Stain Storage
Old 01-11-2017, 04:07 PM   #1
Macmini's Avatar
Trade: Handyman/unlicensed
Rewards Points: 130
Stain Storage
I've got few hundred bucks if silkens srd are to store for a few years if possible. My previous attempts at ling term storage lead to disaster and it dried despite sealing the can and taping the edges. So I hoping instead of buying oxygen removal packets and such I was planning on adding mineral spirits to top off the barrels. I only need to add 1/2 gallon to the 4 gallon buckets. What do you all think. It would be an easy way to out a few hundred in my pocket
Macmini is offline
Old 01-11-2017, 05:41 PM   #2
John Hyatt
John Hyatt's Avatar
Rewards Points: 3,910
Re: Stain Storage
Big zip lock bags doubled up. If they are one gal cans.
How did you end up with that much finish in need or storage ?
J.
John Hyatt is offline
Old 01-11-2017, 05:45 PM   #3
Macmini's Avatar
Rewards Points: 130
Re: Stain Storage
It was cheaper to order that way I'll give the bags a shot. I was hoping to save it and in 2 years re-stain the decks I built
Macmini is offline
Old 01-11-2017, 06:02 PM   #4
John Hyatt
John Hyatt's Avatar
Re: Stain Storage
Two years shelf life is asking a lot. Just sitting there will solidify the compound.
Worth a try I guess.
J.
Old 01-11-2017, 06:58 PM   #5
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 494
Re: Stain Storage
J.
I just opened up a can of TWP that is probably 18 months old and other than having to mix with a paint paddle longer than normal, it was fine. I just held on to it for a "what the hell" type of test/purpose. I needed a little extra rustic and it is just like the other couple gallons I recently had shipped.
I did store it where I do my finishes which is in a cabinet inside a separate area and mostly closed off from anything else in the shop. I think the less air flow... The better.
Never liked sikkens much though, toss it for TWP, Ipe Oil, or Messmer's, those are the best exterior finishes I've used. TWP is the most impressive for the price.
He knows nothing about everything and isn't afraid to prove it, so he defends ignorance with stupidity.
Deckhead is online now
Old 01-11-2017, 07:03 PM   #6
avenge's Avatar
Rewards Points: 2,562
Re: Stain Storage
It won't do crap to stop the settling and hardening of any pigment. Doesn't make much sense to buy that much quantity to save and then have it go bad.
I depends on the type of stain as to how long it will stay usable after opening.
avenge is offline
Old 01-11-2017, 07:50 PM   #7
Macmini's Avatar
Rewards Points: 130
Re: Stain Storage
Sounds good, I'll give it a shot. If it fails no loss on my part
Macmini is offline
Old 01-12-2017, 06:48 PM   #8
MonsieurBon's Avatar
Trade: Framing and finish carpentry
Rewards Points: 200
Re: Stain Storage
My paint supplier says to store cans and buckets of finishes upside down and they will last much longer. He says the finish seals without leaking out. I'm cautious but trying it on a couple cans.
Sent from my Moto G (4) using Tapatalk
MonsieurBon is offline
Paint or Solid color stain? kenmorgen Painting & Finish Work 8 04-27-2013 01:03 AM
spraying stain on unfinished alder window frames girlspaint2 Painting & Finish Work 19 02-02-2013 10:45 PM
dewalt tough system storage solution Rich D. Tools & Equipment 39 08-01-2012 02:11 PM
Why is wood rotting ? SKC Construction 44 07-23-2012 03:06 AM
Fence stain Rslstructures Construction 3 06-23-2012 12:13 AM
