Surface Mounted Posts
Old 10-29-2007, 05:22 PM   #1
Carpenter
RizzoMaryland's Avatar
Anyone have any experience or knowledge with these surface mounted railing posts for decks? They use 2 mounting plates to sandwich the decking material in order to fasten the railing post to the decking material. I'm concerned with how sturdy can this be. How much lateral "strength" does this design have?
I saw the style Cheapo carries called Yardsmart or www.usfenceonline.com
"An idea is salvation by imagination"
Frank LLoyd Wright
RizzoMaryland is offline
Old 10-29-2007, 05:51 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Surface Mounted Posts
Does the harsware stand up to the treated lumber?
Does it have any code approvals?
- The site is very vague.
Dick
concretemasonry is offline
Old 10-29-2007, 07:50 PM   #3
Charitable animal
Bone Saw's Avatar
Trade: decks
yardsmart is lowes crap, anyway nothing wrong with flange mounted posts, however I would ditch the sandwhich concept and do 6x6 blocking between bays where needed and use ledgerlocks. I have done this many times and is my perfered method for installing a "kit" rail post, easy to maintain continuity in offset around miters and corners. Only drawback I would have to say is it takes quite a bit of finness to get everyting plumb yet fastened down tight.
Bone Saw is offline
Old 10-30-2007, 07:39 AM   #4
Carpenter
Bone Saw,
What are ledger locks? Not familiar with that terminology. Also, with the kits you have installed, you haven't had any lateral movement (or cheap feeling) when leaning on the railing?
Thanks in advance
Frank LLoyd Wright
Old 10-30-2007, 09:20 AM   #5
Charitable animal
Bone Saw's Avatar
Trade: decks
Originally Posted by RizzoMaryland View Post
Bone Saw,
http://www.fastenmaster.com/product....tID=8&prodID=9
no, for a flange mount to work it must be fastened down TIGHT and that is the reason I use the ledgerlocks they have a much more aggressive thread/shank diameter ratio that anything out there, I just use em for everything,
Bone Saw is offline
Old 10-30-2007, 09:43 AM   #6
They are aces for LVL's too!
"Spax" has something like, in a wider variety we use a lot. Rated for PT, and go right into concrete, like tapcons.
neolitic is offline
Old 11-01-2007, 08:56 PM   #7
Carpenter/fencing
nywoodwizard's Avatar
For longevity surface mounting any type of post i would not recomend. The best way to install pvc railings in decks is to box in some cca post and sleeve the pvc post over them.Same with a trex style railing.The only other post support method i would use would be bufftecks post supports.
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
How To - Finding New Posts Nathan Contractor Talk Tutorials - How To Use This Site 12 05-09-2008 12:59 AM
best way to paint interior decorative posts? Zeebo Painting & Finish Work 7 08-24-2006 09:35 PM
FEEDBACK: ContractorTalk.com Posts in a Free Trade Magazine Nathan General Discussion 71 04-21-2006 07:39 AM
