Top Rail Radius
Old 08-04-2009, 04:11 PM   #1
sorethumbs's Avatar
Trade: carpentry
Top Rail Radius
I'm working on a large but basic, all PT, deck. The top rail is a standard 2x6, and the factory radius edges are still present. I don't like it. I'm wondering what type of radius you guys use.
I really want to put a large radius on it. I have a 3/4" round-over bit and I want to use it. The rail is already installed so I can't use a router table. I'd have to go against the safety warnings run that honking bit in a hand-held router. Is this too risky? Thanks.
sorethumbs is offline
Old 08-04-2009, 04:15 PM   #2
PA woodbutcher's Avatar
Re: Top Rail Radius
No one says you have to take it all in 1 pass.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 08-04-2009, 04:21 PM   #3
sorethumbs's Avatar
Trade: carpentry
Re: Top Rail Radius
Absolutly! and thanks for such a fast response!
I think, and have been taught, that the danger with the large bits comes from the fact that there is a large amount of wood in contact with the bit even when taking small bites. That concerns me. Have you used large bits in a hand-held before?
Old 08-04-2009, 05:33 PM   #4
KemoSabe
loneframer's Avatar
Re: Top Rail Radius
2 1/2" flat bottom/w replaceable cutters. Ran hundreds of feet of 3/16" dadoes with this. Also used to use a 1/2" radius nosing bit in 1 1/2 horse Craftsman router. Use of both hands IS recommended.
loneframer is online now
Old 08-04-2009, 05:41 PM   #5
Meetre's Avatar
Re: Top Rail Radius
3/4 round over isn't too much for a handheld, but like loneframer said, use two hands.
Meetre is offline
Old 08-04-2009, 06:41 PM   #6
John Hyatt
John Hyatt's Avatar
Re: Top Rail Radius
I have used a 1'' round over in a Makita router ran by my very own hands controled by my reckless ways. You gutta be real carefull,make a couple of passes and run it sharp like real sharp get that carbide freashen up before you start. Dont linger in one spot make the runs slow and straight. JonMOn
John Hyatt is offline
Old 08-04-2009, 06:57 PM   #7
I like Green things
WarnerConstInc.'s Avatar
Re: Top Rail Radius
This wouldn't even notice you were doing anything:
http://www.mcfeelys.com/product/5742...OF-2200-Router
WarnerConstInc. is offline
Old 08-04-2009, 07:10 PM   #8
dkillianjr's Avatar
Re: Top Rail Radius
Ya 3/4" should be fine. I've routed some PT before that the bit more or less shot long shards of wood at my legs, so becareful I had little swords stuck all over my pants
dkillianjr is offline
Old 08-04-2009, 07:17 PM   #9
John Hyatt
John Hyatt's Avatar
Re: Top Rail Radius
Warner that is one badass router. Im not real sure all that power would help if the user wasent seasoned in But I like the thing! J.
Old 08-04-2009, 07:36 PM   #10
I like Green things
Re: Top Rail Radius
Its a brute.
You can sit it on a work table/bench, turn it on and walk away from it.
It will sit perfectly still while it is running.
They make some of the most well balanced, smooth running routers.
You guys ever held on tight ans went for a ride on Poter Cable's big beast of a router they made?
Old 08-05-2009, 01:14 AM   #11
deckman22's Avatar
Trade: Deck Builder
Re: Top Rail Radius
I've been using roundover bits on top rails forever, you won't have a problem as long you use sharp bits.
Deckman
www.alscustomdecks.com
deckman22 is offline
Old 08-05-2009, 01:31 AM   #12
Re: Top Rail Radius
Originally Posted by WarnerConstInc. View Post
Its a brute.
And a fine piece of iron
they are.
neolitic is offline
Matching a Radius TakePride General Discussion 15 10-29-2008 07:23 AM
Radius Calculations????? ETConstruction Carpentry 3 09-10-2008 06:43 AM
Top Rail Radius. How do you do it?? Dollabill Decks & Fencing 14 05-07-2008 11:40 PM
Cut A radius in a top rail? ecooke21 Decks & Fencing 2 07-25-2007 10:10 PM
