Top Rail Radius. How Do You Do It??
Old 12-02-2007, 08:18 PM   #1
Blane N.
Dollabill's Avatar
Trade: Fence building, garage door installation
I have been involved in the family fencing business for some time. Just recently my uncle decided to offer the business to my cousin and I, so we are in the process of working into that capacity. Given this opportunity and after finding this forum I have have started to come up with all kinds of questions.
The other day we were installing top rail on a black vinyl chain link job around a retention pond. Part of the fence follows the curve of a culdesac. Now my uncle usually runs the show as to how he wants the fences built and I have no problems doing it his way, but sometimes I have questions. In this case we bent the top rail smoothly to follow the curve of the sidewalk, but after hanging the fabric, one can see that it just doesn't hang right. The fabric tends to bow out at the top due to the fact that the top rail curves but the fabric wants to be in a straight line between posts. This is how we always build radius's and it works, but I was thinking that it may look better to make a positive bend at each line post so that when the fabric is stretched it hangs properly. Let me know what you all think.
Dollabill is offline
Old 12-02-2007, 08:43 PM   #2
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Re: Top Rail Radius. How Do You Do It??
It sounds like a round hole, square peg problem.....you need a round peg or a curved bottom rail....
woodmagman is offline
Old 12-03-2007, 09:55 AM   #3
Carpenter/fencing
nywoodwizard's Avatar
More post and bottom rail
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 12-03-2007, 10:35 AM   #4
Blane N.
Dollabill's Avatar
What do you mean by "more post"? The posts are spaced the usual 10 feet give or take. More posts in the ground would produce a smother curve but I think that bottom rail would produce the same results. Does anyone positively bend the rail at each eye cap? What kind of results have you seen?
Old 12-03-2007, 03:41 PM   #5
Carpenter/fencing
Chain link is just not the ideal fence for small radius's, more post will produce a smother curve . They can be at any center you want, as long as its under 10'. I have done radius jobs before and the best looking one's were when we used vinyl coated pipes to match the chain link color, it made the additional pipe and closer centers look less obvious. It will never produce a perfect radius,but it will look better. Rails are sometimes bent to accommodate slight turns, to an extent before it kinks. The preferred method would be to terminate at multiple intersections.
Old 12-03-2007, 04:27 PM   #6
Charitable animal
Bone Saw's Avatar
Trade: decks
not quite sure if I'm understanding this correctly, but heres my take on it
take a straight piece of stiff wire (straight bottom section of coat hanger) and prop it at both ends with tubes of ky jelly to form a bridge
take another piece of coat hanger (same piece, different hanger) and bend it to form an arc, repeat above procedure, what happened????
more posts
Bone Saw is offline
Old 12-03-2007, 05:52 PM   #7
Carpenter/fencing
more posts
With thoughts like that ,you should not be left alone for long periods of time.
Old 12-04-2007, 09:00 PM   #8
Blane N.
Dollabill's Avatar
We have been doing it as described above for something like fifteen years and the customers have always been pleased with the finish. You know, we are always trying to be better, right?
On another note, how much time does one have to spend on CT to rack up 1,000 posts? That a bunch! I guess my hats just not that white yet. He he.
Old 12-04-2007, 09:01 PM   #9
Blane N.
Dollabill's Avatar
Only eight posts!!! So many posts to make, so little time.
Old 05-07-2008, 08:15 AM   #10
scannon's Avatar
Trade: construction
Unhappy
im in oakpark illnios can someone give me idea on labor for moving a 20' high chain link fence along a narrow street and move it over 10'. it about 110' long and it going threw concrete.
scannon is offline
Old 05-07-2008, 08:19 AM   #11
genecarp's Avatar
o brother
genecarp is offline
Old 05-07-2008, 09:14 AM   #12
Danno6102's Avatar
Trade: Deck Builder
$10,536.68 When do I start?
Danno6102 is offline
Old 05-07-2008, 09:17 AM   #13
BuiltByMAC's Avatar
Trade: Construction
... it going threw concrete.
Here's an idea - hire a contractor. But it better be a burly guy 'cause if that fence is strong enough to throw concrete, it might not want to move!
Mac
BuiltByMAC is offline
Old 05-07-2008, 11:16 PM   #14
Deck Designer/Builder
DecksEtc's Avatar
Mac
Thanks Mac! Reading your post just made Diet Coke come out my nose!
Absolutely classic!!!
DecksEtc is offline
Old 05-07-2008, 11:40 PM   #15
Carpenter/Finisher
john5mt's Avatar
i'll do it for $10,500.68
hire me!
1st Gen tradesman
My summer job in college became my profession
john5mt is offline
Interior rail installation brewsterb Finish Carpentry 6 11-06-2007 10:19 PM
Deck Hand Rail KGB Decks & Fencing 3 07-28-2007 06:39 PM
Cut A radius in a top rail? ecooke21 Decks & Fencing 2 07-25-2007 10:10 PM
radius nosing for balcony timber Flooring 3 07-05-2007 07:28 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
