburb Green_2 Help Wanted or Looking For Work 0 09-07-2008 05:34 AM
