Squaring A Deck
Old 12-30-2017, 07:44 PM   #1
Loosecannon's Avatar
Trade: Handyman
Squaring A Deck
This deck is whipping me when I check the diagonal it's showing 5/8 out
When I check length and width it's showing over three inches for the life of me I can't figure out what I'm missing
Loosecannon is offline
Old 12-30-2017, 07:49 PM   #2
Pro something
M.F Custom's Avatar
Trade: Construction
Rewards Points: 384
Re: Squaring A Deck
Experience...
M.F Custom is offline
Old 12-30-2017, 11:18 PM   #3
duburban's Avatar
Trade: building
Rewards Points: 1,294
Re: Squaring A Deck
photo?
there must be more to this?
duburban is offline
Old 12-31-2017, 12:06 AM   #4
avenge's Avatar
Rewards Points: 2,790
Re: Squaring A Deck
A professional?
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
NJGC (01-01-2018), Unger.const (12-31-2017)
Old 12-31-2017, 12:12 AM   #5
back doors to hell put in
Irishslave's Avatar
Rewards Points: 352
Re: Squaring A Deck
You maybe building against something that is not square. This can throw you off. Check all of your right angles with the 3-4-5 method or multiples there of 6-8-10, 12-16-20
If that won't work take your carpenters square pick a number on the body, then pick a number on the tongue measure diagonally between these two numbers....now substitute those inch numbers for feet when you measure the deck framing. This works whenever you can't use 3-4-5 multiples for what ever reason.
If your corners are all square then the structure you are attaching to is out which will make one side longer than the other throwing your "X" off
Make sense?
"An argument against democracy,” an astute observer once said, “is to spend five minutes with the average voter.”
Irishslave is offline
The Following 5 Users Say Thank You to Irishslave For This Useful Post:
deckman22 (12-31-2017), Jaws (01-01-2018), Rio (12-31-2017), shanewreckd (12-31-2017), Unger.const (12-31-2017)
Old 12-31-2017, 12:23 AM   #6
Irishslave's Avatar
Rewards Points: 352
Re: Squaring A Deck
If you don't know how to square a deck maybe you shouldn't be building one
The Following 2 Users Say Thank You to Irishslave For This Useful Post:
heavy_d (12-31-2017), NJGC (01-01-2018)
Old 12-31-2017, 12:37 AM   #7
GC/carpenter
Californiadecks's Avatar
Rewards Points: 8,380
Re: Squaring A Deck
Plug the measurements into a construction Master Calculator and push diagonal.
Easy peasy!!!
Mike.
_______________
Californiadecks is offline
The Following 3 Users Say Thank You to Californiadecks For This Useful Post:
BattleBornNV (01-01-2018), Bull Trout (01-02-2018), Snobnd (01-01-2018)
Old 12-31-2017, 12:54 AM   #8
Irishslave's Avatar
Rewards Points: 352
Re: Squaring A Deck
Easy peasy!!!
Mike.
_______________
I've had 2 of those things....both of them quit working even had one of those "scientific" ones...don't know what happened to it
I can still get you to planet Mars and back with a framing square
The Following User Says Thank You to Irishslave For This Useful Post:
M.F Custom (12-31-2017)
Old 12-31-2017, 01:32 AM   #9
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,397
Re: Squaring A Deck
Easy peasy!!!
Mike.
_______________
Someone should tell Elon Musk. He doesn’t need engineers and super computers he just needs a room full experienced carpenters/deck builders.
WBailey1041 is offline
The Following User Says Thank You to WBailey1041 For This Useful Post:
Irishslave (12-31-2017)
Old 12-31-2017, 01:42 AM   #10
GC/carpenter
Re: Squaring A Deck
We had to answer the right angle formula (hypotenuse) on the contractors license test.
Mike.
