These DIY Sites Keep Getting Better
Old 09-01-2008, 09:50 PM   #1
Dan_Watson's Avatar
Found this on another DIY site...Im speechless and wouldnt even know where to begin !
Hopefully Ed doesnt think im posting this one for actual help.
EDIT!!! here is what was posted:
I would like to build a deck platform for an inflatable pool. The deck would be about 12" above the ground. The pool is 9' x 18' x 52". My calculations indicate that this would weigh about 42,000 lbs which would mean that I would need to support about 260 lbs per square foot. I know the standard is about 40 lbs/sqft. First, a concrete slab is not an option. I thought about making concrete piers 10" diameter about 6" above ground and 2' apart. Then mount 6'x6' treated beams across the piers. Then tie in 4'x4's perpendicular to the beams at 12" OC. then lay 5/4 x 6 decking on them. So, I'm looking for any other means of supporting this kind of weight. I really would like a deck option, but am open to any other ideas.
Dan_Watson is offline
Old 09-01-2008, 09:51 PM   #2
Celtic's #1 Fan
mahlere's Avatar
Trade: electrical
Re: These DIY Sites Keep Getting Better
apparently you aren't lying about not knowing where to begin....how about by posting the link?
mahlere is offline
Old 09-01-2008, 10:16 PM   #3
Dan_Watson's Avatar
I guess I forgot to paste it...
Old 09-01-2008, 10:19 PM   #4
Tom R's Avatar
http://www.bobvila.com/BBS/Deck_load...o-1-T1504.html
Tom R is offline
Old 09-01-2008, 10:21 PM   #5
Dan_Watson's Avatar
Thats not even where I found it...Guess hes looking for alot of help
Old 09-01-2008, 11:03 PM   #6
Deck Designer/Builder
DecksEtc's Avatar
I guess he's never heard of the um, ground!
DecksEtc is offline
Old 09-01-2008, 11:23 PM   #7
Dan_Watson's Avatar
That liner would be destroyed from putting it on lumber, not to mention one hell of a wierd feeling on the bottom of your feet.
Old 09-02-2008, 11:35 PM   #8
Palisade Point Const.
TempestV's Avatar
is this where you found it?
http://www.decks.com/Topic5357-21-1.aspx
I like his response where he says that he didn't want to level the ground in order to put the pool out, so he thought this solution would be easier!
TempestV is offline
any other sites like bid clerk to bid on jobs? volsball General Discussion 1 09-17-2007 05:46 PM
our screen names in other's sites?? dougchips Marketing & Sales 5 03-25-2007 10:21 PM
are web sites worth the money wdwrkr75 Carpentry 7 10-02-2006 08:52 PM
