Stringer Techniques?
Old 08-22-2008, 05:20 PM   #1
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
I can't believe in all the years of building I have never had to do this and now I'm stuck!
I have a set of wrap around steps to an upper level deck that has two 45 deg angles (going up on an inside corner). I was pulling my hair out today trying to figure out how to get them cut!!!
Looking for some help on this one, the way I was going to go about it would take a while and I know there must be an easier way.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 08-22-2008, 05:43 PM   #2
Restoration Crazy
Re: Stringer Techniques?
Just to clarify, it's the 22.5 deg. stringers I'm having difficulty with. The ideas me and the guys were coming up with seemed like a clunky way of going about it.
I'll scan in a drawing shortly.
Facebook | Twitter
Old 08-22-2008, 05:45 PM   #3
DavidC
DavidC's Avatar
Boy a pic or sketch would help here. Is there a platform landing at the turns?
Good Luck
www.CookContractingLLC.com
DavidC is online now
Old 08-22-2008, 05:46 PM   #4
Dan_Watson's Avatar
Pictures
Dan_Watson is offline
Old 08-22-2008, 06:12 PM   #5
Restoration Crazy
OK here is one of the sketches.
My plan is to have a full stringer on each side of the 22.5's but how do I get the points to cut them? I know I need to cut the riser portion at 22.5 but it's the length of the tread that is throwing me off
There must be a mathimatical way of doing this.
Geezus!!!!!
I can't download a tiff; give me a minute!
Facebook | Twitter
Old 08-22-2008, 06:40 PM   #6
orson's Avatar
Trade: Kitchen & Bath
Waiting for the pics, but remember...
Take a deep breath....let it out slowly.....
There is a solution, you will master it, and at the end you will stand back and wonder why you were so worried.
Breathe.
orson is offline
Old 08-22-2008, 06:45 PM   #7
Restoration Crazy
Got it (I think)
Facebook | Twitter
Old 08-22-2008, 06:52 PM   #8
orson's Avatar
The depth of the tread cut on the stringer is going to be Square route of [2 x (depth of the tread squared)] minus [2x (depth of the overhang of tread squared)]
A squared + B squared= C squared
A and B are both the same, the depth of the tread so C is the length of the mitre, but you have to subtract the overhang of the tread.
Is that what you were looking for?
orson is offline
Old 08-22-2008, 07:06 PM   #9
DavidC
DavidC's Avatar
Now I see. I would go a double stringer on each corner, with the risers cut back to match the angle of the deck. Probably easier in the long run than a compound cut on one stringer and gives you more support under the tread anyway.
I hope you get what I mean. I sometimes have trouble posting with just text.
Good Luck
Old 08-22-2008, 07:10 PM   #10
Restoration Crazy
The stringers that are on an angle have to have a longer run and the tread as well in order to make the turn. The straight stingers are no problem, it's just the inside corner stringers I can't figure out.
Facebook | Twitter
Old 08-22-2008, 07:12 PM   #11
Restoration Crazy
Good Luck
Exactly what I want to do, just getting the cut points is throwing me for a curve
Facebook | Twitter
Old 08-22-2008, 07:25 PM   #12
Pro Deck Guy
Ahren's Avatar
Trade: Jim's free government helper
Take whatever you're using as a tread, cut it at 22.5. Measure. There's your length. Subtract for nosing, riser.
Ahren is offline
Old 08-22-2008, 07:26 PM   #13
Meetre's Avatar
string line, levels? put something across the other stringers that will cross points and let you see where it needs to be. then, make that peice.
Meetre is offline
Old 08-22-2008, 07:26 PM   #14
Meetre's Avatar
or what Ahren said
Meetre is offline
Old 08-22-2008, 07:34 PM   #15
Restoration Crazy
awsome idea!
Thanks Ahren!
Facebook | Twitter
Old 08-22-2008, 07:49 PM   #16
Pro Deck Guy
Ahren's Avatar
Originally Posted by Jason W View Post
awsome idea!
Thanks Ahren!
No problema.
I should add:
When you subtract for your nosing & riser, hook your tape on the edge of the board and come straight back to the angled end of the board. Don't hook the long point of the angle and come down the angle. Does that make sense?
Ahren is offline
Old 08-22-2008, 07:57 PM   #17
Restoration Crazy
Perfectly
Facebook | Twitter
Old 08-22-2008, 08:02 PM   #18
After you get them cut,stick a 2X6
between the left hand and right hand
sides to beef them up...their gonna look
weird and scrawny.
That will also let you screw the tread
farther back from the joint.
neolitic is offline
Old 08-22-2008, 08:49 PM   #19
orson's Avatar
My post was for a 45deg mitre which you probably already noticed
Since I'm a glutton for punishment(not really cuz I didn't get any yet) but more because I love math(I know, it's sick) here's how you would find the stringer tread cut depth using trig, in the example the regular stringer depth is 6 inches:
orson is offline
Old 08-23-2008, 10:32 AM   #20
Danno6102's Avatar
Trade: Deck Builder
A good CAD program is your friend. when you have something funky, sit down & take a couple hours to draw it up & dimension the crap out of it. Print out the drawing & cut it on site. I do this all the time. It eliminates those "been a long day" miscalculations which I have a habit of making, even first thing in the morning .
Dan
Danno6102 is offline
Useful Techniques from Other Countries Journeyman T General Discussion 1 03-05-2008 08:03 PM
Milling Machine Techniques BlackGold Concrete & Paving 1 09-08-2007 04:17 PM
Share your techniques for access panels in finished ceilings and walls Dustball Carpentry 9 07-14-2007 08:27 PM
Misc. Techniques BlackGold Concrete & Paving 4 06-15-2007 10:41 PM
OSB hangerboard for stair stringer? Spencer Carpentry 26 04-05-2006 07:58 AM
