Surfing Soffit Dilemma
Old 10-25-2008, 11:36 PM   #1
smadax's Avatar
Trade: CONTRACTOR
We installed 10' lengths of vinyl soffit under the ceiling of a deck. The soffit waved quite badly and we removed it and placed additional bracing every 2-3 feet for screws... but it's still slightly wavy.
Is there anything we can do to make them lay straight, opposed to shortening the lengths and running another strip of J in the middle??
smadax is offline
Old 10-26-2008, 08:23 AM   #2
PA woodbutcher's Avatar
Re: Surfing Soffit Dilemma
I would use 2' as a maximim. It is only vinyl. If not exposed to rain water you can use roofing nails up, but if it is use aluminum siding nails. Don't nail it too tight or you will end up with waves anyways when it expands and contracts with the temps. If you have a high ceiling joist you can float the soffit on the nail also. How much wind in the area?
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline
Old 10-26-2008, 03:03 PM   #3
smadax's Avatar
Trade: CONTRACTOR
Hm, they attached the soffit with screws.... I'm willing to bet they didn't leave room for contraction. The area is not in direct wind, protected with trees.
smadax is offline
Old 10-26-2008, 05:01 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Dont use vynal.
WarnerConstInc. is online now
Old 10-26-2008, 05:13 PM   #5
smadax's Avatar
Trade: CONTRACTOR
At all, or just for these lengths?
smadax is offline
Old 10-26-2008, 06:35 PM   #6
I like Green things
For long lengths, unless you put up a bunch of strapping so you nail the piss out of it, nailed loose though.
I have never had much luck with vinyl with anything over a 2' span.
Old 10-27-2008, 12:57 PM   #7
smadax's Avatar
Trade: CONTRACTOR
Good to know, thanks.
smadax is offline
Old 12-02-2008, 02:18 PM   #8
member
Jer's Avatar
Trade: Siding, windows, Aluminum crown
Aluminum soffit is a much better product for longer overhangs (36" or longer)
Jer is offline
Old 12-02-2008, 02:58 PM   #9
Meetre's Avatar
how wavy is the framing? if it's off, you may need to shim it all to one plane. oh, don't use vinyl, the stuff was made to wave, just the nature of the beast.
Meetre is offline
Old 12-06-2008, 08:57 AM   #10
AtlanticWBConst's Avatar
If the framing is not straight, even the alumnium will be wavy as well, not to mention that the you need to ventilate the soffits,
- Build Well -
AtlanticWBConst is offline
Old 12-08-2008, 01:07 AM   #11
builderr's Avatar
Send a message via Yahoo to builderr
I found a panel from alside that I think might be a charter oak..vented soffit panel...was very rigid.
worked good for me on a 10 ft farmers porch
David
builderr is offline
Vinyl soffit span... what backing OC? bobaganoosh Windows, Siding and Doors 11 12-24-2008 12:41 AM
Whistle Blowing dilemma EC Dev General Discussion 19 09-22-2008 01:43 AM
Consulting Dilemma buckleyclan General Discussion 8 09-19-2008 02:22 PM
Soffit Layout eoffmasonry Framing 8 08-28-2008 11:19 AM
Aluminum soffit estimate? K_Tile Windows, Siding and Doors 24 07-25-2008 11:56 AM
