Span For 2 X 4's?
Old 06-15-2009, 08:40 AM   #1
Chris G's Avatar
Trade: Porch and Deck Builder
Span For 2 X 4's?
I'm building a ground level deck with 2 x 4 joists supported by adjustable post bases, (Bison's). I can't use a thicker joist because of door threshold clearance.
The AMC span table table gives me about a 5 - 6 foot span for a 2 x 4, (depending on species/live load numbers). Honestly, that sounds like a trampoline to me. Sure it may not snap, but it will be bouncy as all hell.
What would you span a 2 x 4 to? I can't see getting much more than 2 feet.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!"
http://www.vicporch.ca
Chris G is offline
Old 06-15-2009, 08:43 AM   #2
Tech Geek
WarriorWithWood's Avatar
Trade: Property Management/Facilities Manager
Re: Span For 2 X 4's?
I would do a little excavation and use a 2x6 minimum. Span that 5' and you should be ok.
-Dennis
www.bowmanch.com
WarriorWithWood is offline
Old 06-15-2009, 09:02 AM   #3
Chris G's Avatar
It's over an existing concrete pad.
Chris G is offline
Old 06-15-2009, 09:04 AM   #4
Tech Geek
Why aren't you taking out the pad?
-Dennis
www.bowmanch.com
Old 06-15-2009, 09:11 AM   #5
strat hd
strathd's Avatar
Trade: framing contractor , remodeler , GC occasionally
Maybe you could use doubles or triples ? (Two 2x4's nailed side by side.)
strathd is offline
Old 06-15-2009, 09:13 AM   #6
Old time rule of thumb:
2X4-4', 2X6-6'.......
Gives a stiff floor,
less span than "allowable."
neolitic is offline
Old 06-15-2009, 09:43 AM   #7
BuiltByMAC's Avatar
Trade: Construction
Last ground level deck I built (partially over a concrete patio) was 2x4 joists 16" oc. spanning 4' sitting on 4x4 beams (4' oc) spanning 4' sitting on concrete pier blocks buried in grade sitting on 4" packed gravel. (frost line is 12" deep for us here)
Mac
BuiltByMAC is offline
Old 06-15-2009, 10:04 AM   #8
Morning Wood's Avatar
Trade: Pretty much anything with wood
http://www.awc.org/calculators/span/...Options#answer
http://www.awc.org/calculators/span/...rcalcstyle.asp
Morning Wood is online now
Old 06-15-2009, 11:53 AM   #9
redwood's Avatar
Trade: Carpentry Contractor
Neo and Mac have it right. I use the same thumb as Neo.
I would go to a 4x4 over a 2x4 though.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is online now
Old 06-15-2009, 12:24 PM   #10
General Contractor
greg24k's Avatar
All floor joist tables start with 2X6 lumber. If you use awc calculator 2x4 can span 6'2" with L360 deflection for decks 40lb LL. I personally think it will be a bouncy floor. Shorten the span maybe to 5' and put them 12" OC or like Mac said 4'- 16" OC.
If you have a threshold that you can only fit 2x4 under it and I assume the concrete is pitched away from the house, why not rip wider lumber from 3.5" under the door to what ever you need on the other end to have a level surface.
greg24k is offline
Old 06-15-2009, 01:00 PM   #11
It is 1 P.M. and it is daylight.
neolitic is offline
Old 06-15-2009, 01:24 PM   #12
KentWhitten's Avatar
You are perfectly fine at that distance. You will be surprised how stiff that will be. Irregardless of the size joist, they figure a minimum (usually) of L/360 and a span of 6' gives you a deflection of .2" , a very stiff floor. You do not need 4x4's. That will not be bouncy in the least bit.
Salmon Falls Cabinetry
KentWhitten is offline
The Following User Says Thank You to KentWhitten For This Useful Post:
greg24k (06-15-2009)
Old 06-15-2009, 03:35 PM   #13
General Contractor
greg24k's Avatar
Are you sure?
greg24k is offline
Old 06-15-2009, 05:45 PM   #14
topsail's trimcat
woodworkbykirk's Avatar
up here in the great white north 2x8 is the minimum. but we can get away with 2x6 for a very small landing sometimes
woodworkbykirk is offline
Old 06-15-2009, 06:45 PM   #15
Originally Posted by greg24k View Post
Are you sure?
'Twas a test.
Results as expected.
neolitic is offline
Old 06-15-2009, 07:03 PM   #16
Crock's Avatar
Trade: Fan of Bodger
Think about a long 2x4 roof truss. Designed correctly a 2x4 is strong as hell.
Crock is offline
Old 06-15-2009, 07:05 PM   #17
Chris G's Avatar
Cool, Thanks guys.
As to why I didn't think of doubling them up, I dunno, I was so fixated on a dimension I never use that I clearly forgot fundamentals, (or mentals).
As far as busting the pad. It's old and the last old pad I busted up was 8 - 10 inches thick with rod in it.
Thanks Framerman. It's hard to believe but I will take your word for it adn give it a go. I can always add more support bases if I need.
These are the pedestals btw, although the application for the one in the picture is for deck tiles. They make them without the tabs to hold 2 x material.
Chris G is offline
Old 06-15-2009, 07:07 PM   #18
Chris G's Avatar
The surface is pitched all over the place, I don't think I could lay sleepers without gathering standing water somewhere.
Chris G is offline
Old 06-15-2009, 07:11 PM   #19
General Contractor
greg24k's Avatar
Nice to see you awake Neo, I try to have a "siesta" right around that time, a little espresso with anisette
'Twas a test.
greg24k is offline
Old 06-15-2009, 09:29 PM   #20
Originally Posted by Chris G View Post
Cool, Thanks guys.
I did a house a while back. It was a single story with a crawlspace. The builder had 2x6 floor joists, 16" OC, 8' OC for the 4x6 beams on the prints. I told him he was ****ing crazy. He told me to talk to him after the floor was down. I was schooled. Unbelievable how solid it was. Almost too solid.
And to boot, the guy saved a lot of money using 2x6 instead of the usual 2x10.
4x4's will give you minimal improvement in performance. It carries more load, but the deflection is barely touched. It's better, yes, but minimal.
JamesKB2 (06-15-2009)
Span chart KGB Framing 11 03-13-2009 01:09 AM
TJI SPAN Question msc5195 Framing 47 01-18-2009 09:18 PM
Floor Joist Span BuriedHammer Framing 16 12-30-2008 09:03 PM
Vinyl soffit span... what backing OC? bobaganoosh Windows, Siding and Doors 11 12-24-2008 12:41 AM
Span question bikerboy Introductions 5 08-23-2008 07:44 AM
