Spindles
Old 07-24-2005, 07:11 PM   #1
orionkf's Avatar
Trade: Hardscape
Spindles
What is the standard way of installing spindles? Do people build the complete section on the ground, and then install, similar to platform framing? Or do they install the 2x4s, then install the spindles?
orionkf is offline
Old 07-24-2005, 07:29 PM   #2
wickedcarpenter's Avatar
Re: Spindles
The 2x4's can be ran inbetween posts or on the outside of the posts. I always screw the spindles on after the 2x is up so their plumb.
I'll pre drill the screw holes and start the screws on the ground, then use a 3 1/2 or 4" block to space the top of the spindles to screw to the railing. Same thing on the bottom but I'll use a level very often to make sure they are plumb as spindles are some times thicker at one end or bowed.
Brent.
wickedcarpenter is offline
Old 07-24-2005, 09:59 PM   #3
Tom R's Avatar
Re: Spindles
It's best to 'crown' your spindles, - - either way, - - all toward the deck, - - or all toward the yard, - - as long as they're not crowned to either side.
http://www.tr-built.com
Tom R is offline
Old 07-25-2005, 06:00 AM   #4
Custom Builder
Glasshousebltr's Avatar
Re: Spindles
I do it both ways, on the ground/deck if I set the poles (cause I know the're plumb), In the air if it's a retrofit to existing.
Just seems easier.
Bob
Bob
Glasshousebltr is offline
Painting Limestone Rails & Spindles plazaman Painting & Finish Work 6 07-01-2011 05:58 AM
Just make it fit! WNYcarpenter Finish Carpentry 36 06-19-2007 10:29 PM
round rails and spindles Joewho Painting & Finish Work 10 09-28-2006 10:09 PM
Need some tips bigchaz Decks & Fencing 8 07-27-2006 11:16 AM
Spindle Spacing ouch! Carpentry 39 08-20-2005 12:00 PM
