Spacing For Rails On Deck. Codes
Old 01-23-2006, 02:28 PM   #1
keithguts's Avatar
Trade: Prof. Carpenter
Question
I live in bayshore li. wondering if any one knowa the code for the spacing between the rails.
Keith
keithguts is offline
Old 01-23-2006, 02:33 PM   #2
Deck Designer/Builder
DecksEtc's Avatar
Re: Spacing For Rails On Deck. Codes
4" is pretty standard everywhere but you should double check with your building department. I make all mine 3 1/2" so I NEVER have a problem.
As well, railing heights vary according to the height of the deck and by your local codes.
I am the liquor - Jim Lahey, Trailer Park Supervisor
DecksEtc is offline
Old 01-23-2006, 03:08 PM   #3
keithguts's Avatar
Terry, I think I know what type of work you do. what a crazy question. I just seen your logo. Sorry.
Old 01-23-2006, 05:46 PM   #4
RobertCDF's Avatar
Trade: Custom deck builder
Terry, you sound like me if its 3 1/2" even if it shrinks a little bit no problems. 36 1/2" high at least. Hear of people getting screwed and having to redo it or pay to get a variance because they wanted to make it as close as possible. Idiots.
RobertCDF is online now
Old 01-23-2006, 07:43 PM   #5
DecksEtc's Avatar
That's the exact reason I do it Robert. Adding one or two balusters per railing section costs me a lot less than going back and replacing an entire section a couple years down the road.
DecksEtc is offline
Old 01-23-2006, 07:52 PM   #6
locofoco's Avatar
Trade: general remodeling
Is 4" code everywhere? That really seems close. I did a couple decks for family at 8". OOPS! They were nice decks otherwise. Better check my local code before doing any for paying customer.
locofoco is offline
Old 01-23-2006, 08:20 PM   #7
bob the builder's Avatar
Trade: Home Improvement
is that a 2x2-5" o.c. yer talking??? I thought you were the one with the spindle even spacing between posts calulator, if I remember correct...
Bob
bob the builder is offline
Old 01-23-2006, 08:23 PM   #8
The problem with 8" spacing is I can almost fit between there.
4" is standard, but if I work out of the city there aren't codes, and one customer in particular insisted on 2/ 2x6 cedar for spindles which ends up being well over your 8"....
Bob
Old 01-23-2006, 08:24 PM   #9
Peladu's Avatar
bob the builder ....... my youngest son loves you....:Thumbs:
.....now back to the topic
Peladu is offline
Old 01-23-2006, 08:48 PM   #10
RobertCDF's Avatar
I was not the one with the calculator but I will let you in on how I do it. Cut the 2 2x4's find center mark both sides of baluster use a 12" speed square on the "other side" of the center baluster and mark 4 1/2" and go.
Old 01-23-2006, 09:17 PM   #11
theman's Avatar
Keithgut
Welcome N.Y. Residential Code requires a 4 inch max space between rails. remember your biggest problem is the hand rail, max width is 2 5/8 " good luck
theman is offline
Old 01-23-2006, 09:18 PM   #12
cdac
Guest
cdac's Avatar
Posts: n/a
Old 01-23-2006, 09:54 PM   #13
Originally Posted by cdac
robert thats a good method, i'll share what I do,
x=post to post (inside)dimention
y=whatever baluster spacing you want to go with
z=width of baluster weather 1.5" or 5.5" ect.
divide x by y and round to nearest whole #, this is the # of balusters/rail segment.
divide x by #of balusters, this is your baluster spacing
take your baluster spacing and subtract one baluster width, divide that by 2, this is your first and last space in that rail segment, this takes all the guess work out of having too slender or too wide a gap at the ends
That's how I do it too... But you do your math on a piece of lumber or go get a calulator???
Bob
Old 01-23-2006, 10:01 PM   #14
jmic's Avatar
Hey this thread has things missing, whats going on?
Joe
jmic is offline
Old 01-23-2006, 10:46 PM   #15
RobertCDF's Avatar
If I did all that though I might have to use my brain (I dont always use 4 1/2 I kind of know what to use to not have to wide a gap at the end) But I think I will hang onto that formula and maybe use it next time. I have to put use to that construction master calculator that I bought (tool addict)
Old 01-23-2006, 11:41 PM   #16
Bah Humbug!
Grumpy's Avatar
It's the moderators moderating for the benefit of everyone.
Grumpy is offline
Old 01-23-2006, 11:49 PM   #17
K2's Avatar
Yes, Thank you moderators.
K2 is offline
Old 01-24-2006, 01:08 AM   #18
cdac
Guest
cdac's Avatar
Posts: n/a
Old 01-25-2006, 08:18 PM   #19
rjordan392's Avatar
For what its worth, I was told by a an inspector that the reason for 4" spacing or less is to prevent a toddler from getting his/her head through the space and possibly falling off the deck.
rjordan392 is offline
Old 01-25-2006, 09:29 PM   #20
DecksEtc's Avatar
That's the theory behind the 4" spacing. Because, you know, some kid somewhere challenged his little brother to stick his head through the railing and low and behold, got his head stuck in a 5" space.
DecksEtc is offline
Mass deck footing codes Mike Fish Decks & Fencing 1 07-25-2007 08:34 PM
Dry lower deck stuff frostyfrost Decks & Fencing 12 05-19-2007 07:59 AM
Cedar Deck Prep Problems Larman Painting & Finish Work 2 05-04-2007 05:31 PM
deck beam sizing and post spacing? diyerforever Decks & Fencing 5 05-10-2006 10:58 PM
