Sonar Tube Next To A Septic System
Old 04-11-2009, 12:03 PM   #21
redwood's Avatar
Trade: Carpentry Contractor
Re: Sonar Tube Next To A Septic System
In my area, you must be clear of the leach field by 5'. To my knowledge, there is no restriction as to distance from the septic tank itself, other then it must remain accessable.
Mark
Los Gatos, CA
www.creative-redwood-designs.com
redwood is offline
Old 04-11-2009, 12:14 PM   #22
deck king's Avatar
Trade: deck builder
Look at Mac's site.
Read through his threads.
How do you keep talking with
both feet in your mouth?
Actually, I'm typing.
You should see what I'm typing with.
deck king is offline
Old 04-11-2009, 12:44 PM   #23
Joe Carola's Avatar
Trade: Framing Contractor
Accessible tom clean, but he said that the deck will be covering the tank by 2'. Is that even legal?
Joe Carola
Joe Carola is offline
Old 04-11-2009, 01:19 PM   #24
concretemasonry's Avatar
Trade: Masonry consultant
Just a minor correction in the necessary soil strength -
I assume it was meant by Deck King was to say 3300 psf and not 3300 psi. The 3300 psi (usually 3000 psi) would be the minimal strength of concrete.
In most areas 2500 psf is adequate and most standard designs/code compliance standards are based on about 2500 psf.
Dick
concretemasonry is offline
Old 04-11-2009, 03:06 PM   #25
Golden Rule's Avatar
Trade: New Construction and Remodelling
Throw a glulam in and stain it....you can get something off the shelf in your local yard most likely...and then u can eliminate that middle post. Might need to up grade to 10" or 12" sonotubes tho.
Golden Rule is offline
Old 04-11-2009, 03:32 PM   #26
deck king's Avatar
Trade: deck builder
Thanks for correcting me! that is what I meant.
Old 04-11-2009, 03:41 PM   #27
That would be some gluelam,
13'-9" span.
neolitic is offline
Old 04-11-2009, 04:03 PM   #28
KentWhitten's Avatar
Well....they do make pressure treated parallams now. Bet it's expensive as hell though.
Salmon Falls Cabinetry
KentWhitten is offline
Old 04-11-2009, 06:53 PM   #29
Meetre's Avatar
not sure of your layout, but could you go with 4 posts and split over the problem area? not sure if you can fit it in the budget, or if it will work with where the tank is.
Meetre is offline
Old 04-11-2009, 07:21 PM   #30
Illusion of Perfection
CookeCarpentry's Avatar
I know in my area (eastern PA), we cannot disturb the ground usually within 5' of the septic tank and leach field. Some places have even further distances. Building codes vary by state and locality, so call the local building department and see what they say, and also verify it with a local septic contractor. The biggest thing here, in my opinion, is that there is a limited shelf life on septic systems and not if it needs to be replaced but when...
CookeCarpentry is offline
Old 04-12-2009, 08:01 PM   #31
13'-9" span.
Really...3.125 x 16.5 will span it and that's not a hell of a lot bigger than a 4x12. I'd definitely consider a glulam.
Old 04-12-2009, 08:18 PM   #32
mics_54's Avatar
Trade: contractor
Typically a septic tank must be ten feet away from a dwelling with a basement or other excavation. Also typically piers are not addressed with any type of prescriptive method noted in the IRC. Most pier designs requiring an engineers stamp would need to be engineered by the one stamping it. They would probably not allow such installation if they have liability for it...I am just guessing but I've been around the block a few times. If it's a pier for a deck it wouldnt worry me that much because if it caused a problem it's fairly easy to modify. My question is why not modify it now and avoid any precieved problems.
mics_54 is offline
Old 04-13-2009, 06:55 PM   #33
ronm1974's Avatar
Trade: Remodeling contractor
Just want to tell you guys what happened. Went to the town hall and talked to the board of health this morning and he said dont worry about it, as long as its not on top of the tank theres nothing to worry about. Thought you guys would like to know. Happy digging
ronm1974 is offline
Installing Septic System SMKFULLER Excavation & Site Work 8 04-03-2008 09:23 PM
New septic system silvertree General Discussion 14 11-26-2007 07:36 PM
Living Filter Septic System jmic Excavation & Site Work 18 07-20-2007 09:31 PM
Septic system construction. gdavis Excavation & Site Work 5 02-04-2007 03:29 PM
Systems Development List Gordo Business 19 01-08-2007 07:28 PM
