Surface Mounted Posts
Old 04-06-2011, 07:00 PM   #1
alboston's Avatar
Rewards Points: 672
Anyone use those surface mounted posts for a railing system? Azek calls them Tallboys and Trex has there own version. I am re-decking over a rubber roof (the railing portion is over a patio) and the current span of railing is 27' and only has 1 post in the middle. Obviously I need to add more posts. Just curious if anyone had use these surface mount posts. The rim joist is a triple 2x8. Thanks.
alboston is offline
Old 04-07-2011, 08:30 AM   #2
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Rewards Points: 1,000
Re: Surface Mounted Posts
We've used several. Most seem pretty similar.
Flashing is going to be your biggest concern- we had 1 of our guys work WITH the roofers to make sure everyone was satisfied with the outcome...
Don't have a progress shot, but here's the project I'm referencing.
~Matt
BreyerConstruct is offline
The Following User Says Thank You to BreyerConstruct For This Useful Post:
alboston (04-07-2011)
Old 04-07-2011, 09:01 AM   #3
ZamWeld
ZamWeld's Avatar
Trade: welder
A company named MAC POST can help you with that
ZamWeld is offline
The Following User Says Thank You to ZamWeld For This Useful Post:
Old 04-17-2011, 05:42 AM   #4
RRRSTAIR's Avatar
Trade: Design & build stairs and railings for 30 years
Thumbs up
There is a product line of wood railing hardware we have been using for several years. Most of our work is inside but we surface mount all of our wood posts with the Spring-Bolt Post to Deck kit. The hardware has passed residential and commercial load tests. They make hardware for outside use. Some of the kits are made of stainless steel.
RRRSTAIR is offline
Old 04-17-2011, 09:43 AM   #5
Sawdust Sweeper
carpentershane's Avatar
Rewards Points: 28
http://www.ideas-for-deck-designs.co...st-anchor.html
Titan post anchor is not a bad choice for post anchors (run your post sleeves over the wood posts and voila.)Bases are a little expensive per post.
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
rotted deck posts jhcontracting Decks & Fencing 17 04-05-2010 06:08 PM
How To - Finding New Posts Nathan Contractor Talk Tutorials - How To Use This Site 12 05-08-2008 11:59 PM
FEEDBACK: ContractorTalk.com Posts in a Free Trade Magazine Nathan General Discussion 71 04-21-2006 06:39 AM
