Time Saver For Post Holes
Old 07-16-2007, 04:45 PM   #1
ConradLumberCo
AndyJones's Avatar
Trade: Supplier
Anybody used this new gadget yet, Oz-Post (www.oz-post.com)? Looks like it will save a lot of time digging holes, pouring conrete, etc. I'm all for working smarter and not harder.
AndyJones is offline
Old 07-16-2007, 05:08 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
Re: Time Saver For Post Holes
Might be okay for temporary posts but not for permanent, won't meet code or load requirments.
mickeyco is offline
Old 07-16-2007, 09:01 PM   #3
Professional Remodeler
firemike's Avatar
Andy, you need to get rid of the "(" and the ")?" in your link, it doesn't work. The correct line is http://www.oz-post.com
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 07-16-2007, 09:48 PM   #4
concretemasonry's Avatar
Trade: Masonry consultant
The best use for the Oz-Post is for anchoring "For Sale" realtor signs that are not there that long, do not have to be straight and can be removed easily.
They have been around for a while, but have really no gotten anwhere in real construction like fences. - No good for a deck.
Dick
concretemasonry is online now
Old 07-16-2007, 09:49 PM   #5
Remodeler
MinConst's Avatar
Looks like it is designed for sign posts etc. Not to replace a deck support. Maybe a temporary fence.
Paul
Minichillo's Construction
Website
I will never leave you hanging!
MinConst is offline
Old 07-16-2007, 10:12 PM   #6
Carpenter/fencing
nywoodwizard's Avatar
Kinda as stupid as the vacuum post digger ,srcatch the dirt with this thing and vacuum sucks out the dirt,then you drop a nut trying to emty the vacuum. i'm still laughing thinking about it.
Bull Digger Fence Post Hole Digger , www.bulldiggeronline.com
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 07-16-2007, 10:19 PM   #7
Mod / ArchiBuilder
Cole's Avatar
Cole is offline
Old 07-16-2007, 11:51 PM   #8
Fentoozler
Celtic's Avatar
Replace?
They think it's the end-all-be-all for decks:
http://www.oz-post.com/html/decking.php
I don't think so
Celtic is offline
Old 07-17-2007, 12:08 AM   #9
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
Notice how they don't come out and say (with any certainty) that the decks in those pictures are supported with their product. What the reader ASSUMES is none of their doing and they certainly can't be held responsible for it.
Don't get caught in the Stone Age digging holes, mixing cement, propping posts and removing unused dirt.
Don't get caught doing things the RIGHT way....heaven forbid.
Jim P.
jproffer is offline
Old 07-17-2007, 02:01 AM   #10
Palisade Point Const.
TempestV's Avatar
It shouldn't take a whole lot of intelligence to figure out that using something that is driven into the ground vertically to carry a vertical load is a bad idea.
I've never used them, so I don't know, but they may be strong laterally, which would make them useful for sign posts and possibly fences, particularly in temporary applications.
TempestV is offline
Old 07-18-2007, 02:31 PM   #11
termite's Avatar
Trade: general building contractor
used thousands of these on many different jobs. best thing to come along in regards to fencing since redi mix concrete in a bag. i've had them stay up in gail force winds without a failure. don't knock it til you've tried it.
termite is offline
Old 07-18-2007, 03:12 PM   #12
RobertCDF's Avatar
Trade: Custom deck builder
Wont work for a deck I know that... Maybe a fence post.
RobertCDF is online now
Old 07-18-2007, 03:51 PM   #13
Sprinkler Guy since birth
sprinklerguy's Avatar
Trade: Lawn Sprinkler/Fence Contractor
I wouldn't use it on any fence I built.....
First post and he is a big fan eh? Hmmmmm
Tony Neumann
Lawn Sprinkler Repair and Irrigation Installation
Colorado Springs, Colorado
http://www.sprinklersolutions.com
sprinklerguy is offline
Old 07-18-2007, 04:02 PM   #14
RYANINMICHIGAN's Avatar
Trade: builder of stuff, real nice stuff
In a word, JUNK
RYANINMICHIGAN is offline
Old 07-19-2007, 11:30 AM   #15
ConradLumberCo
AndyJones's Avatar
Trade: Supplier
Not quite the response I was expecting. I haven't used this oz post myself, but I was thinking there would be a little more enthusiasm from the group. No digging post holes, no augers, no cement, and from I have read it says it meets all building code requirements (along with the usual fine print bs from the lawyers). Looks pretty impressive if you watch the videos on the website.
Old 07-21-2007, 08:59 AM   #16
General Contracting
LNG24's Avatar
Trade: Real Estate Broker, Property Manager
Andy,
From an Engineering standpoint, It can not work. Pouring Cement into a hole is not that simple. We are creating a Footing 42" below ground(or what ever your areas frost line is) that will be capable of carrying the load above it. The bottom of that hole needs to be level and solid. No Loose Dirt. In many areas that are now requiring a larger foot at the bottom as well.
Hammering a post into the ground that is spear shaped will not be capable of supporting a load. You can hammer a flat bottom post into the ground until refusal at a certian pre determined PSI which is calculated based on soil testing, but this is far more costly and requires heavy equipment.
So we are NOT against this for installing a sign or a temporary fence, but to support a permanent structure of any type...YES this product would be a No No regardless of how they want to spin it.
LNG24 is offline
Old 07-21-2007, 09:50 AM   #17
Fentoozler
Celtic's Avatar
Sorry...but you got brutal honesty from the folks here .
That's the best you can hope for.
Celtic is offline
Old 07-21-2007, 08:03 PM   #18
bcf's Avatar
Trade: Fence Contractor
I think it looks like a great idea!
But then again, most things that look too good to be true are.
Looks to be about as stable as making a cross of 6' 2x4s nailed to the bottom of your post sitting on the ground.
Now maybe if we installed a big spring to fight against wind knockover...
Matt Ehrenzeller-General Manager
A Great Divide Fence Company
www.agreatdividefence.com
bcf is offline
Old 07-23-2007, 02:47 PM   #19
ConradLumberCo
AndyJones's Avatar
Trade: Supplier
If you comb over thier website it provides all the test data you would need concerning resistance to wind and the strenght of the in ground post. For a typical post application the oz post has tested to be just as strong as a concrete setting, ans has tested out to 120 mph wind resistance (at which point the wood post breaks). My point of veiw is hey, if this meets code (which they say it does) than great, I just saved myself a day on the job. If not, I dont use it and no skin off my back. Wish we could find someone out there who has actually used this.
Old 07-23-2007, 02:47 PM   #20
ConradLumberCo
AndyJones's Avatar
Trade: Supplier
Oh, and i appreciate the honesty. Always nice to have differing opinions.
Filling Small Holes in Vinyl Siding slickshift Windows, Siding and Doors 9 07-05-2008 09:33 PM
can't get letters of time can'tfindit Electrical 21 05-19-2007 02:27 PM
Finding Time Sparky Joe General Discussion 20 11-23-2006 12:47 PM
Quickbooks Time Tracker Debookkeeper General Discussion 2 10-27-2006 09:09 PM