_______________
Old 12-31-2017, 08:34 AM   #11
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
Re: Squaring A Deck
After a lot of searching( 2-3 seconds) I found this ! It's called Google.
https://www.google.com/search?q=how+...hrome&ie=UTF-8
kirkdc is offline
Old 12-31-2017, 10:25 AM   #12
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,492
Re: Squaring A Deck
I think the formula for pi (3.14592..) has something to do with it.
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
The Following User Says Thank You to heavy_d For This Useful Post:
Fouthgeneration (01-01-2018)
Old 12-31-2017, 11:04 AM   #13
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,302
Re: Squaring A Deck
Before I was a contractor I hired a crew to form a garage slab. Was that you?
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Californiadecks (12-31-2017), hdavis (12-31-2017)
Old 12-31-2017, 11:23 AM   #14
Tom M's Avatar
Rewards Points: 6,414
Re: Squaring A Deck
Sometimes if your base plate of your saw is not a true 90 in your cuts are angled then the boxyard building will want to pull out of square.
That's the easy to find out.
But the real problem is something different when the structure you are adding two is out of square.
Last month I built a portico over a front set of stairs. The existing foyer bumped out 7 ft then the stairs bumped out another 5 6 ft all built on a trapezoid. When I started squaring up my columns in my frame it kept pulling me out of square until I ultimately figured out what it was.
Tom M is online now
Old 12-31-2017, 11:59 AM   #15
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,116
Re: Squaring A Deck
Sometimes you guys are a bit much to take.
O.K., so his question is hard to understand. We are not all William Shakespear, but I got enough from the OP to understand that he does know about checking the diagonal lengths both ways as he said that the deck is 5/8" out on the diagonal.
The part I am having a problem with is that he mentions the "length and width" is "showing over three inches". I simply don't know what that means. If he could explain further what he means we could then help.
After all, that is what this site is for, right? At least partially that is what it is for.
You guys really jumped in his *hit.
Andy.
ScipioAfricanus is offline
The Following 9 Users Say Thank You to ScipioAfricanus For This Useful Post:
Bull Trout (01-02-2018), Bummie (12-31-2017), Californiadecks (12-31-2017), deckman22 (12-31-2017), Defenestrate (12-31-2017), Jaws (01-01-2018), m2akita (01-01-2018), rrk (12-31-2017), SmallTownGuy (12-31-2017)
Old 12-31-2017, 12:36 PM   #16
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,408
Re: Squaring A Deck
Andy.
I thought he had a 3”x3” deck that’s 5/8” out of square.
Big Johnson is online now
B.Johnson (01-01-2018)
Old 12-31-2017, 12:38 PM   #17
kirkdc's Avatar
Re: Squaring A Deck
Andy.
I don't know what he's talking about either regarding the 3 inch thing. I guess many of us (including me who is fairly new) get a tad snarky when a brand new poster pops in here with a really basic question that can easily be rectified by so many other means, other than signing up here and saying you're some sort of contractor. plumber, handyman, milkman, etc
He's building a box. It ain't square. Anyone remotely in the trade OR NOT in the trade should be able to find a solution (websites, books, youtube, talk to friends, etc)
kirkdc is offline
Old 12-31-2017, 12:49 PM   #18
Irishslave's Avatar
Rewards Points: 352
Re: Squaring A Deck
Mike.
_______________
Oh chit, Trig on the license test? I'd flunk then
I know square is 3-4-5 and I know the sum of all angles in any triangle is 180 degrees beyond that without a framing square I'm screwed, that's how I learned even Marshall Gross's book is above my pay grade
Old 12-31-2017, 12:55 PM   #19
tjbnwi's Avatar
Rewards Points: 3,416
Re: Squaring A Deck
Pythagorean for unequal side length squares (rectangles).
Square root of two for equal side length squares (1.414 times a side length).
tjbnwi is offline
Old 12-31-2017, 12:59 PM   #20
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Re: Squaring A Deck
It was a joke Tom
heavy_d is offline
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
Roof top Deck issue mandaloril Decks & Fencing 22 04-24-2012 10:19 PM
