Trade: Kitchen & Bath
SS Ledger Brackets, Real Or Fantasy?
I seem to remember seeing a product that you fasten to the wall of a house and then fasten the ledger board to these marine grade stainless steel brackets.
Is this another one of my delusions or do these exist?
Trade: Carpentry Contractor
Re: SS Ledger Brackets, Real Or Fantasy?
Yes, they exist. I saw them last weekend at a lumberyard. I'm sorry but the name escapes me.
They were shaped like a hook, one bolt or lag into the wall and then one through the ledger. The ledger sits in the hook and is offset from the wall by a small amount. They were quite costly and I was a little concerned about their stability. The were also marketed as protection from intruders. A bracket each side of a door, with a 2x4 set in them. |
Trade: Green Products, Energy Auditing and Services
Do search on Maine Deck Brackets deckbrackets dot com
Trade: Squirrel Handler
Maine Deck Bracket, it's aluminum, not SS.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
That's the one I've been looking for!
http://www.contractortalk.com/showth...843#post400843
Thanks for the help guys.
The hangers are $23 a pop plus s&h on their website. The application here is to mount the ledger to vertical t&g wood siding. My thought was to mount the hanger against the siding and use ledger locks to fasten the brackets into the rim joist of the house, fastening into the end of the existing floor joists as well. The footprint of those brackets is a bit clunkier than what I was picturing in my head. It looks like they're running a bracket about every 4.5 to 5 feet in their example photos? I like how they caulk around the bare unpainted wood with silicone, that'll look really nice painted... ![]() I have no access to the framing inside to through-bolt anything. After seeing those thick wall stand offs I'm thinking they may work better. Do you guys see an issue with using them with ledger locks instead of carriage bolts? |
#7 | |
Yeah, I've seen them here in a few stores. Word of caution, they're alumiunum. The higher copper content in the new PT corrodes aluminum quickly. I would caution using these at all.
This is from their site: Quote:
If you correct your mind, the rest of your life will fall into place ~Lao Tzu Custom Cabinetry - Portland, Cape Elizabeth, Scarborough, Kennebunkport, Yarmouth, Falmouth, Cumberland, Ogunquit, Maine Salmon Falls Cabinetry Last edited by KentWhitten; 09-26-2008 at 04:44 PM. |
#8 | |
Re: SS Ledger Brackets, Real Or Fantasy?Quote:
look at the tags on your treated lumber. While I don't think it applies to fir, a very large percentage of TYP is now micronized copper not ACQ. The chemicals are different, the rules are different. The new stuff is less corrosive, and is approved for aluminum flashing. Like the ACQ roll out, you have to look for yourself to know which you're getting. As of now I have to special order ACQ, other than two yards who carry very few 2X's in it and those are all 16' 2X6 at one, and only 2X6 and 2X8 18' and over at the other. I'm talking about all local lumber yards not just the boxes. Surely this isn't the only market where this is happening. YES, I said it has nothing to do with FIR! Apparently the process doesn't work for fir.
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 09-26-2008 at 05:18 PM. |
Just for your info. The deck bracket that I saw was not the Maine deck bracket. This one was actually probably hot dipped galvanized. It was much smaller then the maine bracket and actually had a U shaped bracket, that the ledger sat in.
| ledger for pergola question | soupdizzle | Decks & Fencing | 20 | 08-30-2008 11:30 PM |
| The Real reward for me,priceless | threaderman | Plumbing | 14 | 08-21-2008 12:21 PM |
| Real Estate Investment (Mad Money) | LNG24 | Business | 0 | 02-03-2008 10:21 AM |
| Rubber membrane behind ledger on stucco? | Woodcrafter74 | Decks & Fencing | 6 | 01-31-2006 08:27 PM |
